OBD Scan Tech (OBD II Generic) - A WORKING OBD-II SCAN TOOL!
Works on an older Impreza RS
Postby Penphoe » Tue Apr 15, 2008 4:08 pm
To add more confusion to the mix, I was able to use my Tactrix 1.3 cable to connect to my friend's MY01 Impreza RS using the Scan Tech 0.77 software. It successfully grabbed his CEL code P0420 and was able to reset it. I should have grabbed the freeze-frame data as well, but didn't. :(
Wierd. Works with older cars, but not with my MY05 LGT.
:cry: :?
LaterZ!
Darren!!
Penphoe
Postby LGT-3-6 » Tue Apr 15, 2008 4:18 pm
05 LGT here as well. People with older openports have gotten it working on the 05 LGT.
LGT-3-6
Re: OBD Scan Tech (OBD II Generic) - A WORKING OBD-II SCAN T
Postby Murdah777 » Thu Oct 14, 2010 5:02 am
I have tried installing the software and it gave me an error when i clicked on the installer .exe file. anyone have this same issue?
generic ambien
generic cialis
Murdah777
Postby SirVilhelm » Tue Oct 26, 2010 10:12 am
Hey MalibuJack, did you ever update this software? Couldn't find it on your site.
SirVilhelm
Postby zackpuse » Tue Oct 26, 2010 8:06 pm
zackpuse
Postby fazfuz » Sat Dec 04, 2010 12:35 pm
Hi GUys
just am intersetsted if i can use TACTRIX OPENPORT 2.0 REV C for pulling generic data from my OBD port.
have a Golf R32 model 2007 and would love to use the data for real time gauge viewing.
am still thinking if i should use the data to display on my i-phone or get a incar pc double din.
any ideas and thoughts are much appreciated
fazfuz
Postby 02rexwi » Thu Jan 20, 2011 12:14 pm
I'm trying to use this software, but whenever I try to configure my cable it says it was unable to establish communication. The cable is a tactrix 2.0 cable, COM port was set to COM 1, the options were set up with tactrix cable at first, but then I tried the Jeff protocall, but neither seem to work. The communication log wont register any new information in it, it stored the first attempt, but now it always gives me the same timestamp on the log, so it seems as if its a program problem. I tried uninstalling the program and re installing it, but that hasn't helped.
Any ideas?
02rexwi
Postby edcmat-l1 » Thu Dec 29, 2011 8:02 am
02rexwi wrote:I'm trying to use this software, but whenever I try to configure my cable it says it was unable to establish communication. The cable is a tactrix 2.0 cable, COM port was set to COM 1, the options were set up with tactrix cable at first, but then I tried the Jeff protocall, but neither seem to work. The communication log wont register any new information in it, it stored the first attempt, but now it always gives me the same timestamp on the log, so it seems as if its a program problem. I tried uninstalling the program and re installing it, but that hasn't helped.
Any ideas?
Same here. I know the comm port and drivers are setup correctly, I can read and write using EFUFlash. I'm trying to scan a MY02 Impreza. Whether I set it to auto detect or setup the comm port myself, same deal. No communication.
edcmat-l1
