Hi
I have install 1.31, but now on my Evo 7 lots of the X and Y scales on the maps show jumbled numbers, most odd as 1.30 was fine.
Anyone else have this problem.
MB
burgers wrote:Hi
MB
merchgod wrote:Probably an endian mixup due to the fix in 1.31 where the endian attribute reversal was fixed. Find a table that has the issue and open your base xml file (ex. evo9base). Search for the table and find the scaling attribute for the axis is question. Look at the endian attribute. If it is "big" then change to "little" or vice versa. See if that fixes the issue.
