Evo 5 ECU question
Postby Evo4Mad » Thu Jan 25, 2007 4:32 pm
I hook up my 0-5v output from the LC-1 to it.
Postby BarryC. » Fri Jan 26, 2007 7:10 am
how did you solve the cooling fan problem Evo4mad
any other info would be greatly appreciated
BarryC.
Postby GTODesign » Sat Jan 27, 2007 12:17 am
Evo4Mad Posted: Thu Jan 25, 2007 11:02 pm Post subject:
there is no rear o2 sensor on evo4
And... the E4 O2 sensor isn't heated, E5+ is. (Can't remember if that throws a CEL though) :?:
Re; fan control...
To do it properly you need the 'little black box' from the back of the fan on an E7+ and a bit of wiring. Alternatively, you could fit a thermostatic fan switch and forget about the ECU controlled fan operation. This may, however, cause issues with the A/C (if fitted). [/quote]
GTODesign
Postby BarryC. » Sat Jan 27, 2007 1:41 am
ok my car dont have A/C so fit a PWM controller to the existing fan good idea.
have you swapped the ecu out in your own car???
thanks for the help much appreciated.
any other advice about doing this???
BarryC.
Postby GTODesign » Sun Jan 28, 2007 11:57 am
Did it a while ago on an E4. Went through all the wiring diagrams and the only real differences were fan control (some of the ECU pins differ with regard to fan control also) and O2 sensor differences. Unfortunately I never got to the point of finishing the project and getting rid of the occasional CEL it would throw, could have done with an MUTII to check the codes it was giving really. Car was running quite happiliy though.
GTODesign
