Map Request stage 3 05 wrx
Postby brandonbeeb » Mon May 14, 2007 3:15 pm
Guys currently looking for a map i can modify a bit im running a stage 2 map, my mods are
TurboXS Front Mount Intercooler
Samco Blue Silicone Turbo Inlet Hose
HKS Dual chamber Blow off valve
Group A Lightened Pulley
Turbo XS Up pipe
Bosal Shorty down Pipe
Custom Magnaflow Axleback
TurboXS Short Ram Intake
NGK Iridium Spark Plugs (One Step Colder)
was wondering if anyone had a more agressive map then a stage 2 i could use to modify, im looking to push 18-20 psi midrange thanks
brandonbeeb
Postby Freon » Mon May 14, 2007 8:09 pm
The problem with base maps is that they will never work right on cars with too many mods. Having anything but a stock intake probably rules you out for a stage/base/pretuned map.
Where are you located? Maybe you can find a tuner local.
Postby blurexwagon » Mon Jun 04, 2007 7:34 pm
Freon wrote:The problem with base maps is that they will never work right on cars with too many mods. Having anything but a stock intake probably rules you out for a stage/base/pretuned map.
:shock: :shock:
um, good to know, said the cai guy...
blurexwagon
Postby brandonbeeb » Thu Sep 06, 2007 1:44 pm
does anyone have a map for this?
brandonbeeb
