2004 STi ETC ROM AD3A101D AJ242
Postby cboles » Tue Feb 28, 2006 11:16 am
another ETC ROM...
2004stistock_AD3A101D_aj242.zip
(10.56 KiB) Downloaded 682 times
Postby AlanG » Fri Apr 21, 2006 7:21 am
stupid question 1: What does ETC mean?
stupid question 2: Is this file the equivalent to a "*_cpu.hex"?
AlanG
Postby cboles » Fri Apr 21, 2006 9:30 am
ETC = electronic throttle control
this is a second CPU in the Subaru DBW ECU that controls the throttle servo.
Postby AlanG » Fri Apr 21, 2006 10:20 am
cboles wrote:ETC = electronic throttle control
Thanks :wink:
AlanG
Postby DarkECU » Tue Apr 25, 2006 3:38 pm
<ecus>
<ecu_struct id="A2ZJ700J" type="aj242-7114 USSTI 2004">
<map name="53354 Pri Wastegate Duty AIT Comp." type="2" active="1">
<rows count="16" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000562C0" inc_value_offset="#3C000000" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#00056300" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="53368 Pri Wastegate Duty AIT Comp." type="2" active="1">
<rows count="16" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#00056310" inc_value_offset="#3C000000" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#00056350" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="5337C Pri Wastegate Cool Temp Comp" type="2" active="1">
<rows count="16" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#00056280" inc_value_offset="#3C000000" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#00056360" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="53390 Pri Wastegate Cool Temp Comp" type="2" active="1">
<data offset="#00056370" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="533A4 Desired Boost Cool Temp Comp" type="2" active="1">
<data offset="#00056380" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="533B8 Desired Boost Cool Temp Comp" type="2" active="1">
<data offset="#00056390" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="533CC Boost Atmo Comp RPM Constant" type="2" active="1">
<rows count="4" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000563A0" inc_value_offset="#3C800000" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000563B0" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="533E0 Boost Atmo Comp RPM Constant" type="2" active="1">
<rows count="4" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000563B4" inc_value_offset="#3C800000" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000563C4" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="533F4 Turbo Dynamics Proportional Component" type="2" active="1" help="" level="0">
<rows count="9" offset="#563C8" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data offset="#563EC" power="2" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="53408 Turbo Dynamics Integral Negative" type="2" active="1" help="" level="0">
<rows count="9" offset="#56400" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data offset="#56424" power="2" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="5341C Turbo Dynamics Integral Positive" type="2" active="1" help="" level="0">
<rows count="9" offset="#56438" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data offset="#5645C" power="2" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="53430 Boost Atmo Comp RPM Multiplier" type="2" active="1" help="" level="0">
<rows count="4" offset="#56470" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data offset="#56480" power="2" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="53444 Boost Atmo Comp RPM Multiplier" type="2" active="1" help="" level="0">
<rows count="4" offset="#56488" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data offset="#56498" power="2" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="537A4 Veh. Speed based Throttle Angle Limiter" type="2" active="1">
<rows count="2" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#00057B5C" inc_value_offset="#3C000000" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#00057B64" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="537B8 Idle Air Flow Map - Cool. Temp Based" type="2" active="1" help="" level="0">
<rows count="16" offset="#57B68" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data offset="#57BA8" power="2" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="537CC Idle Engine Load Map - Cool. Temp Based" type="2" active="1" help="" level="0">
<rows count="16" offset="#57BC8" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data offset="#57C08" power="2" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="53808 Merv: Idle Speed Coolant Comp " type="2" active="1" help="" level="0">
<rows count="16" offset="#57AE8" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data offset="#57C78" power="2" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="5381C Front O2 Atm P Comp" type="2" active="1" help="" level="0">
<rows count="4" offset="#57C98" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data offset="#57CA8" power="2" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="541B8 Delayed Open Loop Fuel Throt Thresh." type="2" active="1">
<rows count="16" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#0005BC98" inc_value_offset="#3EFA0000" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#0005BCD8" format="%.2f" func_2val="[value]" func_val2="[value]" power="1" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="5459C Delayed Open Loop Fuel Load Threshold" type="2" active="1" help="" level="0">
<rows count="16" offset="#5C3C0" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data offset="#5C400" power="2" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="54600 Throttle Delta Fuel Comp. (Delta)" type="2" active="1" help="" level="0">
<rows count="18" offset="#5C4E0" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data offset="#5C528" power="2" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="54614 Throttle Delta Fuel Comp. Coolant Temp." type="2" active="1" help="" level="0">
