2003 STi UK Spec Does Not Connect????
Postby FMS » Tue Mar 12, 2013 3:06 am
We have a 2003 STi and we cannot access the ecu using the "usual" method:
1. Plug factory Subaru test plugs together (this will enable rad fans to come on when ignition on)
2. Plug the tactrix into obd2 port.
3. Plug usb cable from tactrix to pc.
4. Chose correct template from read/write menu.
5. Ensure imobilizer is off and turn ignition to on (engine off) and quickly press ok/enter to access ecu. When this happens the fans should not come on and download data from ecu should happen.
We have tried using ecuflash and ecuedit (full Pro Version).
Some help, advise and possible solutions would be greatly appreciated.
Craig
FMS
Re: 2003 STi UK Spec Does Not Connect????
Postby KanScooby » Tue Mar 12, 2013 8:47 pm
An ecuflash error log would help too :-)
KanScooby
Postby FMS » Thu Mar 14, 2013 5:01 am
thanks which log shall i post i have ecu edit and ecu flash?
FMS
Postby KanScooby » Tue Apr 02, 2013 11:46 pm
Copy and paste the text appearing on the Log Window of ecuflash.
KanScooby
Postby ibinsam » Tue Aug 13, 2013 5:26 pm
same case like me..model 2003 wrx sti v8 uk spec..error pop up "interface not connected "..i had connect the green interface connector,tactric jumper..swap tactric kit with my fren still same...my ecu havent tweak with ECUTEK or e
other tuner,,pls advice
ibinsam
Postby Bluntslide » Sat Sep 21, 2013 6:33 pm
Not sure if you have tried this,but my 03 needs a jumper plug to flash.
I was getting the same thing,then plugged it in and WALAAH...
Bluntslide
Users browsing this forum: No registered users and 48 guests
