07 STi
Postby ev8siv3 » Wed Oct 11, 2006 9:26 am
Looks like it dumped. Can you upload the image it dumped please?
ev8siv3
Postby akcel » Wed Oct 11, 2006 10:05 am
that last log posted is from a 07 limited. the mystery motor/ecu is what he's having trouble connecting to, in the first post log
akcel
Postby ev8siv3 » Wed Oct 11, 2006 10:11 am
Does the ECU that is in mystery car currently run the car? We had an issue with an '07 ECU they sent back from SOA completely UN-PROGRAMMED and had to be sent back to get taken care of.
ev8siv3
Postby Keener2.5 » Wed Oct 11, 2006 11:32 am
ev8siv3 wrote:Does the ECU that is in mystery car currently run the car? We had an issue with an '07 ECU they sent back from SOA completely UN-PROGRAMMED and had to be sent back to get taken care of.
Yep, it seems to be running the car fine.
Keener2.5
Postby cboles » Wed Oct 11, 2006 1:50 pm
Can you post the ROM for this ECU? You should be able to flash this one.
Keener2.5 wrote:Hi. I work for Garage Tuning, and I am the guy with the unkown ECU Motor in my GC. What I got from the supplier is that it is preproduction 07-08.
We connected to an 07 Vlimited STi without any trouble tonight. Here is the log, can anyone tell me anything about it? I still am not able to get into my *supposedly 07* ECU.
Thanks for all your help
-Brian
Postby Keener2.5 » Wed Oct 11, 2006 10:32 pm
cboles wrote:Can you post the ROM for this ECU? You should be able to flash this one.
Next time the car is at the shop I can.
Well thats cool that 07s won't be a problem, however I still don't know what mine is!
:x
Keener2.5
Postby akcel » Thu Oct 12, 2006 9:27 am
that's why we want u to post the image BRIAN! :P
akcel
Postby ev8siv3 » Thu Oct 12, 2006 9:37 am
I have an 07 STi image posted on here somewhere. However, has anyone had a successful reflash of one yet?
ev8siv3
Postby Keener2.5 » Thu Oct 12, 2006 10:18 am
akcel wrote:that's why we want u to post the image BRIAN! :P
But I can't because I can't even connect to the ECU! :shock:
Keener2.5
Postby Freon » Thu Oct 12, 2006 10:39 am
Here is the 07 someone posted elsewhere on the forum:
http://freon.shackspace.com/car/ecu%20a ... %20STi.hex
and a very, very early ecuedit XML I wrote for it
http://freon.shackspace.com/car/ecu%20a ... UG000J.xml
VERY different than the 04-06 STI!
Postby merchgod » Thu Oct 12, 2006 11:16 am
Freon wrote:Here is the 07 someone posted elsewhere on the forum:
I have support for the 07 sti limited rom that was posted up. These are defs for Enginuity in the latest update:
http://www.enginuity.org/viewtopic.php?t=360
merchgod
Postby Keener2.5 » Thu Oct 12, 2006 11:16 am
:lol: I just got in!! I was fiddling around with getting my windows to work and notices a white one wire plug that wasn't connected to anything, kind of like the green on the passenger side. I plugged it in and tried connecting to the ECU and it worked!!
Here is the log, from what my n00btastic eyes can see its very similar to the 07 V limited.
[01:09:01.865] Version 1.28.716
[01:09:01.875] 8 memory models read.
[01:09:02.236] 73 ROM metadata models read.
[01:09:02.236] checksum module "subarudbw" loaded.
[01:09:02.236] flashing tool "wrx02" loaded.
[01:09:02.236] flashing tool "wrx04" loaded.
[01:09:02.236] flashing tool "sti04" loaded.
[01:09:02.236] flashing tool "sti05" loaded.
[01:09:02.236] flashing tool "mitsukernel" loaded.
[01:09:02.236] flashing tool "mitsukernelocp" loaded.
[01:09:02.236] flashing tool "mitsubootloader" loaded.
[01:09:02.236] error loading FTD2XX.DLL
[01:09:13.682] ssm2_init
[01:09:13.852] ECU ID is 43 42 59 20 06
[01:09:13.862] ssm2_cmd_0x81
[01:09:13.902] ssm2_cmd_0x83
[01:09:13.963] denso challenge-response
[01:09:14.033] challenge is 1E DA 5C 60
[01:09:14.033] response is 00 57 53 B7
[01:09:14.093] ssm2_cmd_0x10
[01:09:14.473] validating denso kernel ram area addr: FFFF3000 len: 0C28
[01:09:14.533] writing denso kernel area addr: FFFF3000 len: 0C28
[01:09:14.734] writing denso flash block addr: FFFF3000 len: 0080
[01:09:15.054] writing denso flash block addr: FFFF3080 len: 0080
[01:09:15.355] writing denso flash block addr: FFFF3100 len: 0080
[01:09:15.665] writing denso flash block addr: FFFF3180 len: 0080
[01:09:15.965] writing denso flash block addr: FFFF3200 len: 0080
[01:09:16.286] writing denso flash block addr: FFFF3280 len: 0080
[01:09:16.596] writing denso flash block addr: FFFF3300 len: 0080
[01:09:16.897] writing denso flash block addr: FFFF3380 len: 0080
[01:09:17.197] writing denso flash block addr: FFFF3400 len: 0080
[01:09:17.508] writing denso flash block addr: FFFF3480 len: 0080
[01:09:17.828] writing denso flash block addr: FFFF3500 len: 0080
[01:09:18.139] writing denso flash block addr: FFFF3580 len: 0080
[01:09:18.439] writing denso flash block addr: FFFF3600 len: 0080
[01:09:18.749] writing denso flash block addr: FFFF3680 len: 0080
[01:09:19.060] writing denso flash block addr: FFFF3700 len: 0080
[01:09:19.390] writing denso flash block addr: FFFF3780 len: 0080
[01:09:19.711] writing denso flash block addr: FFFF3800 len: 0080
[01:09:20.031] writing denso flash block addr: FFFF3880 len: 0080
[01:09:20.352] writing denso flash block addr: FFFF3900 len: 0080
[01:09:20.672] writing denso flash block addr: FFFF3980 len: 0080
[01:09:20.993] writing denso flash block addr: FFFF3A00 len: 0080
[01:09:21.293] writing denso flash block addr: FFFF3A80 len: 0080
[01:09:21.594] writing denso flash block addr: FFFF3B00 len: 0080
[01:09:21.914] writing denso flash block addr: FFFF3B80 len: 0080
[01:09:22.214] writing denso flash block addr: FFFF3C00 len: 0028
[01:09:24.478] entering kernel
[01:09:24.718] kernel get version
[01:09:24.758] kernel version is : OpenECU Subaru SH7058 OCP Kernel V0.21
[01:09:24.778] Dumping ECU memory...
