ECU Reading/Flashing software for 2004 USDM Forester XT ?
Postby twg » Tue Feb 21, 2006 9:22 pm
Do the current tools support this vehicle ?
The ECU is pin compatible with the STI ecu... I can plug the STI ecu in my car and it will work (with the sti turbo of course)
I have a spare FXT ecu for the time being if that helps anyone (will need it back tho)
twg
Postby Kha0S » Wed Feb 22, 2006 3:13 am
Not currently. The 04+ DBW ECUs are not yet supported by the ecuFlash tools, but it appears that Colby is close to finishing it.
Kha0S
Postby cboles » Wed Feb 22, 2006 9:31 am
... very close!
Postby Rigos gt » Thu Feb 23, 2006 10:50 am
how close? :lol:
Rigos gt
Postby twg » Tue Mar 14, 2006 7:43 pm
any idea of ballpark time frame for completion ?
I've got 2 ECUs, one is a backup, the other I have to send out to get reflashed... I was hoping to backup the ECU that will get reflashed to make sure that I have a backup in case something happens... but I've got someone that needs the 2nd ECU back soon...
wondering if I should wait or just send the ecu out to be reflashed...
twg
Postby Jaxx » Wed Mar 15, 2006 2:24 pm
i too was wondering .. is this going to require a 2.0 cable?
Jaxx
Postby cboles » Wed Mar 15, 2006 2:38 pm
The OpenPort 1.2 cable works for the DBW ECUs. I'm just trying to get the map editing finished, or at least to a point with a non-broken feature set. We should see support for the DBW's before the months end. Evo's will come not long after that when the Evo hardware is ready.
COlby
Postby twg » Fri Mar 17, 2006 8:23 pm
thanks, I'll try to hold out for another 2 weeks...
twg
Postby Jaxx » Wed Mar 22, 2006 9:06 pm
sweet
i want to back up my ecu before i install an AP even if i cant reflash it back
ill be placing an order for the 1.2
thanx
Jaxx
Postby twg » Thu Mar 23, 2006 7:08 am
1 more week!!!! :D
twg
Postby BoxerFan » Fri Mar 24, 2006 5:04 am
cboles wrote:The OpenPort 1.2 cable works for the DBW ECUs. I'm just trying to get the map editing finished, or at least to a point with a non-broken feature set. We should see support for the DBW's before the months end. Evo's will come not long after that when the Evo hardware is ready.
COlby
Hi Colby, would the OpenPort 1.0G cable work with your new software - to read at least ? Is there anyway to modify the 1.0G cable to do flashing?
BoxerFan
Postby cboles » Fri Mar 24, 2006 10:18 am
The 1.0G can technically work, because the DBW ECUs I have seen generate theire own reflash voltage. Some may still look for 12V on this line though, even though the don't use it. One issue is operational speed. The DBW reflash software I am running right now operates at too high of a baudrate for the OpenPort 1.0. I will eventually change the software to operate at a slower baudrate for the 1.0, but probably not in the first release. I will try to support all of the existing versions out there.
Postby twg » Thu Mar 30, 2006 12:57 pm
Oh no!! I have v1.0 of the OpenPort cable, I have the cable that can provide a flashing voltage... please support this cable when you release your software!!! (Or let me know if I can exchange for v1.2+$$$)
thanks!!!
twg
