Hi all, had a problem flashing a mod to an Evo 6, using ecuflash the test write is ok but when I actually write to ecu I get an error, attached below, I can write the original back no problem.
Anybody have any ideas or advice?
Chris
[16:28:52.616] J2534 API Version: 04.04
[16:28:52.616] J2534 DLL Version: 0.50.2598 Jun 26 2009 15:02:29
[16:28:52.616] Device Firmware Version: 1.07.2597
[16:28:55.610] sending init sequence 2
[16:28:55.690] got 0x13 response instead of 0x11
[16:28:55.690] sending init sequence 3
[16:28:56.141] entering bootloader
[16:28:56.221] sending kernel size (2029)
[16:28:56.281] sending kernel load address (0x0000F000)
[16:28:56.291] uploading kernel
[16:28:56.622] verifying kernel checksum response
[16:28:56.622] kernel valid
[16:28:56.822] kernel get version
[16:28:56.882] kernel version is : OpenEcu Mitsubishi H8/539F Kernel V1.06
[16:28:56.882] reading kernel comm buffer size
[16:28:56.942] comm buffer size set to 256
[16:28:56.942] reading kernel flash buffer size
[16:28:56.952] flash buffer size set to 1024
[16:28:57.112] -- flashing image to ECU memory --
[16:28:57.513] -- comparing ECU flash memory pages to image file --
[16:28:57.513] seg start len ecu CRC32 img CRC32 same?
[16:28:57.663] LB7 00010000 00003000 20B88DCE 638A3E14 NO
[16:28:57.763] SB0 00013000 00000200 BD7BC39F BD7BC39F YES
[16:28:57.823] SB1 00013200 00000200 BD7BC39F BD7BC39F YES
[16:28:57.884] SB2 00013400 00000200 BD7BC39F BD7BC39F YES
[16:28:57.954] SB3 00013600 00000200 BD7BC39F BD7BC39F YES
[16:28:58.014] SB4 00013800 00000200 BD7BC39F BD7BC39F YES
[16:28:58.074] SB5 00013A00 00000200 BD7BC39F BD7BC39F YES
[16:28:58.144] SB6 00013C00 00000200 BD7BC39F BD7BC39F YES
[16:28:58.204] SB7 00013E00 00000200 BD7BC39F BD7BC39F YES
[16:28:58.464] LB6 00014000 00004000 EA3E3443 EA3E3443 YES
[16:28:58.665] LB5 00018000 00004000 BEF6372A BEF6372A YES
[16:28:58.865] LB4 0001C000 00004000 690B37D3 690B37D3 YES
[16:28:59.065] LB3 00020000 00004000 824D955A 824D955A YES
[16:28:59.266] LB2 00024000 00004000 2A89DA00 2A89DA00 YES
[16:28:59.476] LB1 00028000 00004000 6A780468 6A780468 YES
[16:28:59.676] LB0 0002C000 00004000 64438855 64438855 YES
[16:28:59.676] kernel flash enable
[16:28:59.736] kernel blank flash page: addr: 00010000
[16:29:14.798] WARNING: failed to erase page at 00010000!
[16:29:14.798] kernel flash disable
[16:29:16.901] interface close
