Subaru MAF table
Subaru MAF table
Postby project_skyline » Wed Jan 11, 2012 5:41 pm
Not sure if this is even the forum but I'm wondering if there is anyway to change the XML to view the MAF table in some different form so you can see it all.
Currently if you open it under the ecuflash it will display the values in a large vertical rectangle table and you can't scroll up or down.
This makes modifying it very difficult without opening in romraider which doesn't allow for easier adjustment compared to ECUflash.
If there is no way to change this might I suggest adding some way to do so.
No idea where a suggestion like that would be made.
project_skyline
Re: Subaru MAF table
Postby Sasha_A80 » Wed Jan 11, 2012 10:29 pm
You may cut the whole MAF table in a set of sub tables in the definition file.
Sasha_A80
Return to OpenECU Software
