Help! Please advice.I made my Openport1.3U,but it can't work
Postby nakagamawa » Thu May 08, 2008 1:16 pm
1,When using My Openport 1.3U cable, EcuFlash LOG is ...
[22:54:48.149] Version 1.34.1435
[22:54:48.165] 11 memory models read.
[22:54:48.165] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[22:54:50.676] 220 ROM metadata models scanned.
[22:54:50.676] checksum module "subarudbw" loaded.
[22:54:50.676] flashing tool "wrx02" loaded.
[22:54:50.676] flashing tool "wrx04" loaded.
[22:54:50.676] flashing tool "sti04" loaded.
[22:54:50.676] flashing tool "sti05" loaded.
[22:54:50.676] flashing tool "mitsukernel" loaded.
[22:54:50.676] flashing tool "mitsukernelocp" loaded.
[22:54:50.676] flashing tool "shbootmode" loaded.
[22:55:27.024] Using interface OpenPort 1.3 Subaru TX47kC2u5e2975dd00000000000000000000000000000000
[22:55:27.024] interface close
[22:55:27.040] unable to connect to vehicle interface.
[22:55:27.040] interface close
2,When using Tactrix Openport1.3U cabe ,ECUFlash log is..
[23:02:21.762] Using interface OpenPort 1.3 Subaru TX47kC2ucfacb4d9e11668e28485f309b57cbd6c7aafe5f4
3,Question
What' wrong?
I can't make same eeprom data of FTDI232R(of my cable) by Mprog3.0 as TACTRIX's data.How do I make same eeprom data?[/img]
nakagamawa
Postby aorig » Fri May 16, 2008 3:07 pm
Ive got the same problem. Any info about this problem will be greatly appreciated.
aorig
Postby BoxerFan » Sat May 17, 2008 12:41 am
Try downgrading to ecuflash 1.29.
BoxerFan
Postby nakagamawa » Sun May 18, 2008 4:54 am
[quote="BoxerFan"]Try downgrading to ecuflash 1.29.[/quote]
Thank you.
I got EcuFlash 1.28,and I confirm.
[01:00:55.509] Version 1.28.716
[01:00:55.524] 8 memory models read.
[01:00:56.195] 71 ROM metadata models read.
[01:00:56.195] checksum module "subarudbw" loaded.
[01:00:56.195] flashing tool "wrx02" loaded.
[01:00:56.195] flashing tool "wrx04" loaded.
[01:00:56.195] flashing tool "sti04" loaded.
[01:00:56.195] flashing tool "sti05" loaded.
[01:00:56.195] flashing tool "mitsukernel" loaded.
[01:00:56.195] flashing tool "mitsukernelocp" loaded.
[01:00:56.195] flashing tool "mitsubootloader" loaded.
[01:01:29.392] ssm2_init
[01:01:29.579] ssm2_init
[01:01:29.782] ssm2_init
[01:01:29.985] ssm2_init
[01:01:30.188] ssm2_init
[01:01:30.390] ssm2_init
[01:01:30.578] ssm2_init
[01:01:30.796] ssm2_init
[01:01:30.999] ssm2_init
[01:01:31.186] ssm2_init
[01:01:31.545] kernel get version
[01:01:32.060] validating denso kernel ram area addr: FFFF6000 len: 0008
I found My cable response(log) is same as Tactrix's response(log).
Where can I get EcuFlash 1.29 ?
nakagamawa
Where can I get source code files(c++?) of EcuFlash ?
Postby nakagamawa » Sat Jul 05, 2008 2:10 pm
I think that EcuFlash v1.34 can't accept my OpenECU cable,because security code of it isn't match the security code of EcuFlash.
:?: Only Tactrix cable can be accepted.
EcuFlash v1.29 don't check the security code,so any OpenECU cale can be used.
Is EcuFlash Openspurce ?
nakagamawa
Re: Where can I get source code files(c++?) of EcuFlash ?
Postby Jon [in CT] » Sun Jul 06, 2008 11:26 am
nakagamawa wrote:I think that EcuFlash v1.34 can't accept my OpenECU cable,because security code of it isn't match the security code of EcuFlash.
Try programming your cable using the file attached to http://forums.openecu.org/viewtopic.php?p=18326#18326 and let us know whether that fixes your problem.
Postby BoxerFan » Mon Jul 07, 2008 11:09 pm
No wonder I could never get ecuFlash 1.3* to work with my cable, only 1.29 works for me. Didn't know ecuFlash does a cable security check. I wonder why it is checking... :( :(
BoxerFan
Postby nakagamawa » Wed Jul 16, 2008 4:06 am
[quote="Jon [in CT]"][quote="nakagamawa"]I think that EcuFlash v1.34 can't accept my OpenECU cable,because security code of it isn't match the security code of EcuFlash.
:?: Only Tactrix cable can be accepted.[/quote]Try programming your cable using the file attached to http://forums.openecu.org/viewtopic.php?p=18326#18326 and let us know whether that fixes your problem.[/quote]
Thank you for your replay.I tried your information,but v1.34 can't accept my OpenECU cable.Please see the attachnemt.Please see
I found that
All the cables are manufactured from the same company in china, between evoscan and tactrix cables. they are all genuine, you should download ecuflash and install it. and run v1.29 ecuflash, guaranteed to work on all cable configurations because v1.29 doesn't check the security keys. Both the EvoScan and Tactrix cables have encrypted keys loaded into them which can not be cloned as it is hardcoded to the physical microcontroller id, and you can not build your own cable to work with ecuflash, sorry, that was a design decision made by tactrix.com and limitless.co.nz to lock out competitors.
So,please teach me where can I found the source code of ECUFlash.
nakagamawa
