by gutano » Tue Nov 20, 2007 8:23 am
Are you connecting the test connectors (should hear fans cycling, etc if they are connected, ignition in on position)? You will only need these connected when flashing the ECU (not logging or reading).
NOTE: Other years/models usually have test connectors in a different location, I can only verify this for a 2006 STI.
They are green connectors (that are not connected) located by the passengers right foot (covered by the piece of molding that runs along the bottom of the door up to the bottom of the glove box). It is pretty easy to take off, and if your taking the slow tune (incremental, over days) route you probably want to let it hang out for the mean time.
