Huge psi to bar error in ecu flash
Postby ssssly » Sat Oct 26, 2013 7:22 pm
There is a huge discrepancy between the Bar and PSI readings in the definition files which does not correspond to the actual conversion of bar to PSI.
For instance if I open my stock rom, A4TJ11C, with the Standard Defs file I get a target boost of 18.56 PSI (which it should be after conversion to PSI) This should equate to 1.28 Bar.
However if I open that same ROM with the Metric definitions the target boost reads 2.93 Bar or 33.2 PSI!!!
That is no where near an acceptable margin of error. *.56.....that is a ludicrous engine blowing, turbo frying discrepancy.
So how do I know what value is being uploaded to my ECU?
And why would what should be a simple multiplication problem be so off?
ssssly
Re: Huge psi to bar error in ecu flash
Postby evolutionVii » Sun Oct 27, 2013 10:42 pm
2.93 BAR ist mislabeled... Its :
2.93 BAR ABSOLUTE ( Bar is always an relative, so its only confusing this time )
In real it will be 1.93 BAR ( 1000 mBar as atmospheric pressur assumed )
1.93 BAR relative is app. 28psi
Take care that in all defs its right labeled and converted ( or calculated ) the right way.
In Evoscan its also sometimes not right calculated for logging
evolutionVii
Postby ssssly » Mon Oct 28, 2013 7:16 am
Even if that were the case which it shouldn't be, the table is relative, it is still 10 PSI high.
ssssly
Users browsing this forum: No registered users and 10 guests
