by marky9074 » Fri Jan 12, 2007 8:54 am
Hi guys,
My tuner has pulled the ROM from my new MY07 Forester STI, but as yet has had no luck flashing back....
In the interim, armed with the tactrix cable I thought I would go through the motions to connect up, just as a learning process.
I have connected the green connectors under the OBD-II connecter, and followed the instructions selecting a DBW 2005-2006, but it bombs out saying check the log.....the log doesnt really give much away. As Colby mentions in other posts, I did this with the clutch in as it's a JDM model.....
[20:13:15.843] Version 1.29.906
[20:13:15.843] 8 memory models read.
[20:13:16.968] 140 ROM metadata models read.
[20:13:16.968] checksum module "subarudbw" loaded.
[20:13:16.968] flashing tool "wrx02" loaded.
[20:13:16.968] flashing tool "wrx04" loaded.
[20:13:16.968] flashing tool "sti04" loaded.
[20:13:16.968] flashing tool "sti05" loaded.
[20:13:16.968] flashing tool "mitsukernel" loaded.
[20:13:16.968] flashing tool "mitsukernelocp" loaded.
[20:13:16.968] flashing tool "mitsubootloader" loaded.
[20:13:41.062] ssm2_init
[20:13:41.203] ECU ID is 3B 02 59 43 16
[20:13:41.203] ssm2_cmd_0x81
[20:13:41.250] ssm2_cmd_0x83
[20:13:41.296] denso challenge-response
[20:13:41.343] challenge is AB D1 8E 14
[20:13:41.359] response is 00 43 53 2D
[20:13:41.406] ssm2_cmd_0x10
[20:13:41.765] validating denso kernel ram area addr: FFFF3000 len: 0C28
Any ideas?
Mark
