Can not read out Evo9 ECU
Postby Flash4u » Tue Feb 01, 2011 2:02 am
Hello I have troubles with this error code if I tried to read out or write the ecu:
I have tried it several times to read out the ecu and then it worked, but whole time I got this error message. At the moment its not possible to write or read out the ecu.
Is the ecu blocked, or whats the problem?
sending init sequence 1 (0001)
J2534 error [ERR_TIMEOUT].
interface close
Use OpenPort2.0 Interface, tried 1.42. and 1.43 version.
No stock file on ECU, but file is crap.
Flash4u
Re: Can not read out Evo9 ECU
Postby radsdau » Wed Feb 02, 2011 3:29 pm
It could be locked. Use 'EVO Unlocker' (search this forum) to discount that possibility.
Have you reflashed EVOs before? It could be a problem with the OP cable or the connection to the programming mode connector (separate connector next to OBDII connector).
Users browsing this forum: No registered users and 51 guests
