throttle closes
throttle closes
Postby student_scheire » Tue May 18, 2010 12:37 am
I'm running with my EVOX'08 on a boost from 22PSI at max torque and it tapers to 18.9 @ 6500.
I think it has a lack of power above 6500 so I've made several logs with VCDS and noticed the next thing:
When I do a pull in any gear at full throttle, the throttle goes from 96% to 60% above 6500RPM. How to avoid this?
No trottle map makes such a change at high rpm
trottle problem.JPG (105.31 KiB) Viewed 2898 times
student_scheire
limiter maps
Postby student_scheire » Wed May 19, 2010 12:17 am
limiter maps;
torque and aircheck #1-#3 and torque limiter and aircheck #4
airflow and torque limiter.jpg (180.75 KiB) Viewed 2883 times
student_scheire
