can't read the 05 2.5l JDM Fxt
Postby Zakie@TIC » Fri May 27, 2011 3:02 am
I have been trying to read a 2005 JDM 2500cc Forester without much luck, tried with and without the green test contectors but I can't find a flash block connector with either 3 or 4 pins. I'm using a 2.0 cable tried ver.1.42 1.43 of eciflash.
Heres the log if any one can help.
Regards,
Zakie
PS: The cable works fine on a EVO8
[15:42:47.687] EcuFlash Version 1.43.3150
[15:42:47.687] OS Version Windows XP
[15:42:47.687] Qt Version 4.6.2
[15:42:47.703] 62 memory models read.
[15:42:47.703] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash1.43/rommetadata
[15:42:47.953] 354 ROM metadata models scanned.
[15:42:47.953] checksum module "subarudbw" loaded.
[15:42:47.953] checksum module "mitsucan" loaded.
[15:42:47.953] checksum module "mitsuh8" loaded.
[15:42:47.953] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[15:42:47.953] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[15:42:47.953] flashing tool "wrx02" loaded.
[15:42:47.953] flashing tool "wrx04" loaded.
[15:42:47.953] flashing tool "sti04" loaded.
[15:42:47.953] flashing tool "sti05" loaded.
[15:42:47.953] flashing tool "mitsukernel" loaded.
[15:42:47.953] flashing tool "mitsukernelocp" loaded.
[15:42:47.953] flashing tool "mitsubootloader" loaded.
[15:42:47.953] flashing tool "shbootmode" loaded.
[15:42:47.953] flashing tool "shaudmode" loaded.
[15:42:47.953] flashing tool "subarucan" loaded.
[15:42:47.953] flashing tool "mitsucan" loaded.
[15:42:55.750] J2534 API Version: 04.04
[15:42:55.750] J2534 DLL Version: 1.00.3147 Sep 3 2010 00:11:07
[15:42:55.750] Device Firmware Version: 1.11.3137
[15:42:55.750] Device Serial Number: TAKqp9jY
[15:42:59.625] kernel get version
[15:42:59.843] interface close
[15:42:59.875] J2534 API Version: 04.04
[15:42:59.875] J2534 DLL Version: 1.00.3147 Sep 3 2010 00:11:07
[15:42:59.890] Device Firmware Version: 1.11.3137
[15:42:59.890] Device Serial Number: TAKqp9jY
[15:43:00.171] VIN read not supported
[15:43:00.281] interface close
[15:43:00.312] J2534 API Version: 04.04
[15:43:00.312] J2534 DLL Version: 1.00.3147 Sep 3 2010 00:11:07
[15:43:00.312] Device Firmware Version: 1.11.3137
[15:43:00.312] Device Serial Number: TAKqp9jY
[15:43:00.484] SSM2 init
[15:43:00.625] SSM2 ECU ID is 3B02594216
[15:43:00.718] Requesting Seed...
[15:43:00.765] Sending Key...
[15:43:00.812] interface close
[15:43:00.843] interface close
[15:43:41.453] J2534 API Version: 04.04
[15:43:41.453] J2534 DLL Version: 1.00.3147 Sep 3 2010 00:11:07
[15:43:41.453] Device Firmware Version: 1.11.3137
[15:43:41.453] Device Serial Number: TAKqp9jY
[15:43:43.718] kernel get version
[15:43:43.921] interface close
[15:43:43.953] J2534 API Version: 04.04
[15:43:43.968] J2534 DLL Version: 1.00.3147 Sep 3 2010 00:11:07
[15:43:43.968] Device Firmware Version: 1.11.3137
[15:43:43.968] Device Serial Number: TAKqp9jY
[15:43:44.265] VIN read not supported
[15:43:44.375] interface close
[15:43:44.406] J2534 API Version: 04.04
[15:43:44.421] J2534 DLL Version: 1.00.3147 Sep 3 2010 00:11:07
[15:43:44.421] Device Firmware Version: 1.11.3137
[15:43:44.437] Device Serial Number: TAKqp9jY
[15:43:44.593] SSM2 init
[15:43:44.750] SSM2 ECU ID is 3B02594216
[15:43:44.843] Requesting Seed...
[15:43:44.906] Sending Key...
[15:43:44.953] interface close
[15:43:44.984] interface close
Zakie@TIC
Re: can't read the 05 2.5l JDM Fxt
Postby radsdau » Sun May 29, 2011 4:49 pm
Looks like the ECU is locked. Perhaps EcuTeK.
Search forum for people who can unlock it for you.
Postby Zakie@TIC » Tue Jun 21, 2011 12:13 pm
Whats the right place to look for such poeple
Zakie@TIC
Postby radsdau » Wed Jun 22, 2011 4:57 pm
I know of 2: Tactrix in the US, Chiptorque in Australia.
Postby ®@©E® » Sun Jun 26, 2011 10:16 am
Possibly, there is another pair of green connectors, somewhere near the ecu
®@©E®
Postby KanScooby » Mon Jun 27, 2011 2:59 am
Only one set of green test mode connectors under the dash / steering column. Time to hit the ok button to read the rom immediately after turning on the ignition as it will be impossible to read if the car enters test mode. Read and written to a number of these STi Fozys here from 04 to 06 with no worries.
KanScooby
Users browsing this forum: No registered users and 48 guests
