old shape lancer/1996 sohc 1.6 glxi ECU help
Postby Marty7n » Mon May 23, 2011 1:43 pm
i have a 1996 mitsubishi lancer,its the old shape.
1.6 sohc
steel case ecu
i have taken the ecu out it reads as follows on the white sticker on the top of the case
MD307354
E2T38986
5130 M
Mitsubishi electric corp.JAPAN
on the side it has another sticker reading
7354
204 E2T38986
Mitsubishi electric corp.Japan
The plan is to turbo this engine and ecu or even be able to up the performance of the engine,i am new to this lads!i know i need to get a cable to connect to my laptop or pc,does anyone have info on what obd this ecu is?and is it capable of much??it has 64 pins.
has anyone chipped one of these ecu's for a turbo??or what do i need to do??
will it cost much??
:shock:
Thanks a million
Marty7n
Re: old shape lancer/1996 sohc 1.6 glxi ECU help
Postby todd-w » Tue May 24, 2011 1:53 am
ecu isnt flashable its possible to use later ecu (plastic case ) 99 on from similar model and flash that but if it has an external immobiliser ( steel case usually situated just behind the radio to the right rhd model) theres some re wiring to do .
todd-w
Postby Theoexelixis » Wed Aug 03, 2011 6:04 am
Hello
I am trying as also to get some infos regarding the pinout of the same ECU.I am planning to install an EVO 8 ECU on the car but so far no luck to get the pinouts of the OEM ECU of the car
If anybody can help is welcome.
Theo
Theoexelixis
