Support for tiburons
Postby TiburonRaven » Thu Apr 05, 2007 3:09 am
so it's a no go project? no one cares?
TiburonRaven
Postby Alpha_Turbo » Thu May 03, 2007 8:03 am
Hello, i've a Accent 2005 (is a KEFICO/BOSCH ECU, not SIEMENS like the beta engines)....... someone find any software to download and upload the Bin file :o :D ??....
I've a OBD2 Interface Multiprocol and i try to connect to the ECU by K-Line, but not good results (i try about 30 different softwares :( ). I try with ECUflash also and get a error (i will post this error later, don´t have the picture in my job......all the info is in my home).....hope you can help me.
i want to contribute to this project, so anything i can help.....just ask.
Greetings
....sorry for my english.....
Alpha_Turbo
Postby pewp » Sun Jul 01, 2007 3:34 pm
TiburonRaven wrote:so it's a no go project? no one cares?
i sent colby or whatever his name is an ecu over a year ago and never heard from him again. this won't happen, i wash my hands of it all.
pewp
Re:
Postby promo » Tue Aug 31, 2010 10:07 am
I'm not quite finished yet...bringing this back from the dead.
http://www.alpha-bid.com/product50.html#50
We could use that as an interface. SFR has done it using this. Why can't we? All we need is some simple software and since you guys have done it multiple times why not just take the step forward in creating something that will spark interest in Hyundais again? Genesis's can also use something similar...right?
promo
Re: Support for tiburons
Postby radsdau » Tue Aug 31, 2010 3:06 pm
The hardware's the easy bit. The vehicle security is the biggest challenge. You really need a full ROM and a capture of a reflashing event to start with.
Without that it's a long long road.
Postby promo » Thu Sep 02, 2010 6:04 am
radsdau wrote:The hardware's the easy bit. The vehicle security is the biggest challenge. You really need a full ROM and a capture of a reflashing event to start with.
I've acquired both..how do I flash the stock ECU with it? Currently we need to take the Eprom out and program it before putting it back in. I want to be able to do it through OBD...
promo
Postby radsdau » Thu Sep 02, 2010 4:32 pm
Get IDA Pro and disassemble the ROM. Have fun!
Postby radsdau » Thu Sep 02, 2010 4:33 pm
You have both of what?
Sounds like you need to get IDA Pro and disassemble the ROM. Have fun!
Postby promo » Mon Sep 06, 2010 10:42 am
radsdau wrote:You have both of what?
How do I disassemble it? Is there a method or do I just search until I find?
promo
Postby radsdau » Mon Sep 06, 2010 3:49 pm
promo wrote:How do I disassemble it? Is there a method or do I just search until I find?
You first have to identify the processor type, then find out if it's supported by IDA Pro.
Then buy IDA Pro- it's worth it.
Then read this thread: viewtopic.php?f=54&t=4362
Postby promo » Tue Sep 07, 2010 9:43 am
It's a Siemens C167. IDA PRO supports C166. Not sure about 167.. :|
promo
Postby radsdau » Tue Sep 07, 2010 3:47 pm
Pretty sure it will be close enough to disassemble.
Postby warp.routine » Tue Mar 29, 2011 2:51 pm
bump...
sounds like we keep making a little progress here and there. I would like to see this project come to life. I don't have a lot to give in the way of support but i'd happily do what I can to get this rolling again... I feel that once we crack the secrets of one or two ECUs, we should be able to easily adapt programming for multiple powerplants.
warp.routine
Postby M.Kyle » Sun Sep 11, 2011 11:09 pm
Dang, this seems very dead :)
M.Kyle
Users browsing this forum: No registered users and 50 guests
