Map offsets for 32bit SUBARU DENSO ECUs (DBW & NON-DBW)
Postby xswrex » Wed May 03, 2006 5:46 am
in the attachment you will find 3 seperate text files (1D,2D,3D) containing the various map offsets.
I will try to give an example how it is implemented:
offset=address in rom
[offset]=go to offset and read the actual value there
seek to [offset] to find the axis/data sizes and offsets
simple :wink:
xswrex
Postby twg » Wed May 03, 2006 6:55 am
THANK YOU!!!!
Now to translate this to XML files... Hmmm....
btw: I also noticed, for the USDM FXT, there are addresses in the 155XXX range... this is outside of the 512K address format, so I think the "1" in front of these addresses are typos... thoughts?
Lastly, I think it's missing some tables, such as following:
MAP Sensor Scaling - Pressure Offset
MAP Sensor Scaling - Voltage Multiplier
Mass Air Flow Reading Limit #1
Mass Air Flow Reading Limit #2
as well as ~6-10 2D tables...
twg
Postby WolfPlayer » Wed May 03, 2006 6:20 pm
This file is pretty amazing if the values are true and can be trusted. I was just asking about the '05 STI ... and wow, here it is.
I don't see the Injector Latency 2D map. But, still .... wow ... lots and lots of data there. Thank you so much for this post!!!
t
WolfPlayer
Postby xswrex » Wed May 03, 2006 9:59 pm
the ones i could verify from rom posts here seemed ok (e.g. STI 06). Without a rom i cannot crosscheck offsets :lol:
surely there will be missing maps, but i think these are good enough to get you started
xswrex
Postby xswrex » Thu May 04, 2006 12:39 am
this is what i have come up with so far
ROM STRUCTURE
3D
offset->
1x16bit cols count
1x16bit rows count
1x32bit cols offset
1x32bit rows offset
1x32bit data offfset
3x32bit values (scalings?)
2D
offset->
1x16bit rows count
1x16bit type?? (encountered so far 0x0000, 0x0400, 0x0800)
1x32bit rows offset
1x32bit data offset
2x32bit or 4x16bit values (starting value??, increase step value??) these are present only if type??<>0000
1D
offset is pointing directly to data
xswrex
Postby xswrex » Thu May 04, 2006 3:31 am
more usefull info
the expressions to real world numbers for the data are stored in the ROM!!!
i am working with the 06 eu STi rom and here are the findings:
Axis data seem to be 32bit
Ignition Base Map
Offset (hex):7C3B0
Col count:19
Col offs:828012 000CA26C
Row count:18
Row ofs:828088 000CA2B8
Data ofs:828160 000CA300
rest 3 32bit entries
0x04000000 8bit data values?
0.3515625000000000 3EB40000 THIS IS THE MULTIPLIER FOR THE DATA! LOOKS FAMILIAR!
-20.0000000000000000 C1A00000 THIS IS THE ADDITION FOR THE DATA!
and another
Initial Wastegate Duty D
Offset (hex):7A6C0
Col count:8
Col offs:789164 000C0AAC
Row count:10
Row ofs:789196 000C0ACC
Data ofs:789236 000C0AF4
0x08000000 16bit data values?
0.0039062500000000 3B800000
0.0000000000000000 00000000
and another
Max Wastegate Duty
Offset (hex):7A6F8
Col count:8
Col offs:789420 000C0BAC
Row count:10
Row ofs:789452 000C0BCC
Data ofs:789492 000C0BF4
8) 8) 8) 8) 8)
xswrex
Postby xswrex » Thu May 04, 2006 3:34 am
twg wrote:THANK YOU!!!!
be creative, ommit the 1 and use the rest of the address
xswrex
Postby swifty » Thu May 04, 2006 4:39 am
Which cars have a 32 bit ecu ?
swifty
Postby Hitokiri » Thu May 04, 2006 9:03 am
OMG!!!
I am sooo stoked!! thats amazing!
Postby cboles » Thu May 04, 2006 9:12 am
Nice work! I should be able to add good DBW maps to EcuFlash quickly now...
Postby Hitokiri » Thu May 04, 2006 4:07 pm
XMLWRITE V3!!!!!
Postby WolfPlayer » Thu May 04, 2006 6:49 pm
For those reading this and not quite following the address locations, here is a quick rundown ...
Get a hex editor and go to the address listed in the document for something (lets talk about a 3D table).
The first 2 bytes represent the number of columns in hex (convert to decimal)
The next 2 bytes represent the number of rows in hex (convert to decimal)
The next 4 bytes represent the address for where the column headers start (this is the column offset).
The next 4 bytes represent the address for where the row headers start (this is the row offset).
The next 4 bytes represent the address for where the actual data starts (this is the data offset).
WolfPlayer
Postby xswrex » Thu May 04, 2006 10:57 pm
struct2D :
rowcnt :2bytes Rows count
databits :2bytes Type of data (0=32bit,4=8bit,8=16 bit)
rowofs :4bytes Rows offset
datofs :4bytes Data offset
if databits <> 0x0000 (32bit data dont have scalings, this is strange....)
mult :4bytes Multiplier for data
add :4bytes Addition to data
struct3D :
colcnt :2bytes Cols count
colofs :4bytes Cols offset
databits :4bytes Type of data (0=32bit,4=8bit,8=16 bit)
The mult and add must be interpreted as floating point numbers (4byte single)
Expression for data in XML: [data]*mult+(add)
2 things remaining
find the axis scalings (if they are in there)
match map definitions to map names
xswrex
Postby New2Scoobs » Fri May 05, 2006 1:26 am
Again, which cars have a 32bit denso ECU?
Postby xswrex » Fri May 05, 2006 4:12 am
New2Scoobs wrote:Again, which cars have a 32bit denso ECU?
if it matters so much, if rom size is 512kb or 1024kb then it is 32bit
xswrex
