Impresas 2.5T 2006y ECU
Postby Morfeus » Sun Sep 09, 2007 1:21 am
Hi,
My friend sent me his Impresas (2.5T 2006y) ECU and I have to reprogramm it with EcuFlesh on the table.
But I don't know what Pins I have to connect to ECUFlesh (+12V, 0, ignition, K-line, L-line (if in use),
Programm-pin maybe something else).
Pins of EcuFlesh OBD connector as I know are:
4/5 - 0V
16 - +12V
3/7 - K-Line
9/15 - L-Line
11 - ProgrammEnable Pin (?)
:?: Can somebody help me with that and give me info about pins of that Impresas 2.5T 2006 ECU (on the picture)?
:?: And what I need instead of connecting of green connector (if I need do this).
Ecu Board
ECU connector
Morfeus
Hi morfeus
Postby christian_piasini » Sat Feb 02, 2008 7:52 am
Maybe I can help you with this....
see below... ;-)
Regards
Instruction subaru_STi_.pdf
(508.53 KiB) Downloaded 369 times
