EVO5/6 MH7201F - MH7202F read/flash tool - it works.
Postby YP » Sun Jun 11, 2006 9:16 am
Hi All.
I am near finishing the project :). I cut the bootloader from Mitsu H8/539F CPU http://forums.openecu.org/viewtopic.php?t=394&highlight= and made some modifications.
Support Processors: MH7201FS, MH7202F, MH8302F.
Supported options: Read/Erase/Flash ECU.
I can't try it on EVO ECU - it's so rare in Russia, but I think it will be work on EVO's.
Now i have one problem. I ask cboles about OpenPort 1.3M schematics month ago, but i can't see anything :( . I build my own hardware based on 1.2 schematics with slight modification and DC/DC convertor addition. My software based on this hardware. Because many forum members already have 1.3M cable I want to adapt my soft to this cable, but i can't do this without schematics.
I will share my work for all after solving this question.
Regards, Dmitry.
YP
Postby JRSCCivic98 » Sun Jun 11, 2006 12:44 pm
Silly question, but doesn't ecuFlash have support for EVOs already?
Postby YP » Sun Jun 11, 2006 1:25 pm
JRSCCivic98 wrote:Silly question, but doesn't ecuFlash have support for EVOs already?
Not EVO5/6
http://openecu.org/index.php?title=EcuFlash:VehicleSupport
YP
Postby peluca » Sun Jun 11, 2006 1:58 pm
YP:
Can you post the EVO V ROM.
Thanks.
peluca
Postby GTODesign » Mon Jun 12, 2006 12:40 am
Hi Dmitry,
Fantastic work. I have 1.2 and 1.3M cables as well as access to various E5/6 ECU's, if you want me to test the software please let me know.
The modification you made to the 1.2, is it the initialization wire that connects to the second plug under the dash and runs to pin 73 (IIRC) on the E5/6 ECU's? I presume other models with the same processor use the same method of initialization?
What ECU/vehicles have you tested it on so far?
GTODesign
Postby YP » Mon Jun 12, 2006 2:07 am
YP:
Thanks.
I post it as far as I get access to EVO V car. :wink:
GTODesign wrote:Hi Dmitry,
I successfuly tested it on various MMC ECU with the MH7202F processor. I read out and flash Galant, Lancer, Carisma, Pajero engine ECU's and AT ECU's without any problems. I think it will be workable on EVO's, because hardware is the same.
I wait for a week for cboles reply about schematics, after that I post soft and my hardware shematics for all.
P.S. Thanks for EVO6 ROM. It helped me in ECU digging :)
YP
Postby NeverLies » Fri Jun 16, 2006 3:11 am
Good job ! Do you think this might work also for a MH7203F ? I have one ECU from this type and would like to try to extract rom ;)
Postby GTODesign » Fri Jun 16, 2006 4:04 am
MH720X all seem to be from the same H8 family so chances are yes.
GTODesign
Postby NeverLies » Fri Jun 16, 2006 8:24 am
Fine ;) YP, do you mind to share your code and the modifications done on the 1.2 openport ? My ECU is on my desk at this time, so DC/DC convertor should be useless right now, will use my lab power :D
Postby NeverLies » Mon Jun 26, 2006 3:39 am
Bump !
Any news YP ? I've sent u a PM.
Postby NeverLies » Tue Jul 11, 2006 5:02 am
Hi Dmitry ,
Did you get any news ? What's up with this reflash ? I want to try it on my ECU :D
Postby NeverLies » Tue Jul 25, 2006 3:00 am
Does anyone has any news from Dmitri ? I would like to test this app on another Mitsubishi ECU :(
Postby red^shark » Tue Aug 08, 2006 12:58 pm
Bump...
This may also include the 1998 and 1999 Eclipses and Talons
Red
red^shark
Re: EVO5/6 MH7201F - MH7202F read/flash tool - it works.
Postby RanEvo » Wed Aug 09, 2006 10:54 pm
Hi Dmitry,
Very good work! :D
I am looking to flash the Mitsubishi Outlander (Turbo), and I wonder if you can support its processor - MH8202F ? :?:
Ran
YP wrote:Hi All.
Regards, Dmitry.
RanEvo
Postby RanEvo » Wed Aug 09, 2006 11:21 pm
Hi Dmitry,
Very good work! :D
Ran
YP wrote:Hi All.
Regards, Dmitry.
RanEvo
