Postby epifan » Fri Dec 02, 2005 12:13 pm
www.epifansoft.com
New screenshots
ecuEdit v2.4.0.92
- Logger: Mitsubishi MUT protocol support
- Tracer/Log Link: unlimited count of data parameters
- Log Viewer: Joint Log mode (all log series on one chart)
- Log Viewer: Dyno time interpolation
- Logging directly through FTDI devices
- Enginuity XML Converter - inheritance map dimension fix
ecuEdit v2.3.0.90
- On-line Tracer: Link Map with Logger
- Logger: Warning Sound (setup in ecuEdit.ini)
- Editor: 1D map with defined data values, like switch. Example: CEL fix maps with Enabled/Disable values
- Editor: Double Click for edit Columns/Rows headers
- Enginuity XML Converter - supporting <switch> tag for CEL fixes
ecuEdit v2.2.2.87
- Logger: Triggers based on expression for logging to file (Defog switch, Full Throttle)
- Logger: Global warnings based on expression. Example : (if Knock Correction < 0 and Engine Load > 2). Global warnings editor is not compleete yet, only read XML
- Logger: Calculated params fixes (like Manifold relative pressure). Don't needs to activate linked params (Absolute pressure and Athmo pressure)
- Editor: Windows clipboard support for map paste
- Log Viewer: Cutting time interval from log
- Log Viewer: Save Log As and Save Selected Range
ecuEdit v2.2.1.85
- Log Viewer: Advanced Log merge ability (custom 2D/3D support)
- Log Viewer: Custom chart: data filter
- Log Viewer: Custom chart: 2D Points (bubbles) chart
- Editor: round function
- Editor: Col and Row headers interpolation
- Editor: Map's screen values clipboard copy
- Logger: Calculated parameters (ex.: Manifold Corrected Relative Pressure)
- Logger: Save parameter's alternatives
- Logger: New Unknown ECU connection dialog
- XML Viewer: search
- Innovate Wideband fixes
- Enginuity ROM XML Descriptions converter
- other bug fixes and improvements
ecuEdit v2.2.0.79
- Innovate Wideband Lambdas support (Innovate ActiveX component). In demo-version Labmda is not writed to Log-file - display only
- Log Viewer : RPM based road dyno
ecuEdit v2.1.0.77
- SSM Logger: Diagnostic Trouble Codes reader
- SSM Logger: Reset ECU
- SSM Logger: Custom Memory Logger (this version include only one preset for Logging Active Ignition Correction (table 8x8 offset=IAM offset+2)
- Logger scheme saver/reader. Save/restore all selected log parameters, graphs and dash setups and etc.
- bug fixes: (many opened windows bug, etc)
ecuEdit v1.2.0.72beta
- Subaru Select Monitor LOGGER
- all SSM parameters described in XML (name, address, covertion expression etc)
- all metric conversions in XML
- alternative addresses for some params (like IAM, Engine Load)
- custom graphs quantity (2 parameters on each graph)
- custom dash item quantity (grid X by Y)
- and more
- Simple DYNO in Log Viewer
- new version of chart engine (360 degree rotation support and others features...)
ecuEdit v1.2.0.71beta
- map list tree view with/without map type grouping (3d,2d,1d)
- Log Viewer: custom log table with graph (surface, bar plot)
- clone ECU description in edit ECU description dialog
ecuEdit v1.2.0.70beta
- new tool - scaling. <scaling> descibe axis or data parameters and contain most of <row>,<col>,<data> attributes. Built-in editor for scaling.
- new tool - checksum. <checksum> describe algorithm of checksum calculation. Identificators are [ecu_type] and ECU file size.