[01:09:24.798] kernel read area: addr: 00000000 len: 0400
[01:09:25.008] kernel read area: addr: 00000400 len: 0400
[01:09:25.219] kernel read area: addr: 00000800 len: 0400
[01:09:25.429] kernel read area: addr: 00000C00 len: 0400
[01:09:25.659] kernel read area: addr: 00001000 len: 0400
[01:09:25.900] kernel read area: addr: 00001400 len: 0400
[01:09:26.130] kernel read area: addr: 00001800 len: 0400
[01:09:26.360] kernel read area: addr: 00001C00 len: 0400
[01:09:26.601] kernel read area: addr: 00002000 len: 0400
[01:09:26.801] kernel read area: addr: 00002400 len: 0400
[01:09:27.021] kernel read area: addr: 00002800 len: 0400
[01:09:27.232] kernel read area: addr: 00002C00 len: 0400
[01:09:27.462] kernel read area: addr: 00003000 len: 0400
[01:09:27.672] kernel read area: addr: 00003400 len: 0400
[01:09:27.903] kernel read area: addr: 00003800 len: 0400
[01:09:28.103] kernel read area: addr: 00003C00 len: 0400
[01:09:28.313] kernel read area: addr: 00004000 len: 0400
[01:09:28.534] kernel read area: addr: 00004400 len: 0400
[01:09:28.744] kernel read area: addr: 00004800 len: 0400
[01:09:28.954] kernel read area: addr: 00004C00 len: 0400
[01:09:29.164] kernel read area: addr: 00005000 len: 0400
[01:09:29.395] kernel read area: addr: 00005400 len: 0400
[01:09:29.625] kernel read area: addr: 00005800 len: 0400
[01:09:29.825] kernel read area: addr: 00005C00 len: 0400
[01:09:30.036] kernel read area: addr: 00006000 len: 0400
[01:09:30.246] kernel read area: addr: 00006400 len: 0400
[01:09:30.486] kernel read area: addr: 00006800 len: 0400
[01:09:30.707] kernel read area: addr: 00006C00 len: 0400
[01:09:30.937] kernel read area: addr: 00007000 len: 0400
[01:09:31.147] kernel read area: addr: 00007400 len: 0400
[01:09:31.368] kernel read area: addr: 00007800 len: 0400
[01:09:31.568] kernel read area: addr: 00007C00 len: 0400
[01:09:31.788] kernel read area: addr: 00008000 len: 0400
[01:09:32.029] kernel read area: addr: 00008400 len: 0400
[01:09:32.229] kernel read area: addr: 00008800 len: 0400
[01:09:32.439] kernel read area: addr: 00008C00 len: 0400
[01:09:32.659] kernel read area: addr: 00009000 len: 0400
[01:09:32.870] kernel read area: addr: 00009400 len: 0400
[01:09:33.070] kernel read area: addr: 00009800 len: 0400
[01:09:33.280] kernel read area: addr: 00009C00 len: 0400
[01:09:33.501] kernel read area: addr: 0000A000 len: 0400
[01:09:33.721] kernel read area: addr: 0000A400 len: 0400
[01:09:33.951] kernel read area: addr: 0000A800 len: 0400
[01:09:34.152] kernel read area: addr: 0000AC00 len: 0400
[01:09:34.392] kernel read area: addr: 0000B000 len: 0400
[01:09:34.602] kernel read area: addr: 0000B400 len: 0400
[01:09:34.833] kernel read area: addr: 0000B800 len: 0400
[01:09:35.043] kernel read area: addr: 0000BC00 len: 0400
[01:09:35.263] kernel read area: addr: 0000C000 len: 0400
[01:09:35.474] kernel read area: addr: 0000C400 len: 0400
[01:09:35.694] kernel read area: addr: 0000C800 len: 0400
[01:09:35.904] kernel read area: addr: 0000CC00 len: 0400
[01:09:36.104] kernel read area: addr: 0000D000 len: 0400
[01:09:36.345] kernel read area: addr: 0000D400 len: 0400
[01:09:36.545] kernel read area: addr: 0000D800 len: 0400
[01:09:36.765] kernel read area: addr: 0000DC00 len: 0400
[01:09:36.996] kernel read area: addr: 0000E000 len: 0400
[01:09:37.196] kernel read area: addr: 0000E400 len: 0400
[01:09:37.416] kernel read area: addr: 0000E800 len: 0400
[01:09:37.637] kernel read area: addr: 0000EC00 len: 0400
[01:09:37.847] kernel read area: addr: 0000F000 len: 0400
[01:09:38.057] kernel read area: addr: 0000F400 len: 0400
[01:09:38.268] kernel read area: addr: 0000F800 len: 0400
[01:09:38.488] kernel read area: addr: 0000FC00 len: 0400
[01:09:38.708] kernel read area: addr: 00010000 len: 0400
[01:09:38.918] kernel read area: addr: 00010400 len: 0400
[01:09:39.119] kernel read area: addr: 00010800 len: 0400
[01:09:39.359] kernel read area: addr: 00010C00 len: 0400
[01:09:39.559] kernel read area: addr: 00011000 len: 0400
[01:09:39.780] kernel read area: addr: 00011400 len: 0400
[01:09:39.980] kernel read area: addr: 00011800 len: 0400
[01:09:40.190] kernel read area: addr: 00011C00 len: 0400
[01:09:40.421] kernel read area: addr: 00012000 len: 0400
[01:09:40.631] kernel read area: addr: 00012400 len: 0400
[01:09:40.831] kernel read area: addr: 00012800 len: 0400
[01:09:41.042] kernel read area: addr: 00012C00 len: 0400
[01:09:41.272] kernel read area: addr: 00013000 len: 0400
[01:09:41.482] kernel read area: addr: 00013400 len: 0400
[01:09:41.702] kernel read area: addr: 00013800 len: 0400
[01:09:41.913] kernel read area: addr: 00013C00 len: 0400
[01:09:42.123] kernel read area: addr: 00014000 len: 0400
[01:09:42.353] kernel read area: addr: 00014400 len: 0400
[01:09:42.594] kernel read area: addr: 00014800 len: 0400
[01:09:42.794] kernel read area: addr: 00014C00 len: 0400
