Need Definition File Needed for 52200010
Postby ofey » Fri Nov 26, 2010 3:47 pm
Can anyone point the way forward in getting an open definition file for 52200010?
I've uploaded my base ROM in case anyone can help.
Thanks in advance.
MY08 4B11 CVT Stock ROM.hex
(1 MiB) Downloaded 1198 times
ofey
Re: Need Definition File Needed for 52200010
Postby ed_GST » Fri Nov 26, 2010 8:59 pm
This def is just a head start
The axis needs to be fixed but the maps are correct
Also RPM limit is correct
52200010.xml
(2.61 KiB) Downloaded 1325 times
ed_GST
Postby ofey » Sat Nov 27, 2010 4:54 am
Thanks for the file ed.
I've worked abit on the file and put in a few more bits which I've returned to you via PM. Any help will be much appreciated.
The axis addresses for the High Octane Fuel Map and Low Octane Fuel Map don't look quite right as mentioned and is actually the crux of the problem I think.
ofey
Postby ofey » Sat Feb 05, 2011 2:22 pm
Just as an Update, I have this configured already with a bit of help from a couple of guys (you know who you are Thanks!!).
ofey
