Should ECUFlash save to XML files?
Postby CANMAN » Tue Aug 09, 2011 2:59 am
As the subject, should ECUFlash save the table definition to an XML via the "save models" button? Or some other way?
Every time I define a table for a new bin, once the app is closed the definition is lost. :shock:
Thx!
CANMAN
Re: Should ECUFlash save to XML files?
Postby CANMAN » Tue Aug 09, 2011 9:30 pm
Marcello wrote:you need to "Save Models" after mods to the definitions
otherwise the mods aren't stored in xml
Thank you for the reply. Saving via "save models" does not appear to work. No XML file is saved in the rommetadata directory/folder or anywhere else. Tried both the release version and the beta version and behavior is the same.
CANMAN
Postby CANMAN » Tue Aug 09, 2011 9:48 pm
Found that if I ran ecuflash as admin the xml does save. :D
CANMAN
Return to OpenECU Software
Users browsing this forum: No registered users and 26 guests
