How to ecu on bench evo8mr
Postby kasipong » Mon Aug 08, 2011 8:58 am
Please help i need to know about odb2 pin for reflash ecu evo8mr
I'm connect ecu
Pin 46 = Gnd
47 = 12 v.
58 = Gnd
59 = 12 v.
60 = 12 v. backup
99 = Ig. on
Pin obd2
Pin 7 connect to ecu pin 85
Pin 4-5 connect to ecu Gnd pin 46,58
Pin 16 connect to ecu pin 60
and i need to know other pin for connect it
I need to disable Immobilizer for ecu Evo8mr but now i can't read data from this ecu.
Please help
kasipong
Re: How to ecu on bench evo8mr
Postby And » Mon Aug 08, 2011 11:51 pm
you can read this ecu while its still in the car and if it is locked then run the unlocker before opening ecuflash and you should be fine to read and right
Andy
And
