Mitsubishi H8/539F(MH7202)reading/flashing research started.
Postby YP » Tue Mar 28, 2006 1:45 am
Hi, All!
I read some topics on this site from people who want to read/flash old Mitsubishi ECU's. I become interested in this work.
First I made Kashima H8/ISP adapter and try to speak with CPU. CPU answers on requests, but I can't read flash because protection code has been set on ECU or I do something wrong :? . After Certification command (start with 0x00, 6 bytes engine code, 0x28, 0x0C) sended to ECU with clear engine coord/code, ECU lock connection after any 3 bytes sended and echoed to(from) ECU.
There are one way to understand how to read/flash it - read CPU in PROM programmer called "big pain" by Colby :) . So, i found InvecsII TCU from Mitsubishi Galant 98 with the same processor and ISP connector. Look at this - It's pure H8/539F! Mitsubishi use this in first ECU's and replace it with MH7202 after.
I made my QFP112->32pin adapter (H8/538 HW manual schematics)
Desolder CPU and solder it to adapter. Insert to PROM programmer.
Select HN28F101 and here is the code :D
NOW is a good time to learn how ISP boot program works. I am not experience in H8/500 assembler yet (I working with PIC on my job) and expect for help from members of this site to understand ISP protocol and engine coord/code location.
ROM Image in attachement from MD761737 MMC Galant TCU. I think it interesting only for reading/programming protocol information.
Regards, Dmitry.
YP
Postby Hitokiri » Tue Mar 28, 2006 4:21 am
sweeeeet!
Postby GTODesign » Wed Mar 29, 2006 12:11 am
Very impressive. Have you tried this with the MH7202 out of an E5/6 ECU yet?
GTODesign
Postby NeverLies » Tue Dec 05, 2006 4:13 am
Is there any update on your side ?
As there is no kernel available yet for H8/500 MCU, I think i will do same as you, dump content of the MCU using an EPROM programmer.
