New online logcfg.txt generator (subaru)
Postby hunterjm » Sat Dec 22, 2012 9:39 pm
Hey,
So I saw that there was a tool by Freakin which inspired an online version of a config generator, but they still required a lot of work to create your config in my opinion. Most of us already have logger profiles set up in RomRaider that we switch between. I created an online generator that uses these profiles to create a logcfg.txt and also supports calculated parameters. With this tool you can upload your profile, choose which version of the official logger definitions to use, select your ECU ID from the dropdown, pick K-Line or CAN BUS, and choose between two triggers (for now).
I would appreciate any feedback: http://subaru.hunterjm.com/
Thanks!
hunterjm
Re: New online logcfg.txt generator (subaru)
Postby Blake » Thu Dec 05, 2013 2:36 pm
Man after I saw this I had register and create a login just to say thanks. This generator saves so much time in all my logging. The file it makes is very organized and easily tweaked. So thanks man this has really helped the past couple of days. I can't believe this has been online for a year and I've just now seen it. Saves a lot of time and hours of typing.
Blake
