Misfire Threshold
Misfire Threshold
Postby itp » Thu Jul 27, 2006 5:02 pm
There is a parameter in Ecuedit for changing the misfire thrsehold. I assume that increasing this number will increase the threshold. Am I right? Trying to see if my super-lite flywheel is throwing random misfire codes.
itp
Postby JRSCCivic98 » Thu Jul 27, 2006 5:47 pm
If you increase it you'll also decrease the ECU's ability to control knock at the same time... I believe.
Postby itp » Fri Jul 28, 2006 5:16 am
Really? How is that? I guess I don't see how they are related.
itp
Postby JRSCCivic98 » Fri Jul 28, 2006 3:44 pm
Ummm, because if you're misfiring your ECU needs to know this and throw the code. Whether or not it's because of your lightweight flywheel is not in question here... what is in question is how the ECU will detect knock/misfires if you turn that sensativity lower. The ECU uses the knock sensor to detect knock as well, but the CPS is also used I believe.
Postby itp » Fri Jul 28, 2006 6:20 pm
The ecu detect misfires by flucuations or break periods in the cam pos. sensor and the crank pos. sensor signals. There is a window of time that is allowable for these periods. Outside of these windows it will be consider a misfire. The knock sensor has nothing to do with detecting misfires.
itp
Postby xswrex » Fri Jul 28, 2006 10:44 pm
JRSCCivic98 wrote:If you increase it you'll also decrease the ECU's ability to control knock at the same time... I believe.
are you serious??? do you know what misfire is?
xswrex
Re: Misfire Threshold
Postby xswrex » Fri Jul 28, 2006 10:52 pm
itp wrote:There is a parameter in Ecuedit for changing the misfire thrsehold. I assume that increasing this number will increase the threshold. Am I right? Trying to see if my super-lite flywheel is throwing random misfire codes.
on various roms i have seen a value of 10, where stock was 2. You might give that a shot
xswrex
Postby itp » Sun Jul 30, 2006 6:09 am
Thanks. I'll try it. I was just trying to see what ranges people are using. Have you seen any other side effects to changing this parameter?
itp
Postby Jon [in CT] » Thu Aug 03, 2006 10:36 am
What is this parameter called? I can't find it.
Postby itp » Thu Aug 03, 2006 7:39 pm
In ecuedit 1.72 it is a 1d map called P301/2/3/4 misfire detection threshold.
itp
Postby Jon [in CT] » Fri Aug 04, 2006 4:04 am
OK. That map seems to be missing for 32-bit ECUs.
Postby itp » Fri Aug 04, 2006 6:01 am
What ecu/car?
itp
Postby Jon [in CT] » Fri Aug 04, 2006 6:50 am
Postby gethin » Fri Aug 11, 2006 8:01 am
I'm getting misfire CEL's with the UTEC LC (completely normal with injector cut) so i'll try to up my threshold to 10 and see if it stops the CEL from coming on. It's at 1 right now.
Gethin.
gethin
Postby FrSTi » Fri Aug 11, 2006 11:50 am
gethin wrote:I'm getting misfire CEL's with the UTEC LC (completely normal with injector cut) so i'll try to up my threshold to 10 and see if it stops the CEL from coming on. It's at 1 right now.
Gethin.
You shouldn't get any more CE if you set your thresold to 10 ;)
FrSTi