[01:09:43.004] kernel read area: addr: 00015000 len: 0400
[01:09:43.225] kernel read area: addr: 00015400 len: 0400
[01:09:43.455] kernel read area: addr: 00015800 len: 0400
[01:09:43.665] kernel read area: addr: 00015C00 len: 0400
[01:09:43.906] kernel read area: addr: 00016000 len: 0400
[01:09:44.126] kernel read area: addr: 00016400 len: 0400
[01:09:44.346] kernel read area: addr: 00016800 len: 0400
[01:09:44.557] kernel read area: addr: 00016C00 len: 0400
[01:09:44.757] kernel read area: addr: 00017000 len: 0400
[01:09:44.977] kernel read area: addr: 00017400 len: 0400
[01:09:45.187] kernel read area: addr: 00017800 len: 0400
[01:09:45.408] kernel read area: addr: 00017C00 len: 0400
[01:09:45.628] kernel read area: addr: 00018000 len: 0400
[01:09:45.868] kernel read area: addr: 00018400 len: 0400
[01:09:46.089] kernel read area: addr: 00018800 len: 0400
[01:09:46.299] kernel read area: addr: 00018C00 len: 0400
[01:09:46.499] kernel read area: addr: 00019000 len: 0400
[01:09:46.720] kernel read area: addr: 00019400 len: 0400
[01:09:46.910] kernel read area: addr: 00019800 len: 0400
[01:09:47.120] kernel read area: addr: 00019C00 len: 0400
[01:09:47.331] kernel read area: addr: 0001A000 len: 0400
[01:09:47.541] kernel read area: addr: 0001A400 len: 0400
[01:09:47.761] kernel read area: addr: 0001A800 len: 0400
[01:09:48.002] kernel read area: addr: 0001AC00 len: 0400
[01:09:48.202] kernel read area: addr: 0001B000 len: 0400
[01:09:48.412] kernel read area: addr: 0001B400 len: 0400
[01:09:48.632] kernel read area: addr: 0001B800 len: 0400
[01:09:48.853] kernel read area: addr: 0001BC00 len: 0400
[01:09:49.053] kernel read area: addr: 0001C000 len: 0400
[01:09:49.273] kernel read area: addr: 0001C400 len: 0400
[01:09:49.504] kernel read area: addr: 0001C800 len: 0400
[01:09:49.714] kernel read area: addr: 0001CC00 len: 0400
[01:09:49.934] kernel read area: addr: 0001D000 len: 0400
[01:09:50.145] kernel read area: addr: 0001D400 len: 0400
[01:09:50.375] kernel read area: addr: 0001D800 len: 0400
[01:09:50.595] kernel read area: addr: 0001DC00 len: 0400
[01:09:50.806] kernel read area: addr: 0001E000 len: 0400
[01:09:51.006] kernel read area: addr: 0001E400 len: 0400
[01:09:51.246] kernel read area: addr: 0001E800 len: 0400
[01:09:51.487] kernel read area: addr: 0001EC00 len: 0400
[01:09:51.707] kernel read area: addr: 0001F000 len: 0400
[01:09:51.947] kernel read area: addr: 0001F400 len: 0400
[01:09:52.137] kernel read area: addr: 0001F800 len: 0400
[01:09:52.348] kernel read area: addr: 0001FC00 len: 0400
[01:09:52.558] kernel read area: addr: 00020000 len: 0400
[01:09:52.798] kernel read area: addr: 00020400 len: 0400
[01:09:53.019] kernel read area: addr: 00020800 len: 0400
[01:09:53.259] kernel read area: addr: 00020C00 len: 0400
[01:09:53.479] kernel read area: addr: 00021000 len: 0400
[01:09:53.680] kernel read area: addr: 00021400 len: 0400
[01:09:53.900] kernel read area: addr: 00021800 len: 0400
[01:09:54.100] kernel read area: addr: 00021C00 len: 0400
[01:09:54.341] kernel read area: addr: 00022000 len: 0400
[01:09:54.581] kernel read area: addr: 00022400 len: 0400
[01:09:54.811] kernel read area: addr: 00022800 len: 0400
[01:09:55.042] kernel read area: addr: 00022C00 len: 0400
[01:09:55.272] kernel read area: addr: 00023000 len: 0400
[01:09:55.482] kernel read area: addr: 00023400 len: 0400
[01:09:55.703] kernel read area: addr: 00023800 len: 0400
[01:09:55.943] kernel read area: addr: 00023C00 len: 0400
[01:09:56.143] kernel read area: addr: 00024000 len: 0400
[01:09:56.354] kernel read area: addr: 00024400 len: 0400
[01:09:56.564] kernel read area: addr: 00024800 len: 0400
[01:09:56.774] kernel read area: addr: 00024C00 len: 0400
[01:09:56.974] kernel read area: addr: 00025000 len: 0400
[01:09:57.175] kernel read area: addr: 00025400 len: 0400
[01:09:57.395] kernel read area: addr: 00025800 len: 0400
[01:09:57.605] kernel read area: addr: 00025C00 len: 0400
[01:09:57.826] kernel read area: addr: 00026000 len: 0400
[01:09:58.036] kernel read area: addr: 00026400 len: 0400
[01:09:58.266] kernel read area: addr: 00026800 len: 0400
[01:09:58.467] kernel read area: addr: 00026C00 len: 0400
[01:09:58.697] kernel read area: addr: 00027000 len: 0400
[01:09:58.907] kernel read area: addr: 00027400 len: 0400
[01:09:59.107] kernel read area: addr: 00027800 len: 0400
[01:09:59.318] kernel read area: addr: 00027C00 len: 0400
[01:09:59.538] kernel read area: addr: 00028000 len: 0400
[01:09:59.778] kernel read area: addr: 00028400 len: 0400
[01:09:59.999] kernel read area: addr: 00028800 len: 0400
[01:10:00.209] kernel read area: addr: 00028C00 len: 0400
[01:10:00.439] kernel read area: addr: 00029000 len: 0400
[01:10:00.650] kernel read area: addr: 00029400 len: 0400
[01:10:00.860] kernel read area: addr: 00029800 len: 0400
[01:10:01.060] kernel read area: addr: 00029C00 len: 0400
