Also, if you want to say, "Your wrong!" feel free, but you must offer a better solution if you do!
DEF SEG = 0
REM address of COM port (p)
REM Typical address
REM &H3F8 = COM1
REM &H2F8 = COM2
p = &H3F8
dllb = p + 0
dlhb = p + 1
ier = p + 1
fcr = p + 2
lcr = p + 3
mcr = p + 4
lsr = p + 5
REM clear buffers & enable FIFO
OUT fcr, 7
REM set baud rate 5
OUT lcr, (INP(lcr) OR 128)
OUT dllb, 0
OUT dlhb, 90
OUT lcr, (INP(lcr) AND 127)
lcrbits = INP(lcr)
REM set 7 data bits xxxxxx10
lcrbits = lcrbits OR 2
lcrbits = lcrbits AND (255 - 1)
REM set Odd parity xx001xxx
lcrbits = lcrbits OR 8
lcrbits = lcrbits AND (255 - 16)
lcrbits = lcrbits AND (255 - 32)
REM set 1 Stop bit xxxxx0xx
lcrbits = lcrbits AND (255 - 4)
REM set 0 (off) Break Enable x0xxxxxx
lcrbits = lcrbits AND (255 - 64)
OUT lcr, lcrbits
REM cancel interupts
OUT ier, 0
REM set MCR rts low(on logic 1 -v), dtr-high(off logic 0 +V)
OUT mcr, 1
REM clear buffer
PRINT "clear buffer"
DO
c = INP(lsr) AND 1
PRINT c
IF c > 0 THEN PRINT INP(p)
LOOP WHILE c > 0
PRINT "done"
REM wait for buffer to be clear b4 sending byte
DO
LOOP WHILE 0 = (INP(lsr) AND 64)
REM wait for serial buffer to be clear b4 changing baud rate
DO
REM set baud rate 9600
PRINT "Changing to 9600 baud"
OUT dllb, &H18
OUT dlhb, 0
REM set 8bit no parity
lcrbits = INP(lcr)
REM set 8 data bits xxxxxx11
lcrbits = lcrbits OR 3
REM set None parity xxxx0xxx
lcrbits = lcrbits AND (255 - 8)
OUT lcr, lcrbits
REM read byte if available
OUT &H3F8, &H80
OUT &H3F8, &H10
OUT &H3F8, &HF0
OUT &H3F8, &H1
OUT &H3F8, &HBF
OUT &H3F8, &H40
PRINT "reading response"
DO
IF (INP(lsr) AND 1) > 0 THEN PRINT HEX$(INP(p))
LOOP UNTIL INKEY$ = CHR$(27) ' wait for Escape key to be pressed
ENDDEF SEG = 0
REM Typical address
REM &H3F8 = COM1
REM &H2F8 = COM2
PRINT "Begin"
OPEN "data.txt" FOR OUTPUT AS #1
PRINT #1, "START OF FILE"
p = &H3F8
dllb = p + 0
dlhb = p + 1
ier = p + 1
fcr = p + 2
lcr = p + 3
mcr = p + 4
lsr = p + 5
OUT fcr, 7
REM set baud rate 5
OUT dllb, 0
OUT dlhb, 90
lcrbits = INP(lcr)
OUT lcr, lcrbits
OUT ier, 0
OUT mcr, 1
REM clear buffer
DO
c = INP(lsr) AND 1
PRINT c
LOOP WHILE c > 0
PRINT "done"
DO
OUT &H3F8, &H33
DELAY 2
DO
c = INP(lsr) AND 1
PRINT c
LOOP WHILE c > 0
PRINT "done"
OUT dllb, &H18
OUT dlhb, 0
lcrbits = INP(lcr)
OUT lcr, lcrbits
OUT &H3F8, &H80
OUT &H3F8, &H10
OUT &H3F8, &HF0
OUT &H3F8, &H01
OUT &H3F8, &HBF
OUT &H3F8, &H40
DO
IF (INP(lsr) AND 1) > 0 THEN PRINT #1, HEX$(INP(p))
CLOSE #1
END
Visceral wrote:I played around with this a bit more today, and ended up changing the code a bit. Code is listed below -- basically I had it send the 0x33 at 5 baud and do the logging to a file.
