CALID vs ...
CALID vs ...
Postby Jon [in CT] » Tue Dec 20, 2005 6:14 pm
Here are some older CALID's from some SOA reprogrammed ECUs.
soa_ecm.pdf
(20.58 KiB) Downloaded 1313 times
Postby Jon [in CT] » Thu Jan 12, 2006 3:29 pm
I've found an updated list (12/16/2005) of SOA ECU reflashes and their CalIDs. There are some interesting reflashes for the 2004/5 WRX that fix a pinging problem.
soa_ecm.pdf
List of available (12/16/05) SOA ECU reflahses containing problems fixed and CalIDs
(186.61 KiB) Downloaded 1441 times
Postby cboles » Thu Feb 09, 2006 9:21 am
How are you so hooked in to all of this great info?
Postby Kha0S » Thu Feb 09, 2006 12:43 pm
Jon is a Subaru (Master?) Tech, AFAIK.
Kha0S
Postby MRF582 » Sat Feb 11, 2006 6:53 pm
Good to know. But there is no information about my 04 WRX ECU.... I have a A4FTF300F. I got it December 2003. I believe it was built by May 2003.
MRF582
Postby Jon [in CT] » Fri May 05, 2006 2:43 pm
MRF582 wrote:Good to know. But there is no information about my 04 WRX ECU.... I have a A4FTF300F. I got it December 2003. I believe it was built by May 2003.
You have a "base" ROM, the initial version for that model year in the US/Canada. Base CalIDs don't show up in these lists.
Attached is an updated list for the US/Canada. There's a glitch on p. 5 and it may be missing STI information. Sorry about that, but there's no way I can fix.
The 2006 WRX and Forester XT are now represented. There's a fix for a P0605 - Internal Control Module Read Only Memory Error. Sounds serious. Hopefully, the fix is for the detection criteria. I haven't seen reports of this DTC on any other forums.
soa_ecm.pdf
List of available reflashes as of 03/30/06
(335.32 KiB) Downloaded 1454 times
Postby cooter » Fri Dec 07, 2007 8:01 am
Sorry to resurrect an old post, but looking at the latest changelog posted, there appears to be missing information. Specifically on page 5, over half the page is missing, right where my car's info would be (2005 STi) :cry:
Looking elsewhere, there only appears to be two revisions for the 2005 STi's ecu, and I have the earlier one. Just curious what the latest revision "fixes".
cooter