[01:10:01.301] kernel read area: addr: 0002A000 len: 0400
[01:10:01.511] kernel read area: addr: 0002A400 len: 0400
[01:10:01.711] kernel read area: addr: 0002A800 len: 0400
[01:10:01.922] kernel read area: addr: 0002AC00 len: 0400
[01:10:02.122] kernel read area: addr: 0002B000 len: 0400
[01:10:02.322] kernel read area: addr: 0002B400 len: 0400
[01:10:02.542] kernel read area: addr: 0002B800 len: 0400
[01:10:02.753] kernel read area: addr: 0002BC00 len: 0400
[01:10:02.953] kernel read area: addr: 0002C000 len: 0400
[01:10:03.163] kernel read area: addr: 0002C400 len: 0400
[01:10:03.384] kernel read area: addr: 0002C800 len: 0400
[01:10:03.604] kernel read area: addr: 0002CC00 len: 0400
[01:10:03.804] kernel read area: addr: 0002D000 len: 0400
[01:10:04.015] kernel read area: addr: 0002D400 len: 0400
[01:10:04.245] kernel read area: addr: 0002D800 len: 0400
[01:10:04.455] kernel read area: addr: 0002DC00 len: 0400
[01:10:04.665] kernel read area: addr: 0002E000 len: 0400
[01:10:04.876] kernel read area: addr: 0002E400 len: 0400
[01:10:05.096] kernel read area: addr: 0002E800 len: 0400
[01:10:05.306] kernel read area: addr: 0002EC00 len: 0400
[01:10:05.517] kernel read area: addr: 0002F000 len: 0400
[01:10:05.707] kernel read area: addr: 0002F400 len: 0400
[01:10:05.927] kernel read area: addr: 0002F800 len: 0400
[01:10:06.138] kernel read area: addr: 0002FC00 len: 0400
[01:10:06.358] kernel read area: addr: 00030000 len: 0400
[01:10:06.558] kernel read area: addr: 00030400 len: 0400
[01:10:06.799] kernel read area: addr: 00030800 len: 0400
[01:10:07.009] kernel read area: addr: 00030C00 len: 0400
[01:10:07.219] kernel read area: addr: 00031000 len: 0400
[01:10:07.449] kernel read area: addr: 00031400 len: 0400
[01:10:07.680] kernel read area: addr: 00031800 len: 0400
[01:10:07.890] kernel read area: addr: 00031C00 len: 0400
[01:10:08.130] kernel read area: addr: 00032000 len: 0400
[01:10:08.331] kernel read area: addr: 00032400 len: 0400
[01:10:08.551] kernel read area: addr: 00032800 len: 0400
[01:10:08.771] kernel read area: addr: 00032C00 len: 0400
[01:10:08.982] kernel read area: addr: 00033000 len: 0400
[01:10:09.192] kernel read area: addr: 00033400 len: 0400
[01:10:09.402] kernel read area: addr: 00033800 len: 0400
[01:10:09.643] kernel read area: addr: 00033C00 len: 0400
[01:10:09.833] kernel read area: addr: 00034000 len: 0400
[01:10:10.043] kernel read area: addr: 00034400 len: 0400
[01:10:10.274] kernel read area: addr: 00034800 len: 0400
[01:10:10.494] kernel read area: addr: 00034C00 len: 0400
[01:10:10.714] kernel read area: addr: 00035000 len: 0400
[01:10:10.935] kernel read area: addr: 00035400 len: 0400
[01:10:11.165] kernel read area: addr: 00035800 len: 0400
[01:10:11.385] kernel read area: addr: 00035C00 len: 0400
[01:10:11.615] kernel read area: addr: 00036000 len: 0400
[01:10:11.816] kernel read area: addr: 00036400 len: 0400
[01:10:12.026] kernel read area: addr: 00036800 len: 0400
[01:10:12.226] kernel read area: addr: 00036C00 len: 0400
[01:10:12.447] kernel read area: addr: 00037000 len: 0400
[01:10:12.657] kernel read area: addr: 00037400 len: 0400
[01:10:12.887] kernel read area: addr: 00037800 len: 0400
[01:10:13.098] kernel read area: addr: 00037C00 len: 0400
[01:10:13.318] kernel read area: addr: 00038000 len: 0400
[01:10:13.528] kernel read area: addr: 00038400 len: 0400
[01:10:13.759] kernel read area: addr: 00038800 len: 0400
[01:10:13.969] kernel read area: addr: 00038C00 len: 0400
[01:10:14.179] kernel read area: addr: 00039000 len: 0400
[01:10:14.410] kernel read area: addr: 00039400 len: 0400
[01:10:14.640] kernel read area: addr: 00039800 len: 0400
[01:10:14.840] kernel read area: addr: 00039C00 len: 0400
[01:10:15.050] kernel read area: addr: 0003A000 len: 0400
[01:10:15.251] kernel read area: addr: 0003A400 len: 0400
[01:10:15.461] kernel read area: addr: 0003A800 len: 0400
[01:10:15.671] kernel read area: addr: 0003AC00 len: 0400
[01:10:15.882] kernel read area: addr: 0003B000 len: 0400
[01:10:16.092] kernel read area: addr: 0003B400 len: 0400
[01:10:16.292] kernel read area: addr: 0003B800 len: 0400
[01:10:16.533] kernel read area: addr: 0003BC00 len: 0400
[01:10:16.763] kernel read area: addr: 0003C000 len: 0400
[01:10:16.953] kernel read area: addr: 0003C400 len: 0400
[01:10:17.153] kernel read area: addr: 0003C800 len: 0400
[01:10:17.354] kernel read area: addr: 0003CC00 len: 0400
[01:10:17.564] kernel read area: addr: 0003D000 len: 0400
[01:10:17.784] kernel read area: addr: 0003D400 len: 0400
[01:10:18.005] kernel read area: addr: 0003D800 len: 0400
[01:10:18.215] kernel read area: addr: 0003DC00 len: 0400
[01:10:18.455] kernel read area: addr: 0003E000 len: 0400
[01:10:18.666] kernel read area: addr: 0003E400 len: 0400
[01:10:18.886] kernel read area: addr: 0003E800 len: 0400