- new attributes [incdata], [incdatab] in <scaling> and <data> for describe increment in real values ([inc], [incb] for increment in ecu-format data)
- new attributes [max], [min] in <scaling> and <data> for describe min and max values
- new attributes [metric] in <scaling> and <data>,<rows>,<cols> for describe unit name string
- float in HexViewer
- new attribute class="Igintion"|"Boost"|"string" in <ecu_struct> for map grouping
- single map XML viewer with edit support (Ctrl+X)
- map struct description included for DBW Subaru ECU (used for describe map by map offset)
ecuEdit v1.2.0.66beta
- new attribute [storagetype] for <rows>,<cols>,<data>. [storagetype] replaces attributes [power] and [signed] and adding new feature of float type (IEE 754)
storagetype="int8|uint8|int16|uint16|int32|uint32|float"
- some bug fixes and improvements
ecuEdit v1.2.0.65beta
- interpolate paste from internal clipboard (from early versions :) forget to announce)
- single map compare from internal clipboard. Compare use interpolate method for assign compared map to source axis and dimensions
- sort map list
- feature to hide equal cells in map compare (Ctrl+E)
- qucik swith to difference mode (Ctrl+D)
- data captions and rows/cols constansts support in build-in map editor
ecuEdit v1.2.0.64beta
- XMLWrite output-type parameter support in INI-File (default =1 - with full offsets)
ecuEdit v1.2.0.63beta
- <map offset=""> support. <map_struct> needed to find map params
- bug with many open windows (more 200) fixed (some MSWindows limitation...)
ecuEdit v1.2.0.61beta
- ini-file added for some additional config parameters
- XMLDir in ecuedit.ini - path for ecu xmls
- XML save improved
- XMLWrite V2.0 support ;) If programm don't find ecu description, it execute XMLWrite to generate XML description and place XML-file to XMLDir. EcuEdit use TEMP directory described in Windows System Environment. XMLWrite.exe and XMLWrite.dat must be in same directory with ecuEdit.exe
ecuEdit v1.2.0.60beta
- single map compare from any ECU
- automatic fill offsets, power, length by map type byte: <map_stuct> in <ecu_tools>
- irregular graph in 3d maps
ecuEdit v1.2.0.57beta
- ECU compare by map list with Source,Compared,Difference table and graph view ability
- Quick map assign from compared ECU
- automatic position of map windows (at left of map list window)
ecuEdit v1.2.0.55beta
- big/little Endian for <ecu_struct>
- big/little Endian, signed/unsigned support for <rows>,<cols>,<data>
- 3d data order: "cols, then rows" (default), "rows, then cols" (used in EVO 3d maps)
- map help support <map ...help="line 1|line 2"...>
- map advance level support <map ...level="1"...> - for organize maps
- ecu ID description support series of different ID's bytes in char and BCD format, functions and char-constants. Allow to assemble ID like JM9653-06
- columns in 1d maps <map type="1" ...cols="5"...>
- 1D map like string <map type="1" ...view="str"...>
- BIN representation in HEXViewer
- HEX,BIN,CHAR,NUM view representation in 1D map <map type="1" ...view="hex"...>
ecuEdit v1.2.0.47beta
- Log Viewer support logs overlay (shifting, hiding)
- Copy map to Windows clipboard in HTML-format
ecuEdit v1.2.0.46beta
- convert functions for Increment value (func_2inc, func_inc2 attributes in <rows> tag)
- support EcuID in diffrent ECUs with same size (EVO9 32-bit ECU and Subaru DBW 32-bit ECU)
ecuEdit v1.2.0.45beta
- increment axis in 2D maps
- data headers in 1D maps
- const axis in 2D maps
ecuEdit v1.2.0.43beta
- support little endian and big endian numeric representation
ecuEdit v1.2.0.41beta
- adding HEX ecu compare: split screen, color difference visualization, navigation
- suppot multi-file XML description for read and write: ecuEdit scan self directory for XML-files, finding unique ecu description and link it. You can see linked xml-files in "file_name" attribute of <ecu_struct> tag in XML viewer. In write process changes would be only in linked <ecu_struct> - another tags in XML-file would not changed
ecuEdit v1.2.0.40
- Map and Log link support. Show cells in map which are used by ECU log.
- New log monitor. Monitoring selected directory and waiting for new log files. Each new log is automatically opened in ecuEdit
ecuEdit v1.2.0.38
- Log Viewer: Support custom log calculated by function with paramters from other log data. Example: build gear change log.
- Log Viewer: Range selector, quickly select log data by range. Example: select full throttle range for custom 2d,3d graph analysis.
