evo 7 ecu
evo 7 ecu
Postby wcassar1985 » Mon Oct 24, 2011 4:21 pm
Hi all, I am the owner of a mitsubishi lancer with 4g63 engine anf also have evo7 ecu fitted to it too.
I bauht the openport cable too.
which is the best thing to do first, to read from ecu?
and than save as it and edit it?
regards
wcassar1985
Re: evo 7 ecu
Postby radsdau » Tue Oct 25, 2011 6:22 pm
Correct. Save a copy of your current/original ROM before you do anything else. If it all goes pear-shaped, you can just put it back to how it is now.
And make a backup. These ROMs have security codes specific to your car, so if you lose it, you'll be stuck with a car that doesn't work.
Start tuning from a copy of your ROM.
Re: evo 7 ecu
Postby wcassar1985 » Tue Oct 25, 2011 7:45 pm
I used the evoscan software 2.8
I read from the ecu and it save sort of file +++++.hex on the left side.
How can i save a copy of it?
regards
wcassar1985
Re: evo 7 ecu
Postby todd-w » Sat Oct 29, 2011 12:55 pm
add these to your ecuflash rommetdata
evo7base.xml
(26.21 KiB) Downloaded 1125 times
98640014.xml
(22.53 KiB) Downloaded 1112 times
todd-w
Re: evo 7 ecu
Postby wcassar » Mon Oct 31, 2011 9:25 am
what are these files neccessary for?
regrads
wcassar
Re: evo 7 ecu
Postby wcassar » Mon Oct 31, 2011 9:33 am
cause i m still a beginner in using the evoscan software.
wcassar
Re: evo 7 ecu
Postby todd-w » Mon Oct 31, 2011 1:27 pm
they are definition files necessary to make the rom viewable , get a copy of ecuflash below
http://www.tactrix.com/index.php?option ... &Itemid=58
todd-w
Re: evo 7 ecu
Postby wcassar » Tue Nov 01, 2011 4:59 am
ok, i have downloaded it......now were should i put the 2 files please?
regards
wcassar
Re: evo 7 ecu
Postby todd-w » Tue Nov 01, 2011 1:30 pm
save to my computer/C:/program files/open ecu/ecuflash/rommetdata/misubishi/evo if it asks to replace existing files click yes
todd-w
Re: evo 7 ecu
Postby wcassar » Fri Nov 04, 2011 5:03 am
thats fine i have managed to do it.
Now I tried to connect with the ecu flash and some errors are poping out and not letting me connect to my ecu.
Are there any options that i shall do to connect well?
thanks
regards
wcassar
Re: evo 7 ecu
Postby todd-w » Sun Nov 06, 2011 1:06 pm
what errors ??
todd-w
Re: evo 7 ecu
Postby wcassar » Wed Nov 09, 2011 10:23 am
no reply from ecu.....
regards
wcassar
Re: evo 7 ecu
Postby radsdau » Wed Nov 09, 2011 7:08 pm
Double check the flash-enable connector is plugged in correctly too; that's important.
Re: evo 7 ecu
Postby wcassar » Wed Nov 09, 2011 9:39 pm
with regards to cable i think that is ok because with the evoscan i succeed to connect and clear the fault codes.
regards
wcassar
Re: evo 7 ecu
Postby radsdau » Thu Nov 10, 2011 3:48 pm
Connecting to read codes and connecting to reflash are not the same. Reflashing requires the extra connector, because it forces the micro to run 'boot' code. You can't reflash without that.
Users browsing this forum: Bing [Bot] and 37 guests
