Keihin CBR1000RR8 ECU interface crack
Postby jube » Fri Jul 04, 2008 6:06 am
Hi all am embarking on a project to modify the code, or just modify the data ( whichever i can achive ) of a standard Keihin cbr1000rr8 ecu.
Has anyone got any experience of cracking these little buggers? I have a circuit for an ODB type interface which is used to prog the HRC ECU versions, but maybe i should tackle it via re-prog the flash as in the Hyabusa post?
jube
Postby Jon [in CT] » Fri Jul 04, 2008 7:39 am
I'm guessing you're talking about some kind of Japanese motorcycle. These forums are oriented toward Japanese cars. Although bike and car ECUs frequently share similar microprocessors, you should visit the forums at http://www.activeboard.com/forum.spark?forumID=99460&p=1, which specialize in Japanese motorcycle ECUs.
Postby jube » Fri Jul 04, 2008 11:58 am
thanks for that mate, had a good look around on that site, all great stuff but zero Honda info tho.
The site seems to consentrate on Denso varient ECU's
Yep its a bike we're on about, also known as the honda fireblade.
With a Keihin ECU, do any honda cars have Keihin ECU's ?
jube
Postby christian_piasini » Mon Jul 07, 2008 10:10 pm
jube wrote:thanks for that mate, had a good look around on that site, all great stuff but zero Honda info tho.
Hello,
Yes a lot of Honda cars has the Keijin ECU.
We support to read/write the last ecu of the Honda of the car.
And I'm pretty to finish the read/write of the Honda CBR600 RR7.
for futuremore question contact us.
Postby jube » Wed Jul 09, 2008 3:05 am
hi christian..
have mailed you, at address on this site ?
thanks for the picture, its very interesting, i assume its from some car?
Should i look around this site and build experience on the communication software you guys use?
jube
Re: Keihin CBR1000RR8 ECU interface crack
Postby christian_piasini » Mon Sep 26, 2011 8:32 am
If you need to fine tune the honda bikes for race, then you need look at that :
BR
HONDA CBR 600-1000 RACE KIT.jpg (1.49 MiB) Viewed 17641 times
Users browsing this forum: Google [Bot] and 36 guests
