Help to edit map
Help to edit map
Postby joegoi » Fri Aug 18, 2006 8:12 pm
Hi All,
I have successfully extracted or connect to the ecu with ecuflash. through the help of FrSti.
And now i need another help.........
I cannot edit the maps.
So it goes
the current map description is invalid or incomplete. Please edit the map descrition to fix the problem and the map will be viewable again.
I will need to set the level to beginner and the address?????????
what else is needed????????
Please anybody??????
I'm still waiting for the reply from Frsti.
Thanks all.
This is the best forum but i'm still very far behind 2 days playing.
2 weeks reading can't get anything. You guys are too advanced.
joegoi
Postby Tea cups » Fri Aug 18, 2006 8:37 pm
Tea cups
Re: Help to edit map
Postby ahains » Fri Aug 18, 2006 8:39 pm
joegoi wrote:Hi All,
So it goes
Thanks all.
Are you using ecuedit or enginuity?
What version?
Are you using xmlwrite? If not, where did you get your ecu definition file?
What year, model, and market is your car?
ahains
Postby joegoi » Fri Aug 18, 2006 8:44 pm
My is a Sti impreza 2003.
i use the Ecuflash to get all the data.
joegoi
Postby joegoi » Fri Aug 18, 2006 8:54 pm
Hi all,
This is the rom info that i have gotten,
internal id A4RN200H
Flash method wrx02
Memory model 68HC16Y5
Joe
joegoi
Postby joegoi » Sat Aug 19, 2006 4:04 am
Thanks all.
I have gotten all the info needed to tune the car.
Thanks to TEA CUPS for begineer go and read carefully at the site given. i did not get it at first.
Hope i can get the max out of it.
Cheers all and to colby too for letting us the subaru owner have this previleages.
Joe
joegoi
Postby Kosti » Wed Aug 23, 2006 3:29 am
Tea cups wrote:http://www.enginuity.org/about444.html
Great link, thank you mate
Kosti
