JECS ROM Download
Postby west_minist » Wed Dec 07, 2005 5:53 am
I have the room, but enginuity didn't open it.
I will see what excel can do.
Postby west_minist » Wed Dec 07, 2005 7:39 am
How did you view or know which parameter is for what?
Postby Spiider » Wed Dec 07, 2005 6:27 pm
Colby's HC16 IDA flirt sig helped a lot. Plus, the Motorola specs and language reference posted here, and some electrical schematics.
Extensive testing, and a good knowledge of certain hex editors.
2A640-2A665 = VVT INTAKE CAM ADVANCE ANGLE RPM SETTINGS (VERTICAL)
2A667-2A682 = VVT INTAKE CAM ADVANCE ANGLE THROTTLE SETTINGS (HORIZONTAL)
2A685-2A79C = VVT INTAKE CAM ADVANCE ANGLE DATA VALUES
This is only for the ah581 rom. (2003 "ver8" JDM STi Twin Scroll)
Postby west_minist » Wed Dec 07, 2005 6:53 pm
You are getting me excited!!!
Postby west_minist » Wed Dec 21, 2005 6:59 pm
I got my wideband installed in the car and have partial tune the car. A lot more responsive now. I have a HKS AFR.
What I realise that below 4Krpm (close loop) and below 1/2 throttle, the car is @ 14.7 or slightly less. Damn.
The only way that I can correct is problem is a reflash.
Colby, how is the JECS editing coming along?
Postby cboles » Wed Dec 21, 2005 7:17 pm
I just got a JECS ECU in the mail the other day - hopefully I can get the reflash figured out for it soon!
Postby west_minist » Wed Dec 21, 2005 7:26 pm
Thats great!
I just cannot believe the afr in that range.
Once download, then we can see what other tools out there to view those maps.
Either way, good news.
Postby west_minist » Sun Dec 25, 2005 1:07 pm
I opened up my JDM MY00 2.0L AVCS Impreza non-turbo Unisia JECS ecu today.
UNISIA JECS CORPORATION
A5
22611 AE463
A18-000 D3G 0524
On the broad:-
A19-001 D52N
The large chip w/ many legs, which have to be the ecu is not a motorola
UJ
WA12212920WWW
016E100
All other chips were NEC. But the processor chip had no motorola on it at all.
Colby, I do not know if this would help, but can you post a pic of the JECS you have?
Postby Hitokiri » Sun Dec 25, 2005 9:27 pm
the ECU he has is a USDM MY00 2.5RS ecu and has the same
"uj" chip I know exactly what you are talking about.
the protocol he developes will hopefully work accross these ecus.
Postby NoCtrl » Mon Dec 26, 2005 3:59 am
Hi,
So my99 and my00 ECU's all look like these: :?:
ECU-my99-TYPE_R_WRX
ECU-Forester-S-Turbo-99 big picture
The Forester-ECU is from my car, the picture of the WRX-ECU was lifted from ebay..
Guess its time to get a Interface and look around for a spare ECU to fool around with :P
NoCtrl
Postby west_minist » Mon Dec 26, 2005 5:44 am
Yep. Thats correct. All of them look the same. The socket from the right is not use and most probably follow this diagram:-
MY99-00 WRX&STI ECU Pinout Diagram.jpg (441.58 KiB) Viewed 22436 times
Connector pg2.jpg (89.66 KiB) Viewed 22251 times
Connector pg1.jpg (130.12 KiB) Viewed 22344 times
Postby NoCtrl » Mon Dec 26, 2005 9:02 am
west_minist wrote:Yep. Thats correct. All of them look the same. The socket from the right is not use and most probably follow this diagram:-
Nice!
Thank you.
NoCtrl
Postby west_minist » Mon Dec 26, 2005 9:06 am
I just need to add the AVCS controls now.
But there was a new ecu that came out for the same engine in 2000. Most probably when acquisitions were going on w/ Unisia JECS Corp.
Where is the rom store? In the chip below the microprocessor?
Postby Spiider » Mon Dec 26, 2005 4:02 pm
If you are talking about the Rom that we access, it is internal to the micoprocessor.
Postby west_minist » Mon Dec 26, 2005 6:24 pm
Ok.
I wonder how Cboles is coming along w/ the JECS.
Any word from him on this?
