2002 JDM WRX
2002 JDM WRX
Postby MichaelWRX » Sat Mar 04, 2006 1:05 pm
Hi guys,
I've had my WRX for about 2 months now and finally got a laptop borrowed to mess around with the OpenPort 1.2 cable and ecuExplorer.
So for I have done some datalogging, tried the adjust timing and adjust idle functions and all is well. The ECU is AF471-7086. I've found the IAM at 020118. My own only is only reading 10 though.
I can't seem to get the Read ECU Flash Memory function to work though. Under the dash has the 2 green connectors, 2 black connectors and one 2 wire white connector. I connected the 2 green ones together and shorted the 2 wires on the white connector but that is not working. Can anyone confirm if this function works on 02 JDM ECU's? And if so, am I following the right procedures?
Thanks,
Michael
MichaelWRX
Postby MichaelWRX » Sat Mar 04, 2006 1:24 pm
I figured out what I was doing wrong. I had the ignition on prior to connecting the green connectors. I started again with the ignition off, connected the green connectors, ignored the white connector, and then turned the ignition on and it worked.
AF471-7086.zip
MY02 Impreza 2.0 WRX (JDM) [AF471-7086]
(77.77 KiB) Downloaded 3739 times
MichaelWRX
Postby MichaelWRX » Sun Mar 19, 2006 3:42 pm
Is there a XML definition file for my ECU available as yet? If not is there a work-through to guide me how to create one?
On another note, here is a 3rd gear pull I logged using ecu Explorer. Any thoughts?
ecuExplorer AF471-7086 3rd gear.zip
3rd gear pull
(3.24 KiB) Downloaded 426 times
MichaelWRX
Postby west_minist » Sun Jun 04, 2006 5:06 am
Hey Michael!
I PM and added you to my msn.
How is the tuning coming along?
You need any help, since you are in my back yard? :)
How many Subaru's you have there?
I visited TT last year December for the first time and only saw 2 Subaru's in Port of Spain.
Who is beating up on you and who are you beating up on? :) :) :)
You ever heard of CommNett?
Postby MichaelWRX » Sun Jun 04, 2006 6:02 am
Added!
I haven't done any reflashing as yet. I've just been tpying with Enginuity trying to learn as much as I could first.
I've only had my WRX since December and I'm only now meeting some of the other owners here.
Let me know if you're ever in the area again!
MichaelWRX