Here's the output I get in the text file (I've removed the "START OF FILE", and formated it for readability):
80 10 F0 01 BF 40
80 F0 10 39 FF A2 10 11 2E 12 49 51 06 73 FA CB
A6 2B 81 FE A8 00 00 00 60 CE D4 F8 B1 E4 80 00
00 00 00 00 00 00 DC 00 00 45 1E 30 C0 F0 20 00
00 40 FB 00 E1 00 00 00 00 00 00 00 F0 E5
I haven't tried any of the other Subaru Select Monitor Protocol commands yet.[/code]
CLS
DEF SEG = 0
REM Typical address
REM &H3F8 = COM1
REM &H2F8 = COM2
p = &H3F8
dllb = p + 0
dlhb = p + 1
ier = p + 1
fcr = p + 2
lcr = p + 3
mcr = p + 4
lsr = p + 5
REM set baud rate 4800
OUT dllb, &H18
OUT dlhb, 0
lcrbits = INP(lcr)
OUT lcr, lcrbits
REM send initialization string
REM 80 10(suby ecu) f0(diagnostic) 01(1 byte data) bf(euc init) 40(chksum)
OUT p, &H80
OUT p, &H10
OUT p, &HF0
OUT p, &H1
OUT p, &HBF
OUT p, &H40REM thank you colby for start tread on nasioc
REM thank you Visceral for help in programming
REM thank you numbles for find file subaruecu.htm
CLS
DEF SEG = 0
REM Typical address
REM &H3F8 = COM1
REM &H2F8 = COM2
OPEN "temp.txt" FOR OUTPUT AS #1
p = &H3F8
dllb = p + 0
dlhb = p + 1
ier = p + 1
fcr = p + 2
lcr = p + 3
mcr = p + 4
lsr = p + 5
OUT fcr, 7
OUT ier, 0
OUT mcr, 1
REM clear buffer
DO
c = INP(lsr) AND 1
PRINT c
LOOP WHILE c > 0
PRINT "done"
OUT dllb, &H18
OUT dlhb, 0
lcrbits = INP(lcr)
OUT lcr, lcrbits
OUT p, &H80
OUT p, &H10
OUT p, &HF0
OUT p, &H1
OUT p, &HBF
OUT p, &H40
PRINT "Hand shake and reading Ecu info (bf)"
PRINT "send 80 10 f0 01 bf 40"
PRINT "ecu reply:"
PRINT
l = &H44
i = l
pippo$ = ""
dato$ = ""
DO
dato = (INP(p))
COLOR (7)
REM colore x tipo centralina
IF (i < (l - 13) AND i > (l - 19)) THEN
COLOR (9)
pippo$ = pippo$ + " " + HEX$(dato)
END IF
REM colore xgli int
IF (i < (l - 46) AND i > (l - 50)) THEN
COLOR (5)
END IF
PRINT HEX$(dato); " ";
REM Byte 9--> to determinate parameter support
IF i = (l - 19) THEN byte9 = dato
IF i = (l - 20) THEN byte10 = dato
IF i = (l - 21) THEN byte11 = dato
IF i = (l - 22) THEN byte12 = dato
IF i = (l - 23) THEN byte13 = dato
IF i = (l - 24) THEN byte14 = dato
IF i = (l - 25) THEN byte15 = dato
IF i = (l - 26) THEN byte16 = dato
IF i = (l - 27) THEN byte17 = dato
IF i = (l - 28) THEN byte18 = dato
IF i = (l - 29) THEN byte19 = dato
IF i = (l - 30) THEN byte20 = dato
IF i = (l - 31) THEN byte21 = dato
IF i = (l - 32) THEN byte22 = dato
IF i = (l - 33) THEN byte23 = dato
IF i = (l - 34) THEN byte24 = dato
IF i = (l - 35) THEN byte25 = dato
IF i = (l - 36) THEN byte26 = dato
IF i = (l - 37) THEN byte27 = dato
IF i = (l - 38) THEN byte28 = dato
IF i = (l - 39) THEN byte29 = dato
IF i = (l - 40) THEN byte30 = dato
IF i = (l - 41) THEN byte31 = dato