[01:10:19.126] kernel read area: addr: 0003EC00 len: 0400
[01:10:19.327] kernel read area: addr: 0003F000 len: 0400
[01:10:19.557] kernel read area: addr: 0003F400 len: 0400
[01:10:19.787] kernel read area: addr: 0003F800 len: 0400
[01:10:20.028] kernel read area: addr: 0003FC00 len: 0400
[01:10:20.238] kernel read area: addr: 00040000 len: 0400
[01:10:20.438] kernel read area: addr: 00040400 len: 0400
[01:10:20.648] kernel read area: addr: 00040800 len: 0400
[01:10:20.849] kernel read area: addr: 00040C00 len: 0400
[01:10:21.049] kernel read area: addr: 00041000 len: 0400
[01:10:21.259] kernel read area: addr: 00041400 len: 0400
[01:10:21.500] kernel read area: addr: 00041800 len: 0400
[01:10:21.700] kernel read area: addr: 00041C00 len: 0400
[01:10:21.910] kernel read area: addr: 00042000 len: 0400
[01:10:22.121] kernel read area: addr: 00042400 len: 0400
[01:10:22.361] kernel read area: addr: 00042800 len: 0400
[01:10:22.571] kernel read area: addr: 00042C00 len: 0400
[01:10:22.812] kernel read area: addr: 00043000 len: 0400
[01:10:23.022] kernel read area: addr: 00043400 len: 0400
[01:10:23.242] kernel read area: addr: 00043800 len: 0400
[01:10:23.453] kernel read area: addr: 00043C00 len: 0400
[01:10:23.683] kernel read area: addr: 00044000 len: 0400
[01:10:23.893] kernel read area: addr: 00044400 len: 0400
[01:10:24.133] kernel read area: addr: 00044800 len: 0400
[01:10:24.334] kernel read area: addr: 00044C00 len: 0400
[01:10:24.544] kernel read area: addr: 00045000 len: 0400
[01:10:24.744] kernel read area: addr: 00045400 len: 0400
[01:10:24.945] kernel read area: addr: 00045800 len: 0400
[01:10:25.165] kernel read area: addr: 00045C00 len: 0400
[01:10:25.385] kernel read area: addr: 00046000 len: 0400
[01:10:25.586] kernel read area: addr: 00046400 len: 0400
[01:10:25.826] kernel read area: addr: 00046800 len: 0400
[01:10:26.026] kernel read area: addr: 00046C00 len: 0400
[01:10:26.226] kernel read area: addr: 00047000 len: 0400
[01:10:26.437] kernel read area: addr: 00047400 len: 0400
[01:10:26.677] kernel read area: addr: 00047800 len: 0400
[01:10:26.877] kernel read area: addr: 00047C00 len: 0400
[01:10:27.118] kernel read area: addr: 00048000 len: 0400
[01:10:27.338] kernel read area: addr: 00048400 len: 0400
[01:10:27.558] kernel read area: addr: 00048800 len: 0400
[01:10:27.759] kernel read area: addr: 00048C00 len: 0400
[01:10:27.979] kernel read area: addr: 00049000 len: 0400
[01:10:28.219] kernel read area: addr: 00049400 len: 0400
[01:10:28.450] kernel read area: addr: 00049800 len: 0400
[01:10:28.660] kernel read area: addr: 00049C00 len: 0400
[01:10:28.860] kernel read area: addr: 0004A000 len: 0400
[01:10:29.081] kernel read area: addr: 0004A400 len: 0400
[01:10:29.301] kernel read area: addr: 0004A800 len: 0400
[01:10:29.501] kernel read area: addr: 0004AC00 len: 0400
[01:10:29.732] kernel read area: addr: 0004B000 len: 0400
[01:10:29.952] kernel read area: addr: 0004B400 len: 0400
[01:10:30.172] kernel read area: addr: 0004B800 len: 0400
[01:10:30.392] kernel read area: addr: 0004BC00 len: 0400
[01:10:30.623] kernel read area: addr: 0004C000 len: 0400
[01:10:30.863] kernel read area: addr: 0004C400 len: 0400
[01:10:31.073] kernel read area: addr: 0004C800 len: 0400
[01:10:31.284] kernel read area: addr: 0004CC00 len: 0400
[01:10:31.514] kernel read area: addr: 0004D000 len: 0400
[01:10:31.744] kernel read area: addr: 0004D400 len: 0400
[01:10:31.975] kernel read area: addr: 0004D800 len: 0400
[01:10:32.195] kernel read area: addr: 0004DC00 len: 0400
[01:10:32.395] kernel read area: addr: 0004E000 len: 0400
[01:10:32.616] kernel read area: addr: 0004E400 len: 0400
[01:10:32.836] kernel read area: addr: 0004E800 len: 0400
[01:10:33.046] kernel read area: addr: 0004EC00 len: 0400
[01:10:33.247] kernel read area: addr: 0004F000 len: 0400
[01:10:33.467] kernel read area: addr: 0004F400 len: 0400
[01:10:33.697] kernel read area: addr: 0004F800 len: 0400
[01:10:33.898] kernel read area: addr: 0004FC00 len: 0400
[01:10:34.118] kernel read area: addr: 00050000 len: 0400
[01:10:34.328] kernel read area: addr: 00050400 len: 0400
[01:10:34.548] kernel read area: addr: 00050800 len: 0400
[01:10:34.769] kernel read area: addr: 00050C00 len: 0400
[01:10:34.979] kernel read area: addr: 00051000 len: 0400
[01:10:35.199] kernel read area: addr: 00051400 len: 0400
[01:10:35.420] kernel read area: addr: 00051800 len: 0400
[01:10:35.620] kernel read area: addr: 00051C00 len: 0400
[01:10:35.850] kernel read area: addr: 00052000 len: 0400
[01:10:36.061] kernel read area: addr: 00052400 len: 0400
[01:10:36.261] kernel read area: addr: 00052800 len: 0400
[01:10:36.471] kernel read area: addr: 00052C00 len: 0400
[01:10:36.712] kernel read area: addr: 00053000 len: 0400
[01:10:36.952] kernel read area: addr: 00053400 len: 0400
[01:10:37.172] kernel read area: addr: 00053800 len: 0400
