and I really mean that,
cossie1 wrote:That goes from me too
BTW barry, tested an evo 7 ralliart ecu in my 6 RSII earlier, car started and ran fine, but the fans were on constantly.
No wireing mods done, just litterly plug and play
3gturbo wrote:cossie1 wrote:That goes from me too
Sounds like the fan circuit uses a different pin an open circuit to the fan controller will make them run all the time. Normally when it's getting 5v it is off and the ecu lowers the voltage to bring on the fans on from there.
R. Mutt wrote:both u guys have evo VI? GSR, RS or RSII? A friend of mine has a VI GSR and there's no white second connector
cossie1 wrote:3gturbo wrote:cossie1 wrote:That goes from me too
Yeh I need to swap 4 wires around apparently to get the fans to work correctly.
Just wanted to confirm to myself that the car will actually run using an e7 Ralliart Ecu.
Was a bit sceptical if I am honest, as the e7 has a 256k flash and the e6's are 128k
gtpumps wrote:cossie1 wrote:3gturbo wrote:cossie1 wrote:That goes from me too
EVO7 ECU uses PWM to control variable speed fan. On EVO7,8,9 there is a fan control module mounted on the radiator fan shroud.
EVO6 ECU uses a simple on/off system with hi/lo speed relays.
Be careful you could damage the EVO7 ECU (if you haven't already!) the PWM output is not designed to switch relays.
So you need to control the lo/hi speed fan relays seperately somehow using a temperature switch or wire in a complete EVO7 fan setup.
I just can't believe you guys can't spend 5 minutes looking at a wiring diagram
cossie1 wrote:I have been told, all that is needed to get it working correctly is this:
Disconenct the idle switch wire (Pin 87).
Then swap wires 32 and 34 (A/C Lo and Hi fan). Disconnect 20 and 21 (rad Lo and Hi fan)and connect 20 to the wire that is now at 32 and connect 21 to the wire that is now at 34.
gtpumps wrote:cossie1 wrote:I have been told, all that is needed to get it working correctly is this:
The A/C fan only runs when the aircon is on how is that going to help? Also it runs in low speed as soon as you press the A/C button, not engine temp controlled.
It won't cause a problem. It is working the same as before, except that the a/c fan pins are being used to trigger the radiator fans as well as the a/c fans. The ECU only pulls the fan relays to ground, so it is not as if the total fan current is passing through the ECU.
cossie1 wrote:gtpumps wrote:cossie1 wrote:I have been told, all that is needed to get it working correctly is this:
I did ask a similar question.
This was the replyIt won't cause a problem. It is working the same as before, except that the a/c fan pins are being used to trigger the radiator fans as well as the a/c fans. The ECU only pulls the fan relays to ground, so it is not as if the total fan current is passing through the ECU.