REM a capo dopo 6 byte
IF i = (l - 5) THEN PRINT
REM a capo dopo altri 9
IF i = (l - (5 + 16)) THEN PRINT
IF i = (l - (5 + 16 + 16)) THEN PRINT
IF i = (l - (5 + 16 + 16 + 16)) THEN PRINT
i = i - 1
END IF
LOOP UNTIL INKEY$ = CHR$(27) OR i = 0' o fine stringa o Esc
PRINT
PRINT
PRINT " press esc to continue with other info"
DO
REM
PRINT
PRINT
PRINT " You have Subby and Ecu:"
PRINT pippo$
COLOR (9)
IF pippo$ = " 54 53 52 51 50" THEN PRINT " OlŠ (r) by Nemis"
IF pippo$ = " 16 44 50 3 5" THEN PRINT " turbo/wrx/gt 99/00 ae800/780"
IF pippo$ = " 16 4 69 4 5" THEN PRINT " STI5/6 99/00 af040"
IF pippo$ = " 16 4 96 6 5" THEN PRINT " P1ag340"
IF pippo$ = " 1b 44 58 5 5" THEN PRINT " wrx 01/02 af531 7555"
IF pippo$ = " 29 44 59 41 5" THEN PRINT " sti uk 01/02 ag820 2591"
IF pippo$ = " 18 42 10 7 5" THEN PRINT " legacy 2.5gx 02"
IF pippo$ = " 18 44 10 8 5" THEN PRINT " legacy 2.0gl 02"
IF pippo$ = " d 4 68 8 5" THEN PRINT " legacy b4 tt"
IF pippo$ = " 19 44 58 5 5" THEN PRINT " forester turbo S/gt00 ag050"
IF pippo$ = " 23 44 10 8 5" THEN PRINT " forester 2.0 gls 02"
IF pippo$ = " 1b 14 40 5 5" THEN PRINT " US wrx 01/02 af423"
IF pippo$ = " 1e 12 0 7 5" THEN PRINT " 2,5 rs af581"
IF pippo$ = " 26 54 78 61 5" THEN PRINT " libetry b4 tt ag850 3382"
IF pippo$ = " 36 14 48 61 5" THEN PRINT " us wrx manual 03 aj030 5692"
IF pippo$ = " 29 44 59 61 5" THEN PRINT " STI uk 01/02 ag820/ag821"
IF pippo$ = " 2e 44 59 41 5" THEN PRINT " STI uk 03 ah990 5512"
IF pippo$ = " 23 12 49 51 6" THEN PRINT " us 2,5 sti 04 aj241"
IF pippo$ = " 2f 4 78 52 6" THEN PRINT " leg jap twins ah111 5646"
COLOR (7)
PRINT
DO
REM
CLS
PRINT " Parameter allowed:"
PRINT
IF INT(byte9 / 2) <> (byte9 / 2) THEN
PRINT "Engine speed"
byte9 = byte9 - 1
END IF
IF INT(byte9 / 4) <> (byte9 / 4) THEN
PRINT "Manifold Absolute Pressure"
byte9 = byte9 - 2
END IF
IF INT(byte9 / 8) <> (byte9 / 8) THEN
PRINT "Air/Fuel Learning #2"
byte9 = byte9 - 4
END IF
IF INT(byte9 / 16) <> (byte9 / 16) THEN
PRINT "Air/Fuel Correction #2"
byte9 = byte9 - 8
END IF
IF INT(byte9 / 32) <> (byte9 / 32) THEN
PRINT "Air/fuel Learning #1"
byte9 = byte9 - 16
END IF
IF INT(byte9 / 64) <> (byte9 / 64) THEN
PRINT "Air Fuel Correction #1"
byte9 = byte9 - 32
END IF
IF INT(byte9 / 128) <> (byte9 / 128) THEN
PRINT "Coolant Temperature"
byte9 = byte9 - 64
END IF
IF INT(byte9 / 256) <> (byte9 / 256) THEN
PRINT "Engine load"
END IF
REM print parameter allowed by byte10
PRINT
IF INT(byte10 / 2) <> (byte10 / 2) THEN
PRINT "Front O2 Sensor #2"
byte10 = byte10 - 1
END IF
IF INT(byte10 / 4) <> (byte10 / 4) THEN
PRINT "Rear O2 Sensor"
byte10 = byte10 - 2
END IF
IF INT(byte10 / 8) <> (byte10 / 8) THEN