- Map description editor: MUL parameter is off by default.
ecuEdit v1.2.0.36
- Support 32-bit ECU
- Log Viewer: functions support for convert log data (time and data conversion)
- New TAG in <config> for describe map ID's
ecuEdit v1.2.0.33
- Log Viewer: Custom 2d, 3d graphs and other improvements
- Support different file and description sizes: open 160K bin file by 192K-offset description and vice versa
- Map clipboard (Copy and paste data from another maps)
ecuEdit v1.2.0.29a
- Log Viewer. Support log session with changes in quantity of log parameters. Some popular log viewer's don't support this opportunity
- Inherited ECU descriptions support by use "include" attribute in <ecu_struct> tag
- Built-in editor for all ECU descriptions
- Simple offset calculator in map description editor
- New graph visualization: transparency, zooming, scrolling
- Command Line support for logs (*.csv) and ECU bin (*.hex)
- Changes in XML-structure: now XML must have only one top-level tag <ecus>. ecuEdit would be try to automatic add <ecus> tag if it isn't exist in ecuEdit.xml
ecuEdit v1.1.0.25
- Functions support (built-in editor). To use function just type function name with "()" in expression from map descriptions (example: func_2val="toRPM()").
- 2D Graph Mouse Navigation and real value axis support
ecuEdit v1.1.0.18:
- including some map description for US 04 WRX, EU 02 WRX
- HEX viewer/editor
- map description built-in editor
- save support.
Your's comments and wishes are wellcome :wink:
epifan
Postby FrSTi » Fri Dec 02, 2005 1:20 pm
That's very nice stuff ;)
FrSTi
Postby WolfPlayer » Sat Dec 03, 2005 6:48 am
Very nice stuff! Great job. Is this available for public download yet?
t
WolfPlayer
Postby New2Scoobs » Sat Dec 03, 2005 8:10 am
Agreed. A very nice (& useful ) looking piece of software. When can we get our grubby little mitts on a copy? :wink:
Postby Jeramie » Sat Dec 03, 2005 5:34 pm
No download available?
Jeramie
Postby epifan » Sun Dec 04, 2005 10:03 am
Jeramie wrote:No download available?
Only for describe maps and view. Editing is support but without "Save" :wink: I'm not decide yet, what I want to do with this soft...
If you are want to try, I'm upload it to forum.
epifan
Postby Jeramie » Sun Dec 04, 2005 10:36 am
"I'm not decide yet, what I want to do with this soft...
If you are want to try, I'm upload it to forum."
What do you mean? Is this not a open source project?
Jeramie
Postby epifan » Mon Dec 05, 2005 12:35 pm
Ok, I decide to upload last version (save not realize) with comments for map describe and some examples.
epifan
Postby Jeramie » Mon Dec 05, 2005 1:06 pm
Cool beans. I'll take a look as soon as I get done work!! Thanks for posting it. :D
Jeramie
next new futures
Postby epifan » Wed Dec 07, 2005 2:35 am
The next new features of ecuEdit is:
- map headers values edit;
- direct (in program) map descriptions edit and adding new maps;
- built in HEX viewer with map link, search function and edit support (look's like Analyzer, but with more functionality)
uploading soon, may be end of this week
P.S. So, what's yours impressions of using ecuEdit?
epifan
Postby NeverLies » Wed Dec 07, 2005 3:20 am
Tested and this is really nice :D Just frustrated that save function is missing right now :(
Do you plan to publish sources of your application ?
Postby epifan » Wed Dec 07, 2005 3:37 am
NeverLies wrote:Tested and this is really nice :D
thx
NeverLies wrote:Just frustrated that save function is missing right now :(
coming soon, I'm promise :wink:
NeverLies wrote:Do you plan to publish sources of your application ?
It's immposible, because it's Delphi project with use a lot off components, including not freeware comps.
epifan
Postby New2Scoobs » Wed Dec 07, 2005 3:45 am
I like it alot. Will we have to know all of the offsets to display maps or will your program automatically find the offsets for the different ROMS?
Great software. :D
Postby epifan » Wed Dec 07, 2005 3:56 am
New2Scoobs wrote:I like it alot. Will we have to know all of the offsets to display maps or will your program automatically find the offsets for the different ROMS?
Great software. :D
Thx.
I don't plan to realize map find function in ecuEdit. This is so difficult task, because short 1d or 2d maps imperceptible in 192K ROM file. And "costs" of developing soft for automatic search is much more then wasted time to manual search.
epifan
Postby New2Scoobs » Wed Dec 07, 2005 4:02 am
Great software. :D
Thx.
Fair enough. Can you please help me to find more maps "manually" for <ecu_struct id="A4SE900D" type="Euro WRX 02">.
I only have the offsets than came with your ECUEdit.XML sample file.
Users browsing this forum: Bing [Bot] and 0 guests
