Here's some Enginuity definitions to test for this rom. It is pretty close to being final for the next def release, but I still have to check a few things.
To add to Enginuity, open up the Ecu Definition Manager in the Edit menu and add it to the list. If you don't usually use Enginuity, be sure you up your user level to 4 or 5 to view all the tables.
This is a very interesting rom. More tables than I've seen before (597 2d tables and 180 3d tables). There are 6 boost maps, 6 fuel maps, 5 base timing maps, 4 ign correction maps, among others.
