ECUFlash can work with Mitsubishi Outlander?
Postby dannieboy » Wed Sep 13, 2006 4:43 pm
monsta11 wrote:I have Airtrek Turbo but cant get it to work. Could you do a better discription of the connections?
Redo your white connector's cable, and attached to your green wires.
Airtrek Turbo has 3 version, earlier batch of JDM and domestic, and face-litted version of domestic
dannieboy
Postby RanEvo » Wed Sep 13, 2006 4:50 pm
dannieboy wrote:
RanEvo wrote:Is that your personal experience?
Can you explain haw to connect the Outlander to the cables connectors?
You're using which series of the engine?
It is the Outlander Turbo, 4G63 whit MH8202F ECU processor.
RanEvo
Postby dannieboy » Thu Sep 14, 2006 8:35 am
RanEvo wrote:It is the Outlander Turbo, 4G63 whit MH8202F ECU processor.
Yup, it's possible to read. Just follow my instruction above. Cheers :D
dannieboy
Postby RanEvo » Thu Sep 14, 2006 3:11 pm
I don't fully understand how to connect it?
in the white cable we have 3 wires, want to do with them?
In the car, we have white connector (female) with 2 wires in it, so what to do please? :?:
RanEvo
Postby monsta11 » Fri Sep 15, 2006 6:42 pm
In the end I chopped the connector off past the heatshrink so that there is only one black cable.
I then attached it to the the pin on our white connector that is green. It didnt make any difference if I connected to the odb pin 1 as well.
I was only able to download using the Evo 9 kernel.
monsta11
Postby otter » Tue Sep 19, 2006 8:29 am
RanEvo wrote:Unfortunately it is imposable to download the ROM file at this moment, I have tried it whit Outlander Turbo and Outlander 2.4 .
The processor in the Outlander is the MH8202F, and cboles stated that “I have a H8 kernel that is almost done. I'm just totally bogged down in other work. Hopefully I'll get it out in Sept....”
So we have a hope to have a solution any day now. :D
Does both the turbo and the 2.4 use that same chip? Reason I ask is I drive a 2.4L Lancer (Ralliart) which shares the same engine (and hopefully ECU, MN156916) as the 2.4L Outlander.
otter
Postby RanEvo » Thu Sep 21, 2006 1:20 am
Honestly, I don't know about the chip of the 2.4 Outlander or the Lancer, I only know for sure what the chip on the Outlander turbo.
RanEvo
Postby RanEvo » Thu Sep 21, 2006 1:27 am
monsta11 wrote:In the end I chopped the connector off past the heatshrink so that there is only one black cable.
unfortunately, its note working on the Outlander Turbo!
I'm geting this when it start to download:
[00:08:12.203] sending init sequence 1 (0001)
[00:08:15.421] sending init sequence 1 (0003)
[00:08:18.640] sending init sequence 1 (FFFF)
[00:08:21.859] sending init sequence 1 (7777)
[00:08:25.093] sending init sequence 1 (7778)
[00:08:28.328] sending init sequence 1 (F0F0)
[00:08:31.046] no response to any known code
and that's it!
I hope that the H8 kernel that is almost done will do the job for the MH8202F of the Outlander Turbo?
As many, many people in Europe are waiting so long for a solution...
RanEvo
Postby monsta11 » Thu Sep 21, 2006 11:03 pm
Try different models of vehicle before uploading- I was getting the same message before I tried the Evo 9 option.
monsta11
Postby RanEvo » Fri Oct 06, 2006 5:16 pm
it's not working with the Outlander Turbo! And it will not work unless we will have the software specific working with the MH8202F! The good news is that very soon we will have it :D
RanEvo
Postby RanEvo » Fri Oct 13, 2006 3:26 pm
wow, we are on October now and waiting, waiting, and waiting for the MH8202F ,Pleas :cry:
RanEvo
Postby salex » Fri Oct 13, 2006 11:29 pm
RanEvo wrote:wow, we are on October now and waiting, waiting, and waiting for the MH8202F ,Pleas :cry:
Guys give Colby a break! His work is worth our appreciation, rather than sole anticipation.
I am sure he will let us all know by the time it is ready. Until then, since we can't really help him speed things up, its better to wait and stay quiet.
salex
Postby thefranchise » Sat Oct 14, 2006 10:33 pm
ya wait and keep waiting...we 1st were told the H8 support might happen back in May of 2006...so just wait until May 2007 incase he made a typo
thefranchise
Postby Cabal » Sun Oct 15, 2006 9:59 am
Maybe you should demand your money back.
Cabal
ECU pictures adn Dyno bench Test
Postby christian_piasini » Wed Dec 06, 2006 11:53 pm
Hi @ all, some additional info on the Outlander ECU EDM
I take some picture and I try the car on the dyno bench.
bye
Chris
