AutoXer wrote:NoQuarter wrote:My LC-1 reading stays at 19.4 something also. It doesn't seem to change at all.
Am I going to have to wait another couple of weeks, or <gulp> months to have this issure resolved? Logging from my LC-1 was the one feature that's had me checking the forum multiple times per day. If I could pick between having gauges, graphing, hot-keys, logging indicators and only having LC-1 logging.... I'd take the LC-1 and leave the rest in a heartbeat.
Please, fix it and give us a v0.91. Pretty please... with sugar on top.
I'm willing to be a beta tester!
Agent-Smith wrote:AutoXer wrote:NoQuarter wrote:My LC-1 reading stays at 19.4 something also. It doesn't seem to change at all.
Agree with this EvoMad.
I know you are busy/family man so how about send up the source to me like you said you would if we pm'd you.
I can take a look at the issue and send any patches your way for distribution.
NoQuarter wrote:Agent-Smith wrote:AutoXer wrote:NoQuarter wrote:My LC-1 reading stays at 19.4 something also. It doesn't seem to change at all.
Same here, get me the source code like we discussed previously and between me and another programmer that works for me, I'll check it out as well and submit changes back to you. The LC1 integration was my #1 concern as well.
Evo4Mad wrote:Do you have a wideband controller you to wish to have supported on EvoScan?
PM me for a v0.95 download link.
Extract the v0.95 EvoScan.exe file into your installation directory i.e. C:\Program Files\EvoScan\EvoScan v0.9\
Select Wideband->Log to wideband.csv file
- This will deselect all items except for the Wideband (WDB) log item in the list.
- This will set the baudrate to 19200 (change it to 9600 for AEM or Zeitronix, LM1 uses 19200, for other wideband loggers set it to the manufacturer listed baudrate)
- Now plug in your serial cable from your wideband and "start datalogger"
- It will clear the serial port buffer ~60times/sec
- and it will log to a file called C:\Program Files\EvoScan\EvoScan v0.9\EvoScanWideBandLog_200609??.csv and any errors will be logged to an errors.csv file.
- After you have finished logging your wideband device,
send a copy of your csv log files to wb@limitless.co.nz along with the name and model of your wideband device, and the actual value or range of values that were displayed on the wideband device at the time of logging.
Thanks for your support,
Hamish.
Users browsing this forum: No registered users and 33 guests
