Problem fully reading 2006 sti ecu. Only gets ignition maps
Postby charles » Tue Jun 06, 2006 10:22 am
I read the cu on my completely, stock 2006 usdm sti and under parameters, all that is listed is ignition maps A and B. Nothing else.
I attached the rom file
06stibase.hex
2006 sti base file
(1 MiB) Downloaded 2367 times
charles
Postby x99percent » Tue Jun 06, 2006 12:45 pm
That's not a problem with the ROM... it's a problem with your XML description for the ROM. It's likely incomplete.
x99percent
Postby charles » Tue Jun 06, 2006 3:03 pm
Can you point me in the right direct in getting this fixed? Is there un update I need for the 06 STI?
charles
Postby x99percent » Tue Jun 06, 2006 4:27 pm
- Do more reading around this site
- Search for XMLWRITE
x99percent
Postby charles » Tue Jun 06, 2006 6:12 pm
Thanks for the direction. I believe I am starting to understand the problem. Is it correct to say that there is no XML for the 06 sti and basicall it has to be defined to reveal all the maps which are there , but I cannot see them because it is using an 05 sti to interpret?
charles
XML for 06 STI
Postby west_minist » Tue Jun 06, 2006 8:16 pm
Here you go.
A2ZJE11J.xml
(47.34 KiB) Downloaded 898 times
Postby sesso » Sun Jun 18, 2006 10:05 pm
where do i put the xml file . ? i oput it into the romdata under sti. and still get ignition maps only
sesso
Postby west_minist » Sun Jun 18, 2006 10:09 pm
what version of ecuedit you are using? Put it in the same folder as ecuedit, if you did not change the settings file.
Postby sesso » Sun Jun 18, 2006 11:30 pm
i am using ecuflash. will it not work with ecu flash? whats the version of ecuedit to use then? i use ecuflash for my evo so i dont know much about sti yet
sesso
Postby Freon » Mon Jun 19, 2006 5:49 am
The XMLs for Ecuflash are located in a subdirectory where you installed the program (I think default is c:\program files\openecu\ecuflash\).
Find the right directory and paste the file there.
Postby sesso » Mon Jun 19, 2006 9:16 am
I did that and it still wouldn't work.
sesso
Postby New2Scoobs » Tue Jun 20, 2006 6:25 am
sesso wrote:I did that and it still wouldn't work.
I think the XML file you have been supplied with is for the ECUEDIT program not the ECUFLASH program (judging by west_minists question)
one XML file is not compatible with all 3 programs (ECUEDIT, ECUFLASH, ENGINUITY) You have to have the one tailored for your program.
Postby sesso » Tue Jun 20, 2006 5:05 pm
ahh ok well whats the newest ecu edit?
sesso
Postby Freon » Wed Jun 21, 2006 8:09 am
Here is an XML for Ecuflash produced by xmlwrite:
http://freon.shackspace.com/car/ecu%20a ... ZJE11J.XML
And one for Ecuedit:
Latest Ecuedit:
http://freon.shackspace.com/car/ecu%20a ... _0_70b.zip
Personally I use Ecuedit. I can easily produce workable XML files with the XMLwrite utility for Ecuedit. I opened your ROM on my computer with Ecuedit and the above Ecuedit XML in the /XMLDefs folder where ecuedit.exe is and it works like a charm.
Postby sesso » Wed Jun 21, 2006 9:56 pm
its opening the test files above so im assuming its working... thanks guys :)
sesso
