2005 STi ECU ETC ROM AD3A104K AJ931
Postby cboles » Mon Feb 27, 2006 6:55 pm
Here's a ROM I pulled out today from the electronic throttle control CPU of a 2005 STi using the BDM port. I'm not sure which variant of the 68HC916 this is (there are a couple of possibilities). I'm also having trouble reading anything other than this 32k block, even though I expect there is at least another 16k and 2k block lying around. One I check some control registers, I should be able to find them. A quick glance at the code with IDA seems to indicate that everything lives in this 32k though.
2005sti_stock_AD3A104K_AJ931.zip
(10.58 KiB) Downloaded 505 times
Postby gregsachs » Tue May 09, 2006 11:23 am
colby, any chance this ecu is still present/could be posted? Or is this the same as the other 2005 ecu image you posted?
thanks,
greg
gregsachs
Postby cboles » Tue May 09, 2006 11:26 am
It is the same as the other I posted. This is from the throttle control CPU on that same ECU.
Postby gregsachs » Tue May 09, 2006 11:35 am
ok, missed that. Looks like we've got the early 2005 sti rom, but are missing the later version.
gregsachs