[01:10:37.383] kernel read area: addr: 00053C00 len: 0400
[01:10:37.583] kernel read area: addr: 00054000 len: 0400
[01:10:37.813] kernel read area: addr: 00054400 len: 0400
[01:10:38.043] kernel read area: addr: 00054800 len: 0400
[01:10:38.254] kernel read area: addr: 00054C00 len: 0400
[01:10:38.484] kernel read area: addr: 00055000 len: 0400
[01:10:38.704] kernel read area: addr: 00055400 len: 0400
[01:10:38.915] kernel read area: addr: 00055800 len: 0400
[01:10:39.105] kernel read area: addr: 00055C00 len: 0400
[01:10:39.325] kernel read area: addr: 00056000 len: 0400
[01:10:39.526] kernel read area: addr: 00056400 len: 0400
[01:10:39.756] kernel read area: addr: 00056800 len: 0400
[01:10:39.966] kernel read area: addr: 00056C00 len: 0400
[01:10:40.207] kernel read area: addr: 00057000 len: 0400
[01:10:40.417] kernel read area: addr: 00057400 len: 0400
[01:10:40.627] kernel read area: addr: 00057800 len: 0400
[01:10:40.858] kernel read area: addr: 00057C00 len: 0400
[01:10:41.068] kernel read area: addr: 00058000 len: 0400
[01:10:41.278] kernel read area: addr: 00058400 len: 0400
[01:10:41.488] kernel read area: addr: 00058800 len: 0400
[01:10:41.709] kernel read area: addr: 00058C00 len: 0400
[01:10:41.939] kernel read area: addr: 00059000 len: 0400
[01:10:42.149] kernel read area: addr: 00059400 len: 0400
[01:10:42.360] kernel read area: addr: 00059800 len: 0400
[01:10:42.560] kernel read area: addr: 00059C00 len: 0400
[01:10:42.790] kernel read area: addr: 0005A000 len: 0400
[01:10:42.981] kernel read area: addr: 0005A400 len: 0400
[01:10:43.181] kernel read area: addr: 0005A800 len: 0400
[01:10:43.401] kernel read area: addr: 0005AC00 len: 0400
[01:10:43.622] kernel read area: addr: 0005B000 len: 0400
[01:10:43.822] kernel read area: addr: 0005B400 len: 0400
[01:10:44.042] kernel read area: addr: 0005B800 len: 0400
[01:10:44.282] kernel read area: addr: 0005BC00 len: 0400
[01:10:44.523] kernel read area: addr: 0005C000 len: 0400
[01:10:44.723] kernel read area: addr: 0005C400 len: 0400
[01:10:44.933] kernel read area: addr: 0005C800 len: 0400
[01:10:45.134] kernel read area: addr: 0005CC00 len: 0400
[01:10:45.334] kernel read area: addr: 0005D000 len: 0400
[01:10:45.554] kernel read area: addr: 0005D400 len: 0400
[01:10:45.775] kernel read area: addr: 0005D800 len: 0400
[01:10:45.985] kernel read area: addr: 0005DC00 len: 0400
[01:10:46.195] kernel read area: addr: 0005E000 len: 0400
[01:10:46.406] kernel read area: addr: 0005E400 len: 0400
[01:10:46.616] kernel read area: addr: 0005E800 len: 0400
[01:10:46.846] kernel read area: addr: 0005EC00 len: 0400
[01:10:47.076] kernel read area: addr: 0005F000 len: 0400
[01:10:47.277] kernel read area: addr: 0005F400 len: 0400
[01:10:47.497] kernel read area: addr: 0005F800 len: 0400
[01:10:47.707] kernel read area: addr: 0005FC00 len: 0400
[01:10:47.908] kernel read area: addr: 00060000 len: 0400
[01:10:48.128] kernel read area: addr: 00060400 len: 0400
[01:10:48.328] kernel read area: addr: 00060800 len: 0400
[01:10:48.539] kernel read area: addr: 00060C00 len: 0400
[01:10:48.739] kernel read area: addr: 00061000 len: 0400
[01:10:48.949] kernel read area: addr: 00061400 len: 0400
[01:10:49.149] kernel read area: addr: 00061800 len: 0400
[01:10:49.380] kernel read area: addr: 00061C00 len: 0400
[01:10:49.590] kernel read area: addr: 00062000 len: 0400
[01:10:49.830] kernel read area: addr: 00062400 len: 0400
[01:10:50.031] kernel read area: addr: 00062800 len: 0400
[01:10:50.241] kernel read area: addr: 00062C00 len: 0400
[01:10:50.451] kernel read area: addr: 00063000 len: 0400
[01:10:50.652] kernel read area: addr: 00063400 len: 0400
[01:10:50.872] kernel read area: addr: 00063800 len: 0400
[01:10:51.082] kernel read area: addr: 00063C00 len: 0400
[01:10:51.303] kernel read area: addr: 00064000 len: 0400
[01:10:51.513] kernel read area: addr: 00064400 len: 0400
[01:10:51.743] kernel read area: addr: 00064800 len: 0400
[01:10:51.964] kernel read area: addr: 00064C00 len: 0400
[01:10:52.194] kernel read area: addr: 00065000 len: 0400
[01:10:52.394] kernel read area: addr: 00065400 len: 0400
[01:10:52.594] kernel read area: addr: 00065800 len: 0400
[01:10:52.825] kernel read area: addr: 00065C00 len: 0400
[01:10:53.025] kernel read area: addr: 00066000 len: 0400
[01:10:53.235] kernel read area: addr: 00066400 len: 0400
[01:10:53.446] kernel read area: addr: 00066800 len: 0400
[01:10:53.686] kernel read area: addr: 00066C00 len: 0400
[01:10:53.886] kernel read area: addr: 00067000 len: 0400
[01:10:54.087] kernel read area: addr: 00067400 len: 0400
[01:10:54.307] kernel read area: addr: 00067800 len: 0400
[01:10:54.507] kernel read area: addr: 00067C00 len: 0400
[01:10:54.717] kernel read area: addr: 00068000 len: 0400
[01:10:54.948] kernel read area: addr: 00068400 len: 0400
[01:10:55.178] kernel read area: addr: 00068800 len: 0400
