JDM EcuFlash
Postby R. Mutt » Wed May 03, 2006 3:34 am
Have you had any luck with the reflash? I've been talking to this guy on evolutionm.com who is dealing with EcuFlash for evos. The cable is already out and he's taking orders...the software will be out soon. I'm thinking of buying the cable but waiting to find out if it works on jdm ecus. The site boasts that it does, but I want to confirm just in case cuz I find it hard to believe a US based guy was able to test out on evi VI and VII ecus
R. Mutt
Postby cboles » Wed May 03, 2006 10:20 am
[I moved your post, since it seemed not WRX related]
The cable is not quite out yet, but I will be shipping them to my customers and Jason by the end of the week. The cable / software will definitely work on JDM as well. Keep in mind the software only works with Evo 7/8 right now, but there will be complete support for EVO 5-9 in the near future. I developed the software and hardware using a number of sample ECUs, including a EVO 7 RalliArt, that I believe is JDM, although it may have been a world market unit. The point is, all of the Mitsu ECUs I have seen work the same way.
Postby GTODesign » Thu May 18, 2006 12:46 am
ECUFlash does work on JDM ECU's, tried and tested.
GTODesign
Postby iveytune » Fri May 26, 2006 7:10 am
I currently have a JDM evo 7 ecu MR 560648 EVO 7 GSR
Does anyone have the XML def for it?
Sean
iveytune
Postby GTODesign » Fri May 26, 2006 7:14 am
I expect this is internal ID EM9864?
What do you want to know? I have been working on this ROM for a while but don't use ECUFlash for editing so have never bothered writing an XML.
GTODesign
Postby iveytune » Fri May 26, 2006 7:22 am
Yes it's EM9864
Thanks.
Sean
iveytune
Postby burgers » Mon May 29, 2006 1:05 pm
Hi Sean
Have you had any luck getting an xml file for this ECU? I have the same ECU & can't match any of the current xml file addresses to the hex download from my ECU.
MB
burgers
Postby iveytune » Mon May 29, 2006 1:46 pm
Havent gotten the XML, I have been searching the code and comparing to the evo8 stuff and I can see all maps. Just trying to tie it all together.
Also waiting for help from a few people here and there.
Sean
iveytune
Postby burgers » Mon May 29, 2006 2:11 pm
Hi
What are you using to read the hex file? Any chance you could give the the offsets for the High Octaine fuel & ignition maps? Thanks
MB
burgers
Postby GTODesign » Tue May 30, 2006 12:19 am
burgers wrote:Hi
MB
Hi Oct F $35BD
Lo Oct F $36D7
Hi Oct Ig $3B85
Lo Oct Ig $3CF9
RPM scale F $5668
Load scale F $568E
RPM scale Ig $56BE
Load scale Ig $56EE
MAF scale (I think) $3977
GTODesign
Postby burgers » Tue May 30, 2006 12:34 pm
Hi GTO
Thanks for the help. The Hi/low octain addresses seemed spot on, 35bd gives me an AFR map, but the RPM & load scales didn't match my hex file.
From your post in the Evo6 thread above, I think I have -14 ECU. I have found an RPM map at 4fb4 & a load map at 4fda, I asume these are the correct ones for the Hi octain fuel map. Lets see what else I can find.
MB
burgers
Postby GTODesign » Tue May 30, 2006 11:53 pm
Sorry, those addresses are from EM9986 :oops: . Some of the addresses do vary from revision to revison.
I'll dig out the ROM later and confirm the scales.
GTODesign
Postby Evo4Mad » Wed May 31, 2006 4:35 am
any ideas on the correct values?
Postby burgers » Thu Jun 01, 2006 8:18 am
Hi
Here's my JDM Evo7 GSR Hex file & a small xml with the Hi/low octain fuel & ignition maps, Hex file name refects the ECU case numbers.
MB
4th June, found some more maps, changed xml name to match ECU internal ID. having trouble finding the anti lag maps & the knock filters.
98640014.xml
(4.93 KiB) Downloaded 1034 times
mr560648e6t34871.hex
(256 KiB) Downloaded 994 times
burgers
Postby iveytune » Thu Jun 01, 2006 6:58 pm
rev limiter 158C
Speed limit 158E
Boost cut delay timer 159A
Immobilizer 3ffce
Just to Add
Sean
iveytune