<rows count="16" offset="#5BA1C" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data offset="#5C54C" power="2" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="54628 Overrun fuel cut-off - fuelling restore RPM" type="2" active="1" help="" level="0">
<data offset="#5C56C" power="2" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="5463C Boost Limit" type="2" active="1" help="" level="0">
<rows count="6" offset="#5C58C" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data offset="#5C5A4" power="2" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="55110 Overrun Desired Mass Air Flow" type="2" active="1" help="" level="0">
<rows count="16" offset="#5FDB0" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data offset="#5FDF0" power="2" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="55124 Overrun Desired Mass Air Flow #2" type="2" active="1" help="" level="0">
<rows count="16" offset="#5FE10" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data offset="#5FE50" power="2" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="55160 Target Idle 1" type="2" active="1" help="" level="0">
<rows count="16" offset="#5F92C" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data offset="#5FEA8" power="2" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="55174 Target Idle 2" type="2" active="1" help="" level="0">
<data offset="#5FEC8" power="2" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="55188 Target Idle 3" type="2" active="1" help="" level="0">
<data offset="#5FEE8" power="2" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="5519C Target Idle 4" type="2" active="1" help="" level="0">
<data offset="#5FF08" power="2" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="551B0 Target Idle 5" type="2" active="1" help="" level="0">
<data offset="#5FF28" power="2" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="551C4 Target Idle 6" type="2" active="1" help="" level="0">
<data offset="#5FF48" power="2" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="55550 Injector Opening Time Compensation" type="2" active="1" help="" level="0">
<rows count="5" offset="#611A4" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data offset="#611B8" power="4" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="55580 A Temp Sensor" type="2" active="1" help="" level="0">
<rows count="30" offset="#6131C" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data offset="#61394" power="4" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="5558C MAF Sensor Scaling" type="2" active="1" help="" level="0">
<rows count="54" offset="#6140C" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data offset="#614E4" power="4" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="55598 EGT Sensor ?" type="2" active="1" help="" level="0">
<rows count="30" offset="#615BC" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data offset="#61634" power="4" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="5565C Cool Temp Sensor Sc" type="2" active="1" help="" level="0">
<rows count="28" offset="#55958" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data offset="#559C8" power="4" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="55668 AIT Sensor Scaling" type="2" active="1" help="" level="0">
<rows count="30" offset="#55A38" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data offset="#55AB0" power="4" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="53490 Initial Wastegate Duty A" type="3" active="1">
<cols count="8" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#00056520" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<rows count="12" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#00056540" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#00056570" format="%.2f" func_2val="[value]" func_val2="[value]" power="2" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="534AC Initial Wastegate Duty B" type="3" active="1">
<cols count="8" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#00056630" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<rows count="12" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#00056650" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#00056680" format="%.2f" func_2val="[value]" func_val2="[value]" power="2" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="534C8 Initial Wastegate Duty C" type="3" active="1">
<cols count="8" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#00056740" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<rows count="12" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#00056760" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#00056790" format="%.2f" func_2val="[value]" func_val2="[value]" power="2" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="534E4 Initial Wastegate Duty D" type="3" active="1">
<cols count="8" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#00056850" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<rows count="12" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#00056870" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000568A0" format="%.2f" func_2val="[value]" func_val2="[value]" power="2" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="53500 Max Wastegate Duty" type="3" active="1">
<cols count="8" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#00056960" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<rows count="8" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#00056980" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000569A0" format="%.2f" func_2val="[value]" func_val2="[value]" power="2" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="5351C Max Wastegate Duty" type="3" active="1">
<cols count="8" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#00056A20" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<rows count="8" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#00056A40" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#00056A60" format="%.2f" func_2val="[value]" func_val2="[value]" power="2" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="53538 Desired Boost A" type="3" active="1">
