buidling a shboot mode device
Postby adamsaiyad » Thu May 05, 2011 10:12 am
I will be tuning alot of cars here in Zimbabwe eventually, but i need to make sure i have a backup plan, is there any way of building this sh boot mode interface adapter, i have gone onto tactrix downloaded the schematic but the person who i have shown it to says we need two ics ?
How do we programme these ics for the job intended... rescuing subaru ecus?
alternatively is there someone out there that makes these and can supply me with two of them ?
I dont want to brick an ecu and then have to be waiting to make one or even have to send the ecu to tactrix as in africa shipping to america is 150 usd
Then shipping back another 100 usd plus the time factor of having a car off the road .
Please help from those experienced.
or email me adam@yoafrica.com
adamsaiyad
Re: buidling a shboot mode device
Postby adamsaiyad » Thu May 05, 2011 10:21 am
ok i have figured out a little i have a sunix usb to serial adapter its a UTM1925B but im uncertain if this will work ?
Do i have to have the exact cable mentioned on the tactrix website ? the FTDI based usb to serial adapter ?
If so which website in America can i order one off ? thanks in advance will need more help when it arrives to figure out how to build this cable .
adamsaiyad
Postby Sasha_A80 » Sat May 07, 2011 11:53 am
You may use any USB\UART or COM\UART converter with free Renesas FDT tool.
But. Denso ECU needs watchdog timer badly for BootMode. Otherwise ecu will be reset each 40-50 ms.
Sasha_A80
Postby adamsaiyad » Tue May 10, 2011 9:20 am
Sorry but not sure as the tactrix site said i needed a specific chipset ?
So this is the cable i have
http://www.sunix.com.tw/product/uts2009 ... 77777.html
And wanted to check and confirm it will work.
i can get a watch dog timer from a local electronics store.
Please confirm if this will work yes or no ?
Thankyou for taking time to respond .
adamsaiyad
Postby Sasha_A80 » Tue May 10, 2011 11:27 am
You need FTDI based chipset for Tactrix.
The cable you have mentioned is MosChip based and is not applicable for Tactrix.
Moreover RS232 is not applicable for SHbootMode.
You will need UART (aka MAX232 or equivalent as a convertor or USB\UART adapter) and use Renesas FDT in case of using non-FTDI based adapter .
Sasha_A80
Postby adamsaiyad » Thu May 12, 2011 1:09 pm
Sorry Sasha_A80 where can i buy this cable you are speaking of?
can i buy it from amazon.com ?
adamsaiyad
Postby Sasha_A80 » Thu May 12, 2011 8:08 pm
The cheapest "VagCom compatible k-line adapter" is FTDI based and is applicable for SHboot Tactrix mode (with appropriate redesign).
ANY USB/UART adapter based on reputable chipset (FTDI, Prolific, SiLabs) is applicable for Renesas FDT software.
WatchDog time circuitry is required for Denso ECU regardless of the chipset of the adapter used.
Sasha_A80
Postby radsdau » Sun May 15, 2011 3:57 pm
This page
http://www.tactrix.com/index.php?option ... &Itemid=41
gives instruction on how to do it, and includes a full schematic of the required hardware. The 555 timer provides the watchdog tickler.
Users browsing this forum: Bing [Bot] and 37 guests