[01:10:55.388] kernel read area: addr: 00068C00 len: 0400
[01:10:55.599] kernel read area: addr: 00069000 len: 0400
[01:10:55.789] kernel read area: addr: 00069400 len: 0400
[01:10:56.009] kernel read area: addr: 00069800 len: 0400
[01:10:56.210] kernel read area: addr: 00069C00 len: 0400
[01:10:56.440] kernel read area: addr: 0006A000 len: 0400
[01:10:56.650] kernel read area: addr: 0006A400 len: 0400
[01:10:56.851] kernel read area: addr: 0006A800 len: 0400
[01:10:57.061] kernel read area: addr: 0006AC00 len: 0400
[01:10:57.261] kernel read area: addr: 0006B000 len: 0400
[01:10:57.471] kernel read area: addr: 0006B400 len: 0400
[01:10:57.712] kernel read area: addr: 0006B800 len: 0400
[01:10:57.912] kernel read area: addr: 0006BC00 len: 0400
[01:10:58.122] kernel read area: addr: 0006C000 len: 0400
[01:10:58.333] kernel read area: addr: 0006C400 len: 0400
[01:10:58.563] kernel read area: addr: 0006C800 len: 0400
[01:10:58.763] kernel read area: addr: 0006CC00 len: 0400
[01:10:58.974] kernel read area: addr: 0006D000 len: 0400
[01:10:59.184] kernel read area: addr: 0006D400 len: 0400
[01:10:59.384] kernel read area: addr: 0006D800 len: 0400
[01:10:59.604] kernel read area: addr: 0006DC00 len: 0400
[01:10:59.815] kernel read area: addr: 0006E000 len: 0400
[01:11:00.015] kernel read area: addr: 0006E400 len: 0400
[01:11:00.235] kernel read area: addr: 0006E800 len: 0400
[01:11:00.436] kernel read area: addr: 0006EC00 len: 0400
[01:11:00.646] kernel read area: addr: 0006F000 len: 0400
[01:11:00.866] kernel read area: addr: 0006F400 len: 0400
[01:11:01.067] kernel read area: addr: 0006F800 len: 0400
[01:11:01.297] kernel read area: addr: 0006FC00 len: 0400
[01:11:01.497] kernel read area: addr: 00070000 len: 0400
[01:11:01.718] kernel read area: addr: 00070400 len: 0400
[01:11:01.928] kernel read area: addr: 00070800 len: 0400
[01:11:02.128] kernel read area: addr: 00070C00 len: 0400
[01:11:02.358] kernel read area: addr: 00071000 len: 0400
[01:11:02.559] kernel read area: addr: 00071400 len: 0400
[01:11:02.769] kernel read area: addr: 00071800 len: 0400
[01:11:02.969] kernel read area: addr: 00071C00 len: 0400
[01:11:03.170] kernel read area: addr: 00072000 len: 0400
[01:11:03.390] kernel read area: addr: 00072400 len: 0400
[01:11:03.590] kernel read area: addr: 00072800 len: 0400
[01:11:03.791] kernel read area: addr: 00072C00 len: 0400
[01:11:04.001] kernel read area: addr: 00073000 len: 0400
[01:11:04.211] kernel read area: addr: 00073400 len: 0400
[01:11:04.421] kernel read area: addr: 00073800 len: 0400
[01:11:04.622] kernel read area: addr: 00073C00 len: 0400
[01:11:04.832] kernel read area: addr: 00074000 len: 0400
[01:11:05.042] kernel read area: addr: 00074400 len: 0400
[01:11:05.253] kernel read area: addr: 00074800 len: 0400
[01:11:05.473] kernel read area: addr: 00074C00 len: 0400
[01:11:05.703] kernel read area: addr: 00075000 len: 0400
[01:11:05.904] kernel read area: addr: 00075400 len: 0400
[01:11:06.124] kernel read area: addr: 00075800 len: 0400
[01:11:06.344] kernel read area: addr: 00075C00 len: 0400
[01:11:06.575] kernel read area: addr: 00076000 len: 0400
[01:11:06.795] kernel read area: addr: 00076400 len: 0400
[01:11:07.025] kernel read area: addr: 00076800 len: 0400
[01:11:07.235] kernel read area: addr: 00076C00 len: 0400
[01:11:07.466] kernel read area: addr: 00077000 len: 0400
[01:11:07.676] kernel read area: addr: 00077400 len: 0400
[01:11:07.886] kernel read area: addr: 00077800 len: 0400
[01:11:08.097] kernel read area: addr: 00077C00 len: 0400
[01:11:08.297] kernel read area: addr: 00078000 len: 0400
[01:11:08.517] kernel read area: addr: 00078400 len: 0400
[01:11:08.748] kernel read area: addr: 00078800 len: 0400
[01:11:08.988] kernel read area: addr: 00078C00 len: 0400
[01:11:09.208] kernel read area: addr: 00079000 len: 0400
[01:11:09.429] kernel read area: addr: 00079400 len: 0400
[01:11:09.649] kernel read area: addr: 00079800 len: 0400
[01:11:09.859] kernel read area: addr: 00079C00 len: 0400
[01:11:10.050] kernel read area: addr: 0007A000 len: 0400
[01:11:10.270] kernel read area: addr: 0007A400 len: 0400
[01:11:10.470] kernel read area: addr: 0007A800 len: 0400
[01:11:10.680] kernel read area: addr: 0007AC00 len: 0400
[01:11:10.901] kernel read area: addr: 0007B000 len: 0400
[01:11:11.121] kernel read area: addr: 0007B400 len: 0400
[01:11:11.341] kernel read area: addr: 0007B800 len: 0400
[01:11:11.552] kernel read area: addr: 0007BC00 len: 0400
[01:11:11.762] kernel read area: addr: 0007C000 len: 0400
[01:11:11.982] kernel read area: addr: 0007C400 len: 0400
[01:11:12.203] kernel read area: addr: 0007C800 len: 0400
[01:11:12.423] kernel read area: addr: 0007CC00 len: 0400
[01:11:12.633] kernel read area: addr: 0007D000 len: 0400
[01:11:12.834] kernel read area: addr: 0007D400 len: 0400
[01:11:13.054] kernel read area: addr: 0007D800 len: 0400