<cols count="8" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#00056AE0" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<rows count="12" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#00056B00" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#00056B30" format="%.2f" func_2val="[value]" func_val2="[value]" power="2" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="53554 Desired Boost B" type="3" active="1">
<cols count="8" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#00056BF0" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<rows count="12" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#00056C10" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#00056C40" format="%.2f" func_2val="[value]" func_val2="[value]" power="2" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="53570 Desired Boost C" type="3" active="1">
<cols count="8" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#00056D00" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<rows count="12" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#00056D20" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#00056D50" format="%.2f" func_2val="[value]" func_val2="[value]" power="2" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="5358C Desired Boost D" type="3" active="1">
<cols count="8" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#00056E10" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<rows count="12" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#00056E30" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#00056E60" format="%.2f" func_2val="[value]" func_val2="[value]" power="2" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="54758 Lo Det Fuel Map" type="3" active="1" help="" level="0">
<cols count="15" offset="#5C91C" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<rows count="18" offset="#5C958" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data order="cr" offset="#5C9A0" power="1" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="54774 Lo Det Fuel Map" type="3" active="1" help="" level="0">
<cols count="15" offset="#5CAB0" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<rows count="18" offset="#5CAEC" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data order="cr" offset="#5CB34" power="1" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="54790 Hi Det Fuel Map" type="3" active="1" help="" level="0">
<cols count="15" offset="#5CC44" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<rows count="18" offset="#5CC80" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data order="cr" offset="#5CCC8" power="1" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="547AC Hi Det Fuel Map" type="3" active="1" help="" level="0">
<cols count="15" offset="#5CDD8" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<rows count="18" offset="#5CE14" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data order="cr" offset="#5CE5C" power="1" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="54D28 Ignition Base Map" type="3" active="1" help="" level="0">
<cols count="15" offset="#5EAC4" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<rows count="18" offset="#5EB00" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data order="cr" offset="#5EB48" power="1" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="54D44 Ignition Base Map" type="3" active="1" help="" level="0">
<cols count="15" offset="#5EC58" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<rows count="18" offset="#5EC94" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data order="cr" offset="#5ECDC" power="1" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="54E08 Ignition Advance 1" type="3" active="1" help="" level="0">
<cols count="16" offset="#5EF64" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<rows count="18" offset="#5EFA4" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data order="cr" offset="#5EFEC" power="1" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="54E24 Ignition Advance 2" type="3" active="1" help="" level="0">
<cols count="16" offset="#5F10C" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<rows count="18" offset="#5F14C" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data order="cr" offset="#5F194" power="1" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="54E40 Ignition Advance 3" type="3" active="1" help="" level="0">
<cols count="16" offset="#5F2B4" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<rows count="18" offset="#5F2F4" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data order="cr" offset="#5F33C" power="1" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="53458 WGD Atmo/RPM Comp 1" type="3" active="1">
<cols count="6" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000564A0" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<rows count="4" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000564B8" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000564C8" format="%.2f" func_2val="[value]" func_val2="[value]" power="2" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="53474 WGD Atmo/RPM Comp 2" type="3" active="1">
<cols count="6" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000564E0" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<rows count="4" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000564F8" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#00056508" format="%.2f" func_2val="[value]" func_val2="[value]" power="2" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="554B0 Accel\Throttle Mapping" type="3" active="1">
<cols count="15" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#00060B8C" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<rows count="17" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#00060BC8" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#00060C0C" format="%.2f" func_2val="[value]" func_val2="[value]" power="2" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="54D98 IgnCor CT vs EngLd1" type="3" active="1" help="" level="0">