PRINT "Front O2 Sensor #1"
byte10 = byte10 - 4
END IF
IF INT(byte10 / 16) <> (byte10 / 16) THEN
PRINT "Throttle Opening Angle"
byte10 = byte10 - 8
END IF
IF INT(byte10 / 32) <> (byte10 / 32) THEN
PRINT "Mass Air Flow"
byte10 = byte10 - 16
END IF
IF INT(byte10 / 64) <> (byte10 / 64) THEN
PRINT "Intake Air Temperature"
byte10 = byte10 - 32
END IF
IF INT(byte10 / 128) <> (byte10 / 128) THEN
PRINT "Ignition Timing"
byte10 = byte10 - 64
END IF
IF INT(byte10 / 256) <> (byte10 / 256) THEN
PRINT "Vehicle Speed"
END IF
REM print parameter allowed by byte11
PRINT
IF INT(byte11 / 2) <> (byte11 / 2) THEN
PRINT "Atmospheric Pressure"
byte11 = byte11 - 1
END IF
IF INT(byte11 / 4) <> (byte11 / 4) THEN
PRINT "Knock Correction"
byte11 = byte11 - 2
END IF
IF INT(byte11 / 8) <> (byte11 / 8) THEN
PRINT "Fuel Injection #2 Pulse Width"
byte11 = byte11 - 4
END IF
IF INT(byte11 / 16) <> (byte11 / 16) THEN
PRINT "Fuel Injection #1 Pulse Width"
byte11 = byte11 - 8
END IF
IF INT(byte11 / 32) <> (byte11 / 32) THEN
PRINT "Differential Pressure Sensor Voltage"
byte11 = byte11 - 16
END IF
IF INT(byte11 / 64) <> (byte11 / 64) THEN
PRINT "Throttle Sensor Voltage"
byte11 = byte11 - 32
END IF
IF INT(byte11 / 128) <> (byte11 / 128) THEN
PRINT "Air Flow Sensor Voltage"
byte11 = byte11 - 64
END IF
IF INT(byte11 / 256) <> (byte11 / 256) THEN
PRINT "Battery Voltage"
END IF
PRINT
PRINT " ....a lot of cut and paste to do :-( sorry no time"
PRINT
DO
REM
LOOP UNTIL INKEY$ = CHR$(27) ' o fine stringa o Esc
CLS
PRINT "Block Read: Read 128 bytes from address 0x200:000 (ecu returned all zeros)"
PRINT "80 10 f0 6 a0 0 20 0 0 7f c5"
REM Sent:
OUT p, &H80
OUT p, &H10
OUT p, &HF0
OUT p, &H6
OUT p, &HA0
OUT p, &H0
OUT p, &H20
OUT p, &H0
OUT p, &H0
OUT p, &H7F
OUT p, &HC5
l = 135
i = l
DO
PRINT HEX$(INP(p)); " ";
REM a capo dopo 5 byte di conferma
IF i = (l - 4) THEN PRINT
i = i - 1
END IF
PRINT
PRINT
PRINT
DO
REM
CLS
PRINT "live data read, engine speed 0f0e ignition 11 :"
PRINT " knock 12, dig63 knock sig,dig 64 crak,cam etc"
PRINT
REM 80 10 F0 14 A8 00 00 00 0F 00 00 0E 00 00 11 00 00 22 00 00 63 00 00 64 53
REM Sent:
OUT p, &H80
OUT p, &H10
OUT p, &HF0
OUT p, &H14
OUT p, &HA8
OUT p, &H0
OUT p, &H0
OUT p, &H0
OUT p, &HF
OUT p, &H0
OUT p, &H0
OUT p, &HE
OUT p, &H0
OUT p, &H0
OUT p, &H11
OUT p, &H0
OUT p, &H0
OUT p, &H22
OUT p, &H0
OUT p, &H0
OUT p, &H63
OUT p, &H0
OUT p, &H0
OUT p, &H64
OUT p, &H53
l = 12
i = l
dati$ = ""
dato = 0
COLOR (7)
DO
REM colore x dati
IF (i < (l - 4) AND i > 1) THEN
COLOR (9)
dati$ = dati$ + CHR$(i)
END IF
REM
i = i - 1
END IF
COLOR (7)
PRINT
PRINT
PRINT
DO
REM
CLS
ENDUsers browsing this forum: No registered users and 1 guest
