Green flash connectors
Postby qoncept » Tue Apr 04, 2006 6:17 pm
I'm tired of fooling around under my dash.. Does anyone know where I can get both male and female type green flash connectors so I can just plug them in and wire in a switch? Also, the flash block jumper would be nice rather than the paperclips I'm using now.
Postby Hitokiri » Tue Apr 04, 2006 7:22 pm
why don't you just plug them in and wire a switch in on either side of one connector??
Postby calvinc » Tue Apr 04, 2006 11:01 pm
order the following part from your subaru agent. part # 24036AA010 - it is a harness adapter set. comes with 3 adapters for the various models.
see .pdf attachment for details.
jumper_harness.pdf
(78.46 KiB) Downloaded 1549 times
Postby cboles » Tue Apr 04, 2006 11:30 pm
I have a bunch of the raw connectors coming from Asia as we speak. I'm going to send them out to be assembled and then I should have lots of WRX init connectors. I need to look into how to ship them worldwide cheaply to keep shipping from costing more than the connector!
Postby qoncept » Wed Apr 05, 2006 12:01 pm
Hitokiri wrote:why don't you just plug them in and wire a switch in on either side of one connector??
I don't have enough loose wire to pull them out and don't feel like soldering on my back with the iron directly above my face.. :P
Thanks, Calvin
Postby Jeramie » Wed Apr 05, 2006 5:55 pm
cboles wrote:I have a bunch of the raw connectors coming from Asia as we speak. I'm going to send them out to be assembled and then I should have lots of WRX init connectors. I need to look into how to ship them worldwide cheaply to keep shipping from costing more than the connector!
Glad to see you found them as I couldn't! How many did you end up having to order?
Jeramie
Postby cboles » Wed Apr 05, 2006 7:57 pm
I ordered a 1,000 housings and far more pins than I need...
Postby Jeramie » Thu Apr 06, 2006 5:12 am
Sorry I couldn't be of more help. :(
I assume when you have them for sale you will post it somewhere?
Jeramie
Postby cboles » Thu Apr 06, 2006 8:18 am
Yes, I'll put them on the Tactrix website.
Postby Jeramie » Thu Apr 06, 2006 8:43 am
Cool beans I'll be waitting!
Jeramie
Postby mrtMY03Aust » Tue Apr 18, 2006 12:33 am
cboles wrote:Yes, I'll put them on the Tactrix website.
Looking forward to this also!
mrtMY03Aust
Postby KAX » Sat Jun 17, 2006 5:11 pm
calvin, do you have to order all three of those together, or do you know the part number for the individual connectors? dont feel like spending $20 for 3 connectors when i only need 1. Or should i just get it from tactrix?
KAX
Postby JRSCCivic98 » Sun Jun 18, 2006 8:51 am
Just get the Tactrix one.
Postby calvinc » Mon Jun 19, 2006 12:03 am
KAX wrote:calvin, do you have to order all three of those together, or do you know the part number for the individual connectors? dont feel like spending $20 for 3 connectors when i only need 1. Or should i just get it from tactrix?
it comes as a kit so you have to buy the whole thing. i bought that long before the tactrix ones were available...if you only want a particular housing then buy it from tactrix.
Postby swifty » Mon Jun 19, 2006 1:59 am
I have the flash block connected all the time. Luckily my car only needs one wire with a couple of spade connectors. I wired my green test connectors up to a switch in the console near the handbrake. I just got some 2 core cable, a male and female spade connector and a on/off switch with a cover so when the cover is closed the switch is off. Took me about 20 minutes to do. Now I can drive my car, log, check logs, adjust map and flash and I don't have to get out of the driving seat.
swifty
Return to OpenECU Hardware
Users browsing this forum: No registered users and 23 guests