<cols count="16" offset="#5E120" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<rows count="4" offset="#5EE6C" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data order="cr" offset="#5EE7C" power="1" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="54DB4 IgnCor CT vs EngLd2" type="3" active="1" help="" level="0">
<rows count="4" offset="#5EEBC" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data order="cr" offset="#5EECC" power="1" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="558F8 Intake Cam Advance" type="3" active="1">
<cols count="14" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000629DC" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<rows count="18" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#00062A14" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#00062A5C" format="%.2f" func_2val="[value]" func_val2="[value]" power="2" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="55914 Intake Cam Advance 2" type="3" active="1">
<cols count="14" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#00062C54" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<rows count="18" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#00062C8C" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#00062CD4" format="%.2f" func_2val="[value]" func_val2="[value]" power="2" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="53914 Calc Eng Ld Comp" type="3" active="1" help="" level="0">
<cols count="11" offset="#58054" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<rows count="12" offset="#58080" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data order="cr" offset="#580B0" power="1" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="53930 AirTemp vs AirFlow" type="3" active="1" help="" level="0">
<cols count="5" offset="#58134" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<rows count="8" offset="#58148" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data order="cr" offset="#58168" power="1" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="5394C RPM vs Throttle" type="3" active="1">
<cols count="9" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#00058190" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<rows count="6" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#000581B4" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#000581CC" format="%.2f" func_2val="[value]" func_val2="[value]" power="2" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="539E0 CPC Duty" type="3" active="1">
<cols count="14" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#00058428" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<rows count="13" format="%.2f" func_2val="[value]" func_val2="[value]" offset="#00058460" power="4" caption="caption" desc="desc" signed="True" reverse_bytes="True"/>
<data offset="#00058494" format="%.2f" func_2val="[value]" func_val2="[value]" power="2" caption="caption" color_dir="0" desc="desc" inc="20" incb="170" inc_dir="1" signed="False" reverse_bytes="True"/>
</map>
<map name="53E0C Eng Ld vs RPM 13" type="3" active="1" help="" level="0">
<cols count="12" offset="#59A24" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<rows count="14" offset="#59A54" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data order="cr" offset="#59A8C" power="1" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="54838 Eng Ld vs RPM 2/3" type="3" active="1" help="" level="0">
<cols count="8" offset="#5D5BC" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<rows count="11" offset="#5D5DC" power="4" func_2val="[value]" func_val2="[value]" signed="True" format="%.2f" caption="caption" desc="desc"/>
<data order="cr" offset="#5D608" power="1" func_2val="[value]" func_val2="[value]" signed="False" format="%.2f" caption="caption" desc="desc" color_dir="0" inc="20" incb="170" inc_dir="1"/>
</map>
<map name="#5B960 Rev Limit" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#5B960" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#5B9AC Speed Limiter" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#5B9AC" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#5B4FC Injector Flow Scaling" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#5B4FC" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#45870 Enabled Diagnostic Trouble Codes" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#45870" power="0" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#56201 Learnt Ign Count for Boost Disable" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#56201" power="0" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#56258 Learnt Ign Retard for Boost Disable" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#56258" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#5625C Advance Mult for Boost Disable" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#5625C" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#56260 Advance Mult for Boost Re-Enable" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#56260" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#5B428 Closed to Open Loop Delay Periods" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#5B428" power="1" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#5B774 Closed Loop Min Coolant Temp." type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#5B774" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#5B778 Open Loop Per Gear RPM Thresholds Man." type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#5B778" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#5B7A0 Open Loop Per Gear RPM Thresholds Auto" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#5B7A0" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#5B7C8 Open Loop Stationary RPM Threshold" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#5B7C8" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#5B7D0 Open Loop Throttle Thresh Hi Alt. Auto" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#5B7D0" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#5B7D8 Open Loop Throttle Thresh Lo