misfire problems help cams BC 272
Postby mariokerdj » Tue Jun 07, 2016 11:44 am
hi i need help my car is wrx 2002 i have BC cams, adjustable cam gears, spring kit all BC, my car show misfire the cods are p0301, p0302, p0304.
the spark has changed 2 weeks ago have iridium bkr8 the sparkplug is black i set the rpm in 850 and i cant eliminate this codes i know if i desactivate in the map but i dont like to do dis i need an other solution help me please or tell me what i need to do..?? in the map o the problem its other think :?
mariokerdj
Re: misfire problems help cams BC 272
Postby jaxscuby » Wed Sep 07, 2016 11:26 am
if your spark plugs are "black", you're too rich at idle.
mis-fires can be cause by running too rich at idle.
the maf table needs to be adjusted and possible your injector size.
who did your tune?
jaxscuby
Users browsing this forum: Google [Bot] and 33 guests
