Cannot find test connector 04 USDM STi
Postby tjamz » Sat Sep 02, 2006 4:41 pm
Car= 2004 USDM STi
So far all I can find is the two green plugs that connect together and have not been able to find the 4 wire plug that the shorting block connects to. I know exactly where it is on a 2002 USDM wrx (the 2 wire plug), but unfortunately its not in that location on this car. Need help ASAP!
tjamz
Postby Tea cups » Sat Sep 02, 2006 5:33 pm
The drive-by-wire cars like your STi do not require the jumper to flash.
Tea cups
Postby Freon » Sat Sep 02, 2006 5:40 pm
The plug is actually there, looks just like an 04/05 WRX, but it serves no purpose AFAIK.
I hooked mine up the first time I flashed, but later found out it wasn't necessary.
Postby tjamz » Sat Sep 02, 2006 7:38 pm
Yeah....my bad there, I tried it w/o the connector hooked up and it worked fine, I should have done more searching before I asked this question. Thanks for those who responded however.
tjamz