[01:11:19.804] kernel read area: addr: 000BD800 len: 0400
[01:11:20.024] kernel read area: addr: 000BDC00 len: 0400
[01:11:20.254] kernel read area: addr: 000BE000 len: 0400
[01:11:20.454] kernel read area: addr: 000BE400 len: 0400
[01:11:20.665] kernel read area: addr: 000BE800 len: 0400
[01:11:20.865] kernel read area: addr: 000BEC00 len: 0400
[01:11:21.095] kernel read area: addr: 000BF000 len: 0400
[01:11:21.376] kernel read area: addr: 000C0000 len: 0400
[01:11:21.576] kernel read area: addr: 000C0400 len: 0400
[01:11:21.786] kernel read area: addr: 000C0800 len: 0400
[01:11:21.997] kernel read area: addr: 000C0C00 len: 0400
[01:11:22.217] kernel read area: addr: 000C1000 len: 0400
[01:11:22.437] kernel read area: addr: 000C1400 len: 0400
[01:11:22.648] kernel read area: addr: 000C1800 len: 0400
[01:11:22.858] kernel read area: addr: 000C1C00 len: 0400
[01:11:23.068] kernel read area: addr: 000C2000 len: 0400
[01:11:23.269] kernel read area: addr: 000C2400 len: 0400
[01:11:23.469] kernel read area: addr: 000C2800 len: 0400
[01:11:23.679] kernel read area: addr: 000C2C00 len: 0400
[01:11:23.899] kernel read area: addr: 000C3000 len: 0400
[01:11:24.090] kernel read area: addr: 000C3400 len: 0400
[01:11:24.300] kernel read area: addr: 000C3800 len: 0400
[01:11:24.530] kernel read area: addr: 000C3C00 len: 0400
[01:11:24.741] kernel read area: addr: 000C4000 len: 0400
[01:11:24.971] kernel read area: addr: 000C4400 len: 0400
[01:11:25.191] kernel read area: addr: 000C4800 len: 0400
[01:11:25.422] kernel read area: addr: 000C4C00 len: 0400
[01:11:25.652] kernel read area: addr: 000C5000 len: 0400
[01:11:25.862] kernel read area: addr: 000C5400 len: 0400
[01:11:26.093] kernel read area: addr: 000C5800 len: 0400
[01:11:26.323] kernel read area: addr: 000C5C00 len: 0400
[01:11:26.553] kernel read area: addr: 000C6000 len: 0400
[01:11:26.764] kernel read area: addr: 000C6400 len: 0400
[01:11:26.974] kernel read area: addr: 000C6800 len: 0400
[01:11:27.204] kernel read area: addr: 000C6C00 len: 0400
[01:11:27.435] kernel read area: addr: 000C7000 len: 0400
[01:11:27.645] kernel read area: addr: 000C7400 len: 0400
[01:11:27.865] kernel read area: addr: 000C7800 len: 0400
[01:11:28.065] kernel read area: addr: 000C7C00 len: 0400
[01:11:28.296] kernel read area: addr: 000C8000 len: 0400
[01:11:28.496] kernel read area: addr: 000C8400 len: 0400
[01:11:28.706] kernel read area: addr: 000C8800 len: 0400
[01:11:28.917] kernel read area: addr: 000C8C00 len: 0400
[01:11:29.147] kernel read area: addr: 000C9000 len: 0400
[01:11:29.357] kernel read area: addr: 000C9400 len: 0400
[01:11:29.578] kernel read area: addr: 000C9800 len: 0400
[01:11:29.808] kernel read area: addr: 000C9C00 len: 0400
[01:11:30.038] kernel read area: addr: 000CA000 len: 0400
[01:11:30.249] kernel read area: addr: 000CA400 len: 0400
[01:11:30.459] kernel read area: addr: 000CA800 len: 0400
[01:11:30.669] kernel read area: addr: 000CAC00 len: 0400
[01:11:30.889] kernel read area: addr: 000CB000 len: 0400
[01:11:31.110] kernel read area: addr: 000CB400 len: 0400
[01:11:31.320] kernel read area: addr: 000CB800 len: 0400
[01:11:31.550] kernel read area: addr: 000CBC00 len: 0400
[01:11:31.761] kernel read area: addr: 000CC000 len: 0400
[01:11:31.981] kernel read area: addr: 000CC400 len: 0400
[01:11:32.211] kernel read area: addr: 000CC800 len: 0400
[01:11:32.442] kernel read area: addr: 000CCC00 len: 0400
[01:11:32.672] kernel read area: addr: 000CD000 len: 0400
[01:11:32.872] kernel read area: addr: 000CD400 len: 0400
[01:11:33.103] kernel read area: addr: 000CD800 len: 0400
[01:11:33.313] kernel read area: addr: 000CDC00 len: 0400
[01:11:33.513] kernel read area: addr: 000CE000 len: 0400
[01:11:33.734] kernel read area: addr: 000CE400 len: 0400
[01:11:35.226] kernel read area: addr: 000DB800 len: 0400
[01:11:35.456] kernel read area: addr: 000DBC00 len: 0400
[01:11:35.676] kernel read area: addr: 000DC000 len: 0400
[01:11:35.887] kernel read area: addr: 000DC400 len: 0400
[01:11:36.407] kernel read area: addr: 000DF800 len: 0400
[01:11:39.782] kernel read area: addr: 000FF800 len: 0400
[01:11:39.983] kernel read area: addr: 000FFC00 len: 0400
Keener2.5
Postby merchgod » Thu Oct 12, 2006 11:17 am
So post up the rom, then! We would all like to see it.
merchgod
Postby ev8siv3 » Thu Oct 12, 2006 11:37 am
If the green connector was on the right side of the car, this would be a FXT/LGT/OXT.
ev8siv3
Postby Keener2.5 » Thu Oct 12, 2006 2:12 pm
ev8siv3 wrote:If the green connector was on the right side of the car, this would be a FXT/LGT/OXT.
The flash connectors were on the left side like they should be, this thing is definintely an STi. There was a random one wire plug hiding under the fuse box on the driver side that wasn't connected. I'll post a pic tonight as well as get the rom posted up.
Keener2.5
