Need Help with 08 Evo X Rom Gulf Specs
Postby E6-X » Mon Oct 12, 2009 9:58 am
Hi all,
I plugged in my OP 2.0 cable and downloaded my ROM. It all went well. Ecuflash asked me to switch ignition off after finished downloading the file and I saved it.
I tried to open my downloaded ROM and Ecuflash says "unknown ROM image" can someone out there help me out ?
I also tried complete shutting down my car then when i restarted, i had a CEL and i manage to read the code from EVOSCAN and it says " ECUID" . . . also tried to clear it but no help.
Battery was also disconnected for approx. 5 mins no help but when i went and check on my car again and started it up, the CEL was gone.
After spending hours of reading, i think i need a definiton file for my ROM (attached). I really hope someone can help me out with many thanks in advance.
08 Evo X MR Gulf Specs. Using latest ecuflash v1.42, win xp sp3.
evox2008gulfspecs.hex
ROM file
(1 MiB) Downloaded 873 times
E6-X
Re: Need Help with 08 Evo X Rom Gulf Specs
Postby todd-w » Tue Oct 13, 2009 8:38 am
try this attached
53050006.xml
(13.57 KiB) Downloaded 876 times
todd-w
Postby E6-X » Fri Oct 23, 2009 5:27 pm
thx todd, will give it a try, just downloaded the xml :D
E6-X
Postby billion01 » Sun Mar 27, 2011 6:24 pm
Hi guys, I am getting this unknown rom image error every time I try to work on an EVO X. It connects fine and reads fine but when I try to work on it, it asks me if I want to use a wizard to create a rom definition or abort using this rom image.
I attached the file I pulled from one of the vehicles.
Any and all help will be greatly appreciated,
evoxred.hex
(1 MiB) Downloaded 790 times
billion01
Postby rwebber » Sun Jul 24, 2011 11:14 am
Hi,
Did you ever figure out how to tune your Gulf Spec Evo X? I would love to know how to tune it myself. I really dont want to pay 3000AED for a tune when I can do it myself and learn alot (have fun) at the same time.
Regards,
Ramsey
rwebber
Postby And » Mon Jul 25, 2011 10:18 pm
hi billion01
heres an xml for your rom
Andy
55570005.xml
(8.61 KiB) Downloaded 848 times
And
Postby evooman » Tue Jul 26, 2011 10:59 am
Hi guys
im new to ecuflash
i have the XML file as well as the hex file but im not sure how it works every time i try and open the hex file it says unknown ROM how do i change the file ?
please help
evooman
Postby And » Tue Jul 26, 2011 11:03 pm
just upload the hex to here and I'll generate you an xml for it,
if you already have teh correct xml then its should be placed in the (where ever installed normally Program Files)OpenEcu\Ecuflash\rommetadata\mitsubishi\evo directory
Andy
And
Postby evooman » Wed Jul 27, 2011 1:02 am
Hey Andy
Thenks for your help i've attached the hex file looking forward to hearing from you
MK- AMS Evo X AMS v1.hex
(1 MiB) Downloaded 781 times
evooman
Postby And » Wed Jul 27, 2011 10:25 pm
here you go
Andy
53050009.xml
(34.27 KiB) Downloaded 835 times
And
