1.33 crashes when reading ecu
Postby 06rexwagon » Tue Oct 02, 2007 5:26 pm
Anyone successfully read a rom with 1.33? On 2 different 05 STi's and 2 different laptops it crashes and wants to send an error report as soon as I hit read.
06rexwagon
Postby ecuflasher » Wed Oct 03, 2007 10:02 am
I have the same prob.
ecuflasher
Postby radsdau » Wed Oct 03, 2007 10:54 pm
Works for me. Looks like the problems people have been having are related to the FTDI drivers.
When installing 1.33 I cancelled at the USB driver part.
Postby Spec C Wannabe » Thu Oct 04, 2007 5:31 pm
Mine failed at reading/writing Ecu from the instance that I hit read or write button.
I am not a computer geek so I don't know what's wrong with it....
Now I can't go back to older version and stucked with my tuning.
Spec C Wannabe
Postby qoncept » Sat Oct 06, 2007 12:29 pm
Happening here too. I tried first with my buddy's Vista box with a completely fresh install and using the packaged drivers. Then tried on XP laptop with 1.33 and the drivers I had from an old install.
Postby ev8siv3 » Mon Oct 08, 2007 2:48 pm
Try this set of drivers.
ProperTactrixDrivers.zip
(746.43 KiB) Downloaded 536 times
ev8siv3
Postby Spec C Wannabe » Mon Oct 08, 2007 10:12 pm
ev8siv3 wrote:Try this set of drivers.
Ok will try it tonight...
How to install and replace the old unworkable file?
Please give me the path.....
Thnx so much... :D
Spec C Wannabe
Postby ev8siv3 » Tue Oct 09, 2007 7:26 am
Goto the windows control panel, uninstall all FTDI and tactrix drivers.
Reboot the computer.
Unarchive this attachment to its own folder. Go into the directory and install the drivers with DPinst.exe.
Then reboot again and insert your cable to try again.
ev8siv3
Postby 06rexwagon » Tue Oct 09, 2007 7:29 am
Where did these drivers come from?
06rexwagon
Postby ev8siv3 » Tue Oct 09, 2007 7:43 am
06rexwagon wrote:Where did these drivers come from?
A working installation back around 1.29 or 1.30 I believe. Check the timestamp on the files. It has been the only drivers that have worked properly for myself and many other people who have upgraded.
ev8siv3
Postby Paolino » Thu Oct 11, 2007 6:10 am
I tried installing 1.28, 1.30 and 1.33 using all different driver combinations, including the ones in this thread. I am running Vista and trying to read my USDM 07 wrx rom.
Paolino
Postby Spec C Wannabe » Thu Oct 11, 2007 6:13 am
I ended up using 1.3.0 from my thread below.
Spec C Wannabe
Postby cboles » Sun Oct 14, 2007 5:46 pm
I'm looking into it - I have removed all the drivers / software on my Vista machine, and I can't get it to reproduce the problem some of you are having with 1.33. Hopefully I can get a repro soon...
Postby cboles » Sun Oct 14, 2007 5:53 pm
I cleaned off an XP machine and it seems to work fine too with 1.33. Hmmm....
Postby 06rexwagon » Sun Oct 14, 2007 7:00 pm
Try an old 1.2 cable
06rexwagon