Alt. Auto" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#5B7D8" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#5B7E0 Open Loop Throttle Threshold Manual" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#5B7E0" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#5B7E4 Closed Loop Max Vehicle Speed" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#5B7E4" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#5B7EC Closed Loop Max EGT" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#5B7EC" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#5B7F4 Open Loop Hi/Lo Altitude Threshold" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#5B7F4" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#5B7FC Delayed Open Loop RPM Threshold" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#5B7FC" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#5B800 Delayed Open Loop Load Threshold" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#5B800" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#5B804 Fuel Map AdvMult Threshold" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#5B804" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#5DD94 Fine Ign Learning Advance Time Interval" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#5DD94" power="1" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#5DF8C Maximum Knock Retard" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#5DF8C" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#5DF90 Knock Retard Decrement - Gamma F" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#5DF90" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#5DF94 Knock Retard Increment - Alpha F" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#5DF94" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#5E040 Knock Detection RPM Range" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#5E040" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#5E06C Coarse Ign Learning RPM Range" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#5E06C" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#5E07C Coarse Ign Learning Load Range" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#5E07C" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#5E0C0 Fine Ign Learning Max Advance" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#5E0C0" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#5E0C4 Fine Ign Learning Max Retard" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#5E0C4" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#5E0C8 Fine Ign Learning Advance Magnitude" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#5E0C8" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#5E0CC Fine Ign Learning RPM Range" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#5E0CC" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#5E0DC Fine Ign Learning Load Range" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#5E0DC" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#5E0EC Fine Ign Learning Map Load Columns" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#5E0EC" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#5E0FC Fine Ign Learning Map RPM Rows" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#5E0FC" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#5E114 Fine Ign Learning Retard Magnitude" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#5E114" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#55CFC MAP Sensor Scaling - Pressure Offset" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#55CFC" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#55D00 MAP Sensor Scaling - Voltage Multiplier" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#55D00" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#578A0 Mass Air Flow Reading Limit #1" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#578A0" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#58934 Mass Air Flow Reading Limit #2" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#58934" power="2" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#1FFC Boot ROM Version" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#1FFC" power="0" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#9F DTC Count" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#9F" power="0" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#45910 DTC Definitions" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#45910" power="0" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#5 Fine Ign Learning Load Column Count" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#5" power="0" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#7 Fine Ign Learning RPM Rows Count" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#7" power="0" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
<map name="#61EB8 Sel Mon ID" type="1" active="1">
<data count="1" func_2val="[value]" func_val2="[value]" offset="#61EB8" power="0" format="%.2f" caption="" desc="" color_dir="1" inc="1" incb="5" inc_dir="1"/>
</map>
</ecu_struct>
</ecus>
DarkECU
Postby Freon » Wed Apr 26, 2006 12:54 pm
Wow, nice work. Just need to figure out some common new functions. I do notice that some of the same conversion functions from the 160k ECUs work. Ignition and AFR work fine. Any 4 byte definition seems to be off.
Anyone have ideas, particularly for the MAF sensor scaling numbers?
Re: 2004 STi ETC ROM AD3A101D AJ242
Postby Dino606 » Sun Oct 19, 2008 5:49 am
cboles wrote:another ETC ROM...
Hi,
just wondering whether the stock sti roms u posted have the stock values for the injector scaling and latency?
I'm looking for stock sti injector scaling and latency values as i am using them in my Mitsu Airtrek Turbo.
Anyone can help?
Dino606
Postby Freon » Sun Oct 19, 2008 12:10 pm
They're stock tunes, with stock latency and injector scalars. This is a post from over two years ago and that is one of the first times a DBW ECU was read.
The AJ241, AJ242, and AJ243 all have the same injector settings and are all for the same car, the 2004 USDM STI with yellow side feed injectors.
