Mitsubishi Evo4-EvoX and Subaru EvoScan Datalogging Project
Postby chrisw » Mon Sep 11, 2006 9:52 am
I have spent limited time working with it. So far I get the same results that AutoXer reported with my LC-1. It reads, but only in a range of 19-20 (at idle)
chrisw
Postby A418t81 » Mon Sep 11, 2006 1:06 pm
Logging my LC-1 through evoscan gives me AFRs in the 40s on idle. Logworks open at the same instance reads correctly.
A418t81
Postby hexman » Mon Sep 11, 2006 1:39 pm
Evo4mad. I am the guy who gave you the Innovate protocol info. It seems that there may be an error in the LC-1 sub-packet definition. Thoughts???
hexman
Postby NoQuarter » Mon Sep 11, 2006 3:27 pm
A418t81 wrote:Logging my LC-1 through evoscan gives me AFRs in the 40s on idle. Logworks open at the same instance reads correctly.
If you mean you are reading the LC1 from both applications at the exact same time I don't think that will be possible. Both of those apps will not share the port at the same time.
NoQuarter
Postby NoQuarter » Mon Sep 11, 2006 3:29 pm
My LC-1 reading stays at 19.4 something also. It doesn't seem to change at all.
NoQuarter
Postby A418t81 » Mon Sep 11, 2006 3:59 pm
You are correct, poor wording on my part.
Curious that I am seeing 40.xxxx and everbody else here is basically seeing 20.
A418t81
Postby AutoXer » Mon Sep 11, 2006 4:59 pm
A418t81 wrote:Curious that I am seeing 40.xxxx and everbody else here is basically seeing 20.
If you're using a XD16, did you mess with it's configuration. The configuration in my XD16 is stock/default. Any thing different about your LC1 setup? Just curious.
AutoXer
Postby thefranchise » Mon Sep 11, 2006 5:34 pm
anyone get their upgrade emails yet?
thefranchise
Postby rwunsche » Mon Sep 11, 2006 5:49 pm
No upgrade email here yet.
Has anyone tried it with an AEM UEGO wideband yet?
rwunsche
Postby EBPIX » Mon Sep 11, 2006 9:55 pm
I haven't gotten an Email either... tbevoviii@hotmail.com Thanks.
EBPIX
Postby Evo4Mad » Mon Sep 11, 2006 11:40 pm
issue sorted, you should receive an email now.
Postby c-spec » Tue Sep 12, 2006 1:20 am
got my yesterday. thanks Evo4Mad :D
c-spec
Postby AutoXer » Tue Sep 12, 2006 6:22 am
NoQuarter wrote:My LC-1 reading stays at 19.4 something also. It doesn't seem to change at all.
Am I going to have to wait another couple of weeks, or <gulp> months to have this issure resolved? Logging from my LC-1 was the one feature that's had me checking the forum multiple times per day. If I could pick between having gauges, graphing, hot-keys, logging indicators and only having LC-1 logging.... I'd take the LC-1 and leave the rest in a heartbeat.
Please, fix it and give us a v0.91. Pretty please... with sugar on top.
I'm willing to be a beta tester!
AutoXer
Postby evo400 » Tue Sep 12, 2006 8:26 am
I have this problem too
the speed is working, but the MAP is showing zero at all.
evo400
Postby lvnvevo » Tue Sep 12, 2006 8:31 am
i still havent gotten an email twoquick2go@hotmail.com
thanks!!
lvnvevo
Users browsing this forum: No registered users and 23 guests
